Garage floor coatings - Epoxy vs. Polyaspartic | FerrariChat
Discussion in 'Technical Q&A' started by ramosel, Jun 30, 2011.
  1. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    So it looks like we are buying a new garage (some house thing attached too...). There are no coatings on the garage floors yet. I've had good luck with the Epoxy coatings from UCoat-it in the past but I keep hearing about the new Polyaspartic/Polyurea coverings. Does anyone have any first hand knowledge or experiences with the Poly products? Advacoat?
    I'm particularly interested in Advacoat's metallic process that make the floor look like hammertone metal. If you haven't seen it, its wicked stuff. But, I'd like to know more about performance of the product if you have any input, Thanks!
    Rick
  2. Russ Birch
    Russ Birch Formula Junior
    Oct 31, 2003
    437
    Clearwater, FL
    Russ Birch
    I can't comment on either of those, but FWIW, we used xylene acrylic on new concrete and it still looks brand new after 7 years. No chipping, no cracking, no discoloration. It does show tire tracks where the cars come in and out, but it is very minor and can be cleaned with soap and a brush.
    Downside? Although it is oil proof, waterproof and tough, you cannot spill xylene, toluene, or MEK on it.
    We love it! (and it was only like $65 a gallon and you get great coverage.)
  3. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    What about brake cleaners? they do have a bit of toluene in them...
    Rick
  4. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #4 ramosel, Jul 17, 2011
    Well, I'm leaning towards the polyaspartic polyurea flooring if I can find a dealer with a crew in my area. I've done a few epoxy floors myself (with friends) but the flash time on this polyaspartic stuff is pretty damn short (12-18 min).
    On a side note... I started checking around to find out what seemed to be the way a Ferrari garage should be done, to keep with the Tifosi seal of approval. Keegan tells me he has a flyer from Ferrari about how the dealer garages should be painted so I said sure, lets look at it. He shows up (once I mentioned cold beer) yesterday with the info. Flyer my a$$, it's a whole stinkin' hard cover book in a hard case... and yes, its just for Ferrari to tell the dealers how and where to paint and hang signs.
    Anyway, I scanned the important sections and here is the official paint scheme according to Ferrari. I have about six pages scanned from the book but they are too large to post here. Here is pertinent information. PM me if you'd like more....
    Uncle Dave, we figured we have to road trip it check out your adherance... beers charged for all points off.
    If the dimensions don't show well
    Top red stripe 20 cm
    Yellow stripe 20 cm
    Lower red section 110 cm
    Rick
  5. lndshrk
    lndshrk Formula Junior
    Nov 7, 2003
    753
    SLC, Utah
    Jim Conforti
  6. lndshrk
    Nov 7, 2003
    753
    SLC, Utah
    Jim Conforti
    OK, I'm a dumas - Advacoat
  7. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
  8. pexogoce
    pexogoce Karting
    78
    pexogoce
    I've been researching between the two and still can't decide. I'm planning on getting this professionally done. I do plan on working on my car from time to time, but not just the typical fluid changes. Up to the extent of a full motor swap where the car can be on jacks for weeks. Quotes for both coatings or combination of coatings seem to fall between 1750-1850 for a 2 car garage. Which system would be more durable for my usage?
  9. GTO Joe
    GTO Joe Formula Junior
    997
    Charlotte, NC
    Joseph Troutwine
    I have experience with the two systems mentioned in the original post. When I built a house in AZ in 2006 I used the UCoat-It on my virgin concrete with acid etch and given the hot tire issue it lasted with out any issues for the 9 years I lived there. At the time it was the best stuff available. Four years ago when I did the new concrete floor in my garage here in NC I used the Poly combo mentioned and it is really good but it is tricky to apply. I began by renting a concrete grinder to scarf the surface and then flushed with water to clean. My son and I applied the material with a base coat and then applied the 1/8th sized flakes and let it set for a day followed the next day with the clear. It is very durable and with the flakes it has traction so no problem with slick surface. Please keep in mind the Poly is a chemical name and not a product name. I got my materials from Versatile Building Products and they are a commercial supplier. The materials are good but I will warn their service was terrible so beware of that. They have good instructional articles on their web site. I also had a condo garage while in AZ and it came with a professional installed epoxy with flakes that looked good but came up with brake fluid so that is why I moved to Poly when I did it here in NC. Key is to have another person to help apply given the flash time with the poly if you decide to do it yourself and make sure you buy the shoe spikes for application.
  10. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    After visiting Italy I came home and decided to use Italian porcelain tile. I saw many industrial applications as well as some service shops.
    I visited the local Ferrari dealership last week and saw that their entire shop is porcelain tile as well.
    JCR, 430tdf and THINKFAST like this.
  11. samsaprunoff
    samsaprunoff F1 Rookie
    4,386
    Edmonton, AB Canada
    Sam Saprunoff
    Good day,
    I used an Industrial epoxy paint on my shop floors and I would never use it again given how I used my floors. The epoxy surface looks great and holds up well for general use (about 12 years now). However, when wheeling around heavy items (e.g. steel wheel based casters), the overall pressure on the Epoxy was too much and so in some cases cracking and chipping occurred. Over time it starts to look somewhat battered. However, these areas could be repaired, etc but it is a pain. Another issue is if you do any welding and at times one may need to use to the floor as a welding platform. Welding creates a lot of localized heat, sparks, etc, which affects the surface coating. If I were to do it again, I would only coat those areas that really needed protection from oil, solvents, etc. but keep the main areas as bare concrete and simply ensure that any spills are promptly addressed.
    As I said, it all depends upon your usage and how you plan on using your garage floor and so plan accordingly.
    Cheers,
    Sam
    moysiuan likes this.
  12. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,464
    Osprey, Florida
    Ali E. Haas
    Yup, depends on usage. You can very easily get in big trouble with a floor that is the least bit slick when wet. Big trouble. Then there is durability as mentioned above from shear and hot things as drips from welding. After appropriate prepping my concrete floor was painted with G&C xylene based paint/stain. Nothing fancy but fully intact after 25 years. Everything dripped on it, may leave stains - so to speak - but intact and in perfect shape. It has no thickness to it, just a paint so the concrete is as good as bare when wet and that is so very important.
    Ali
  13. pexogoce
    pexogoce Karting
    78
    pexogoce
    thank you so much for your suggestion
    samsaprunoff likes this.
