430 - Garage Door Opener | FerrariChat
430 Garage Door Opener
Discussion in '360/430' started by Fv81587, Aug 26, 2019.
  1. Fv81587
    Fv81587 Karting
    Aug 18, 2018
    125
    Novi, Mi
    Frank Valeri
    I want to start off by saying thank you to the Fchat member that did this mod a few years ago and posted the idea and pix of integrating a garage door opener into the overhead light trim panel as this was his great idea.
    Over the weekend I got a black small square momentatry switch and installed it in the blank switch bank hole to the left of the steering wheel. I took the circuit board out of the small handheld clicker opener wrapped it in open cell foam and zip tied it up under the dash running the wires to the switch in the switch bank. To connect the switch I just had to remove the switch on the circuit board and solder the pair of wires across each of the 2 sets of holes that had common continuity. A quick continuity measurement tells you which two holes need to be soldered together.
    It works great and is soo much more convienent than having a separate opener in the car.
    kes7u and Flyingbrick242 like this.
  2. Flyingbrick242
    Flyingbrick242 Formula Junior
    656
    Northern AZ.
    Cool idea well done!...I've been kicking around the idea of finding a rear view mirror similar to the one in the F430 that has home link buttons built in.
    Have not done much research but Im sure I'm not the only one who has thought of this...it all beats having the garage remote laying in the vehicle.
  3. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,204
    Shorewood, MN
    Kevin
    Excellent idea! Just out of curiosity. Are there any switches available that resemble the other 3 switches, but are spring loaded or would similarly function as a garage remote???
    Kevin
    Flyingbrick242 likes this.
  4. tazandjan
    39,007
    Mine with a Homelink system incorporated into the overhead panel in a 575M. Even has the little LED to let you know it is working.
    whatheheck and Bob in Texas like this.
  5. Neil A
    Neil A Karting
    Oct 11, 2011
    54
    Edinburgh, UK
    Nice work I plan on doing the same in my 360 , I did this mod to my old 996 turbo using a targa roof switch to keep it looking factory as the symbol on the switch resembled a door opening .
    On the ferrari the closest symbol I could find to use would be a glovebox switch.
    kes7u likes this.
  6. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,204
    Shorewood, MN
    Kevin
    Excellent!! Can you please keep us updated when you do this? Particularly as it pertains to the wiring. I can likely do this if I see it, but it is beyond me to figure it out. Thank you!
    Kevin
  7. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    kes7u likes this.
  8. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,204
    Shorewood, MN
    Kevin
  9. Fv81587
    Fv81587 Karting
    Aug 18, 2018
    125
    Novi, Mi
    Frank Valeri
    That's a great idea Neil to reuse the glove box switch. I may have to update my little black button. We'll see if I can find that switch online, if so I'm in. I'm sure the dealer wants like $1000 for it if they can even get it so Im not going there.
  10. Neil A
    Neil A Karting
    Oct 11, 2011
    54
    Edinburgh, UK
    I bought a switch yesterday on ebay for £34 so when it arrives I will look out a spare door remote and solder in some jumper wires.
    I guess the switch will have to go under the cover by the fuel flap, bonnet release as I dont have a blank on the dash panel.
  11. LorenzoR
    LorenzoR F1 Rookie
    Heres another idea, remove the icon and flip it upside down. Looks like a door opening to me. This is what ill do
    whatheheck likes this.
  12. Fv81587
    Fv81587 Karting
    Aug 18, 2018
    125
    Novi, Mi
    Frank Valeri
    Another great idea - it looks just like an old style swing open garage door. I'll go online and look for a used switch today.
  13. LorenzoR
    LorenzoR F1 Rookie
  14. Neil A
    Neil A Karting
    Oct 11, 2011
    54
    Edinburgh, UK
    Carried out this mod today fairly simple , worst part was trying to un solder the switch from my door remote.
    As I have fitted a carbon cup holder where the ashtray was I used the illumination feed for the old lighter so the switch lights up aswell.
    I secured my remove under the cup holder so it's easy in the future if I need to change the battery.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  15. Flyingbrick242
    656
    Northern AZ.
  16. gobuffs2002
    gobuffs2002 Karting
    Aug 7, 2010
    242
    Colorado
    I'd love to hear what you did. Sounds interesting and a great replacement for the simple rear view mirror.
  17. LorenzoR
    LorenzoR F1 Rookie
    My garage door opener went bad so I bought and installed a new one. So now since my old remote that i hooked up in the 430 wont work I have to make a new one. Not sure if I can do it now tho see pics. There's no soldering points on the new one. Any ideas are appreciated
  18. f4udriver
    f4udriver Formula Junior
    Feb 1, 2012
    297
    Central Illinois
    Mike G
    Need to see the other side of the circuit board. But I would assume the red button is the one that needs hooked up. If the black one on the left has wires soldered on the back, then that is it.
    Alternately, usually you can take the old receiver and install it on the new opener.
  19. LorenzoR
    LorenzoR F1 Rookie
    Alternately, usually you can take the old receiver and install it on the new opener.[/QUOTE] i'm not sure what you mean by that. if the old receiver won't pair up to the new garage door opener , what good does that do maybe i'm missing something
  20. Qavion
    Qavion F1 World Champ
    13,806
    Ian Riddell
    How did you know how to hook up the old remote?
    Assuming the Ferrari switch doesn't attach to the car in any way, you'd just have to wire the Ferrari switch in parallel with the "S4" microswitch. Just follow the wiring (tracks) from the microswitch to the nearest solder points. We'd need shots of the back of the board.
    Does the microswitch have 4 contacts? If so, you'd have to remove the old microswitch from the board (taking not of the orientation) and figure out what the four contacts do.
    Do you know what made the old one fail?
  21. LorenzoR
    LorenzoR F1 Rookie
    Well, I think I figured it out, but what you're looking at in previous pic is the front on both of the circuit boards. This picture here is the back of the boards and as you can see on the back of it where I connected the wires on the old one. The new one doesn't have anywhere to solder to. so I took a chance and soldered to the front and it worked. i hope I got it soldered good enough.... My original garage door opener was seventeen years old so it's seen it's day.
    Qavion likes this.
  22. LorenzoR
    LorenzoR F1 Rookie
    Here's the front of it where I soldered the new wires to. the soldering points were much smaller for sure. I was a little leery of doing it.
  23. LorenzoR
    LorenzoR F1 Rookie
    so the white wire came off along with the solder point. I can still use the same block(sw4) solder points that are at 10 and 4 oclock... Other than messing with the red button block.This would be my last chance.
  24. LorenzoR
    LorenzoR F1 Rookie
    sw4 will still work. if I attach at the 10 and 4 o'clock points it will work. Maybe jb weld?
