Fuse for Dash Backlighting and Spot Light | FerrariChat
Discussion in '360/430' started by keitmoody, May 25, 2022.
  1. keitmoody
    keitmoody Rookie
    Jul 2, 2021
    11
    Kansas City
    Keith Moody
    Can anyone identify for me which fuse number per the owners manual (see pics attached) operate the backlighting for the dash (tach and speedo) as well as the Spot Light? The Guage needles eluminate but not the faces. And the Interior Roof Light works but the Spot light does not (the bulb is good). Thank you for the help. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Qavion
    Qavion F1 World Champ
    13,805
    Ian Riddell
    Can you confirm that your (exterior) sidelights are working and the "sidelight on" symbol is illuminating on your dash?
    There is no specific fuse for instrument cluster lighting. The instrument lighting uses instrument cluster general power (ignition key and live battery power). The internal lighting is triggered by an earth (ground) on a pin on one of the instrument cluster backplugs. When you put on your sidelights using the column stalk switch, this puts an earth on the pin. An earth on the pin also illuminates the sidelight symbol.
    If the sidelight symbol is illuminating, then most likely there is an instrument cluster internal fault (a known problem). Some folks on the forum may be able to help with the repair of the cluster.
    The spotlight is a different issue. Your spotlight, interior light and clock (on the Modena) all use the same power, so it sounds like you have a light module internal problem. Perhaps the switch is faulty. Check the wiring inside the light assembly. The red wire is live battery power.
    Try cleaning the switch contacts. They don't look too difficult to get to.
  3. keitmoody
    keitmoody Rookie
    Jul 2, 2021
    11
    Kansas City
    Keith Moody
    Thank you for the insights. The side lights and symbol are working. Do you have to remove the dash to get to the instrument back light?
  4. Qavion
    13,805
    Ian Riddell
    You'll have to remove the instrument binnacle, not the whole dash. It's not a matter of changing bulbs, but changing either the electroluminescent panel or fixing the power supply. See this thread:
    https://www.ferrarichat.com/forum/posts/144445991/
    See this advertisement:
    https://www.ebay.com/itm/Ferrari-360-F131-Dashboard-Backlight-Instrument-Panel-Dial-and-Gauges-for-Dash/233203448720?
    The forum should have plenty of message threads on how to remove the binnacle
    e.g. https://www.ferrarichat.com/forum/posts/137266326/
  5. keitmoody
    keitmoody Rookie
    Jul 2, 2021
    11
    Kansas City
    Keith Moody
    Thank you for sharing!
    Qavion likes this.
