360 - Fuel test port schrader valve too short - not engaging ? | FerrariChat
360 Fuel test port schrader valve too short - not engaging ?
Discussion in '360/430' started by fotostars, May 3, 2020.
  1. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    Is this just me? I just wanted to use my standard fuel gauge to check on the health of my fuel pumps.
    I released the pressure on the rail with a screw driver pushing on the valve. Letting fuel out in a rag.
    Then screw in my trusted fuel pressure gauge. Start the car. -> no reading.
    Puzzled :( maybe my gauge is faulty. Go to my Spec Miata test port. Release pressure with a screw driver. Screw the gauge, start the engine and it reads the expected 36psi.
    The only explanation I have is that the core is more recessed on the 360 and the pin on my gauge adaptor is not long enough to push on the valve to open it. It’s actually pretty obvious comparing both.
    Any thoughts or experience here? Short of taking the core out and make more of a mess when taking it out and disconnecting the gauge after pressure is back.
    The 360:
    What I have on the Miata:
  2. 24000rpm
    24000rpm F1 Rookie
    change the pressure tester. mine works just fine
  3. hessank
    hessank Formula 3
    1,867
    Canada, Florida
    Fred
    My Tester works great too. Never a problem.
    As a matter of fact I carry it around for emerg testing on long trips just in case.
  4. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,822
    Memphis, TN
    The easy answer would be to grind down the tip of your tester so it has a shorter reach. The other option would be to make or buy an extension, like they have on big rig trucks. You can buy them for a few bucks at any auto parts store.
  5. fotostars
    Feb 6, 2015
    345
    Bay Area
    What brand/model works for you guys?
  6. fotostars
    Feb 6, 2015
    345
    Bay Area
    I think my problem is the opposite. The tip of the tester appears to be too short.
  7. fotostars
    Feb 6, 2015
    345
    Bay Area
    Ok. Just to close on this. The O’Reilly “loan-a-tool” worked well.
    Measured 50psi at Idle, 40psi after 1h30 rest. Both banks the same.
    Well within specs according to WSM.
    Anthony 360 F1 likes this.
  8. fatbillybob
    Aug 10, 2002
    28,557
    socal
    Buy new shrader valve core high quality for fuel. Go ask parts guy at Napa autoparts. Unscrew with valve core tool replace new at right level just finger snug to hold seat. If you don't know what that feels like have a pro do that. Now your gauge should work fine
