Fuel Tank - Draining | FerrariChat
Discussion in 'Boxers/TR/M' started by vincenzo, Dec 21, 2017.
  1. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Image Unavailable, Please Login While trying to snake a fuel siphon hose down the main filler or down the overflow nipples at the tank, my hose appears to hit a snag rather than an easy plunge to the tank bottom.
    Are there any screens or baffles or other structures inside of these ‘90 TR (USA) tanks?
    Any other easy ways to get “most” of the fuel out before pulling the plug to change out the crossover/pump hoses?
    Thanks in Advance,
    Merry Christmas,
    Vincenzo
    PS: The engine STILL out of the car!
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    Just run the factory fuel pumps to pump the fuel out of the tanks. You just have to jump the 30 and 87 terminals at the pump relay socket in the front fuse box to activate each pump (The pin designations are market on the relay). You don't need to turn the key on as the 30 terminal is powered all the time. Stop the pump as soon as the fuel starts to run low. It is not good for the pump to run with no fuel going through it. Connect hoses to the outlets of the fuel filters and route them into your catch container.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,395
    romano schwabel
    just loosen the center hose between the 2 tanks
    Melvok likes this.
  4. Steve Magnusson
    26,504
    #4 Steve Magnusson, Dec 22, 2017
    +1
    That way you can take it out in manageable-sized small chunks (like 1/2~1 gallon) into a small opening container for transfer to another car, if it's fresh, or to another more permanent (and safe) container for later disposal. Gasoline is really "thin", and rushes out of a drain plug opening really fast -- nor do you want more than a litre, or so, in a drain pan with a large exposed surface area.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    Taking out the drain plug works only if you have a large (25+ Gallon) catch container that has a large funnel with anti-splash foam. The fuel rushes out very quickly and can make a large dangerous mess if you don't have such a set-up. Most people and shops don't.
  6. fatbillybob
    Aug 10, 2002
    28,538
    socal
    Working with gas is dangerous. Make sure you don't have things around that can start fire like a old bulb style shop light dropped on the ground to ignite spilled gas. I always think about how far my job will go and run fuel out the rail via hot wired fuel pumps. It is safest and most controlled. You have to use more careful thought if engine out already. If your project has taken more time than you thought and you worry about old gas as the reason to drain the tank don't worry. Old gas burns. Unintentionally, I once had gas in a fuel injected mondial cab. for 2 years. I added some new gas put a new battery in and started the car. I drove it home for the Major. The dusty car with 2 year old gas ran fine.
  7. ago car nut
    ago car nut F1 Veteran
    5,462
    Madison Ohio
    David A.
    One cup of gasoline can do as much damage as dynamite!!! You see guys starting old cars by dumping gas from a container down the carb while starting! Very bad. A guy was doing this and the engine backfired and burned him severely.
  8. turbo-joe
    Apr 6, 2008
    9,395
    romano schwabel
    if you handle carefully nothing can happen
    Melvok likes this.
  9. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    If your up on a lift and there is only a few gallons shouldn't be a problem draining from the drain plug. I drained about 12 gallons from my tank using two 7 gal jugs and a large funnel but it took 2 of us to do a quick transition to the other jug without spinning a drop.
  10. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    I just pumped the fuel out of a 3/4 full Testarossa during an engine out service. The fuel was seven years old and smelled terrible. I powered up the left side fuel pump by jumping the relay in the fusebox as previously described. I took the inlet fitting out of the left side fuel filter and put a hose over the threaded and ran it into a drum. It took about ten minutes for the one pump to pump the fuel out. I then tried to run the right pump, but no fuel came out. I then removed the fuel drain plug on the bottom of the cross-over pipe and only a cup of fuel came out. So just using the regular pump will get almost all of the fuel out no fuss, no mess or spillage.
  11. ago car nut
    5,462
    Madison Ohio
    David A.
    When I changed the fuel pump, and crossover hoses on my TR, I also removed the small fuel tank strainers before the pumps in the tanks. Mine were clean. Worth a look!
    Melvok likes this.
  12. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Thanks to all.
    Eventually, the hose was snaked down the main filler. Apparently it was just hanging up on the two intermediate coupling hoses on the filler neck.
    The tanks are now completely dry by way of siphon. Presumably, there is another 1/2 gallon or so in the pump system etc.
    Since the engine is out and the upgraded fuse box not yet reinstalled, I’ll likely drain the final bits out rather than pump.
    Thanks again,
    MERRY CHRISTMAS!
  13. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,243
    Mel
    Merry Xmas to you too Vince !
    Any spectaculair repairs to do next to the usual EO ?
    You did the diff last time if I recall correct ?
