Fuel System Priming | FerrariChat
Fuel System Priming
Discussion in 'Vintage (thru 365 GTC4)' started by ehs308, Jul 13, 2014.
  1. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Looking for some procedural guidance as to how to properly prime the fuel system on my 275GTB/2. The system has been refurbished including all new hoses from the tank to the carburetors and rebuilt fuel pressure regulator and Fispa mechanical fuel pump(discussed in a previous thread on this forum). Is this done by running the electric fuel pump in conjunction with the mechanical pump or by itself until fuel reaches the carburetors and is there any bleeding of the system required and if so, at what junction in the fuel system should this be done? Specifically concerned about how much time I might need to run the electrical fuel pump and/or crank the engine before the fuel system is flowing fuel and pressurized?
    Have never rebuilt this system before now and any assistance will be much appreciated.
    Ed
  2. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: Nothing special is needed. Just fill the carbs with the electric pump as usual for a cold start. Start car with the electric pump running for the first 30 seconds or so to give the mechanical pump time to pull fuel down the line and pump it to the carbs, then turn off the electric as usual. Car should then be fine.
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: Just reread your post and realized you had replaced ALL the lines from the tank to the carbs. You still should be able to prime the system using the electric pump. You can hear the difference in "tone" with the electric pump when it starts to pull fuel. If it never slows down or changes the "tone" of the clicks, then you may need to stick the nozzle of your air compressor air gun into the tank filler (sealed by a rag) and give it a few "shots" of air while the pump is running. That is usually enough added pressure to help prime the electric. Once the electric starts to pull fuel, you are on your way.
  4. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Just the input I was looking for DWR46. Many thanks to you. I made one attempt at priming the system before my original post and was a bit concerned when the pump did not slow down nor change its' "tone" of clicks as you noted. Better to ask than to continually run the electric pump and risk damaging it. One other item I failed to mention in my original post was that when changing out the fuel hose from the top of the tank to the fuel filter housing, there was no filter attached to the bottom of the fuel pick up tube when I removed it from the tank. I don't believe it fell into the tank and I used a boroscope to search the empty tank but to no avail. I plan to replace this filter before using the car but at the time I couldn't help but wonder if it was more than just a filter and might have had something to do with my fuel system failing to prime. Thanks again and I'll post my results.
  5. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,075
    San Francisco Area
    John Vardanian
    #5 John Vardanian, Jul 13, 2014
    Hi Ed, Dyke, this happened to me once when I decided to remove and clean the entire Fispa pump along with the filter canister. When I reinstalled the assembly and turned on the pump I expected the pump to finally go from rapid rattle to slow click, but it never happened. The trick is you need to manually prime the unit; i.e., fill the filter canister with fuel, then turn on the pump.
    You can do this two ways, (1) if the unit is already installed on the car, remove the canister reservoir and fill it on the bench then offer it up to the canister lid and tighten up the through bolt, or (2) tighten everything up then use the filler plug the manufacturer has provided. Right there is the filler plug. Good luck.
    john
  6. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Many thanks for your advice John. I gave Dyke's method a shot first, and sure enough, the pump returned to what would be considered normal audible clicks and then slowed. I switched it off and then checked every fuel fitting connection for leakage as everything had been renewed (new hoses,replated fittings and new copper and fiber washers) and I was sure I would find something weeping fuel. Fortunately, none of the more difficult to access connections were wet/leaking and I snugged up those few that were moist and the engine fired right up. Let it idle for a minute or so on just the fuel in the carbs and the mechanical pump (electric pump switched off) until the most forward carburetor began to starve for fuel. Noted the glass bowl on the pressure regulator was only about a quarter full and I'm surmising my phenolic spacer is a bit to thick preventing the mechanical pump from creating adequate enough fuel pressure to feed the carburetors. Step one was to get fuel flowing and the engine running. Will now move on to the procedures discussed under the thread titled Fispa Mechanical Fuel Pump and will follow up in that thread once I've got the pump running properly. Many thanks for your guidance.
    Ed
  7. John Vardanian
    Jul 1, 2004
    3,075
    San Francisco Area
    John Vardanian
    Thanks Ed, good to hear it worked out.
    Nice trick, pressurizing the tank...
    john
  8. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: Go ahead and run the car for a longer period on the electric pump if you want before checking the mechanical. As you have done, keep an eye on the glass bowl to see what the mechanical pump is doing. It may take the mechanical pump a little while to pull fuel all the way from the main filter junction. As long as I am giving away trade secrets, I always use a light smear of Locktite 518 on the fiber or copper washers as I assemble the fuel lines. never had a leak since I started using it over 30 years ago. It really is the next best thing since chocolate milk!!
  9. lancia
    lancia Formula Junior
    Jan 18, 2004
    563
    Dyke, Do you use Locktite 518 on the threads of the Salvia fittings when winding them into the special yellow wire-wrapped fuel line? Thanks, Chris
  10. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Dyke: Thanks again for your most helpful assistance. I'll run the car on the electric pump for awhile as you suggest. I noticed when I first ran the engine, it began to stall shortly after I switched off the electric pump, confirming what you've noted; that the mechanical pump hadn't started to pull fuel from the main filter junction. Locktite 518 sounds like the ticket for sealing the fiber and copper washers. Thanks for sharing that as well.
    Ed
  11. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    lancia: Yes, 518 is a flange, thread or gasket sealant.
  12. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Ran the engine at idle for about 5 minutes with the electric pump running as Dyke had suggested, keeping an eye on the fuel level in the glass bowl. The level dropped fairly quickly to about 20% full, and with the exception of an occasional dribble of fuel into the bowl, the level never rose. The engine eventually stalled even though I kept the electric pump running. It would appear that I'm getting minimal to no fuel pressure from the mechanical pump and I'm a bit baffled why the electric pump alone wouldn't keep the engine running. Attempted to re-fire the engine after giving everything a once over and noted that the electric fuel pump is clicking constantly and rapidly, just as it did before I employed Dyke's suggestion to inject compressed air through the tank filler neck to prime the system. The engine did not re- start and I'm thinking will require an air injection again in order to prime and fire. Thinking I may have multiple issues to resolve not limited to what may be a faulty mechanical fuel pump and potential blockage/restriction (not likely) somewhere in the system. Will continue to investigate and follow up.
  13. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: You may have an air leak in the suction line from the tank pickup to the electric pump. You may have to reseal (with 518) ALL the washers in the suction side of the line. Also carefully inspect the pickup tube in the tank for cracks that would let air into the line. If you have a suction leak, this will effect the mechanical pump also.
  14. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Dyke: Picked up a tube of 518 today and will carefully inspect everything and reseal all the washers on the suction side of the system. I looked the pickup tube over closely when I changed out the hose from the tank to the rear filter housing and other than the missing filter at the end of the tube, it appeared to be in good shape with no cracks. I also noticed a slight fuel weep around the tank hose banjo fitting that is secured by the pickup tube. Quite possibly enough of a leak to create the problem you are referring to. Thanks again for your time and advice and I'll follow up with my results.
    Ed
  15. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,575
    Grant
    Ed.
    After the first long run and engine has got hot, and then cooled down, ie the next morning after the run, re check all the fittings for leaks as a precaution.
  16. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Disassembled,inspected and then reassembled all connections on the suction side of the electric pump utilizing new copper washers and a smear of Loctite 518 as recommended by Dyke. Electric pump primed on its' own and did not require assistance via a shot of compressed air as it had before. Several constant clicks from the pump,then slowing as it always has. Engine fired right up, the pressure regulator glass bowl filled with fuel and the mechanical pump took over, running the engine for several minutes without issue. Everything appears to be functioning as it should and I think Dyke's diagnosis of an air leak on the suction side of the system was spot on. Thanks again for your assistance. Although the mechanical pump appears to be operating properly I will move on to measuring the fuel pressure coming from it, making any necessary adjustments and post my results under the thread entitled Fispa Mechanical Fuel Pump.
    Thanks for your great advice Wheels1 as well. Close to getting back on the road and will certainly do as you suggest after my first long run.
  17. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: I would caution AGAINST retightening any fitting that you used 518 to seal. Once the 518 has set up, if you move the fitting, you will break the seal. I did not want to make an issue of this with Wheels1, and if you used NO sealant on the connections, his method will be fine, but once a sealant has setup and sealed the fitting, DO NOT disturb it.
  18. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    Thanks Dyke for verifying this. I thought that might be the case when I was checking each fuel connection after allowing some time for the sealant to set up before running the engine. I could tell from the appearance and texture of the cured excess 518 that had squeezed out that it would not be wise to tighten any weeping fittings where I had used 518 for the reason you suggest. As such, I left everything alone and ran the engine. Located a fuel pick up tube filter which is on its' way here. I plan to use new crush washers and sealant when I install the filter on the tube and back into the tank. Should I find anything weeping in the future that was sealed with 518,it will be disassembled and redone. Thank you again for your much appreciated assistance.
    Ed
  19. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Ed: 518 is anaerobic, so it cures in the "lack" of air. Any excess that comes out around the fitting will remain soft and can be wiped away at any time. Even years later excess will still be easily wiped away.
  20. John Vardanian
    Jul 1, 2004
    3,075
    San Francisco Area
    John Vardanian
    Hi Dyke, does this re-tightening issue also apply to flanges, like for instance an oil pan lid gasket?
    I had removed the oil pan lid and reinstalled it with 518 for the first time, instead of RTV. The nuts were tightened to 5lbs as usual. After a drive I rechecked the nuts at 5lbs and ended up having to turn each nut about another 1/8 turn. This would happen with the RTV too, where nuts had to be re-tightened--sometimes more than once. But what bothered me as I was tightening the nuts, there was evidence of slight oil weeping from the joints from the brief drive. RTV never did this. So, I am questioning whether I should use 518 on the cam cover gaskets after the next valve adjustment.
    john
  21. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    John: The retightening concerns would not apply to flanges, as you are not 'breaking" the seal as you would by turning the banjo bolt against the copper or fiber washer in a fuel line fitting. I have generally used RTV on valve cover gaskets as it fills large gaps near the front and rear cam cover oil seals. 518 should have worked fine for an oil pan.
  22. John Vardanian
    Jul 1, 2004
    3,075
    San Francisco Area
    John Vardanian
    Thanks Dyke, I thought that would be the case with 518. I'll keep toquing the oil pan nuts see if the weeping will stop.
    john
  23. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,634
    NJ
    Peter
    There is great information in this thread. Is it standard practice to need 518 on the copper washers? I noticed my car started to have fuel starvation on long drives (an hour or more) after I replaced incorrect fiber washers with the correct copper washers. I thought it was vapor lock, but from this thread I now realize there is weeping around the copper washers, so it sounds like 518 will fix this.
  24. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,025
    Peter: If your car is a 330, the fiber washers are original. I discovered 518 about 25 years ago, and have used it ever since. Otherwise, you are always fighting fuel system seepage. Locktite 515 is the same product, except it is NOT instant curing, so 515 takes a few hours to cure. I prefer the 518, as I am usually short on patience.
  25. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,634
    NJ
    Peter
    Thanks Dyke. It's interesting to learn that 330's came with fiber washers. The ones that were on my car looked quite large relative to the fitting, so I suspect they weren't correct even though they were fiber. I wouldn't have noticed them at all except that they looked too large. I have more copper washers, so I will probably put those on with 518 (unless you feel it's worthwhile to for me to find the more correct fiber washers).
