348 - Fuel pump R&R and some supply chain woes | Page 3 | FerrariChat
348 Fuel pump R&R and some supply chain woes
Discussion in '348/355' started by steved033, Jan 3, 2021.
  1. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    I hear they swelled, but less than the existing. If he was measuring diameter, it was about 7%. I haven't heard since.
    sjd
  2. Ricambi America
    Sponsor Owner
    It is still in the tank of fuel. I have been measuring it every 3 days.
    Ferraripilot likes this.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I suspect the allowable amount of swelling is near 0?
  4. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    A 100% viton part will swell nearly zero, and will retain its structure.
    sjd
  5. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    Ferraripilot, ernie, QSA and 3 others like this.
  6. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    I didn't disconnect the pump from the hoses, so it made it super fiddly, but the pumps went right together. the bottom ring was a little tighter on the OD as the viton pad between the plastic and the pump pushed it open at the bottom:
    here's a view with both rings on:
    the bottom screen going on. The second one I put the top on first then the bottom, and it went a little easier. Some lube might have helped too, the sharp edge on the viton hung up going into the cup on both parts.
    Final fit together, and the return re-molded and spaced properly. I ziptied the two lines to keep the return loop from waving around.
    I ran out of time to fuel it and fire it up, as I changed out FPRs, too.
    sjd
  7. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    #57 QSA, Feb 10, 2021
  8. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    It's a standard grade of FKM. Feels like Durometer 75. Seems pretty close to the mcmaster test pieces I made myself.
    I have a test piece of it in a jar of fuel with a sample of nylon from the clamp. There's been no swell and no change so far, per your document, it'll take 168 hours...I can't simulate the 40C. I'll check it from time to time and refresh the fuel occassionally. I'll post if there are any issues, this is an engineering experiment.
    Viton Type F seems to be the best for fully submerged parts. Type F is by far the best, and from my reading the hardest durometer and most durable. Did I request anything specific? no. It's a good solution, there are a couple things that I'd make changes to, and I have a supplier that's willing to make a few sets with type F.
    As a note, the grey electrical covers are swollen, but haven't shown any cracks or tears, and it's been two months.
    sjd
    QSA and ATLdoghouse like this.
  9. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    Runs.
    Drives.
    There's no different noise from the pumps. (I was worried that there would be less damping with the new setup and more pump noise....but nope)
    sjd
  10. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    958
    ^^^congrats....nice work
    steved033 likes this.
  11. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    Congrats. Now, are you gonna sell a kit? Pretty-please?
    steved033 and QSA like this.
  12. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    We can talk. :)
    I need to make a couple small tweaks to the model, and it's good to go. I have to do some analysis (basically looking at all the cars that use or could be converted), so that it's not absurdly expensive, I also don't want to be sitting on parts for the next 30 years.
    If you're interested, PM me, we can talk.
    sjd
  13. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,839
    Atlanta
    John!
    I like that it is a pretty simply and effective solution. No need to get overly complicated. Great stuff Steve
  14. steved033
    Apr 12, 2017
    10,041
    Atlanta, GA
    Steve D.
    Timeline/update:
    2021:
    1/15: test parts went in fuel
    2/10: parts went in tank. fresh FPRs. I was so out of gas, I had to go get a 5 gallon can filled. I also had to do an ECU reset with the new FPRs in there.
    2/12: fuel in test jar refreshed. still no change in nylon or viton parts.
    2/15: added 7 gallons of Shell 93 (same as test jar)
    3/1. +100 miles on the car. no hiccups. I think it runs better than it had.
    More to come.
    If you're interested in this solution, PM me, The big hurdle is having the viton cut. I need to do more than 1's and 2's.
    sjd
  15. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    Please mark me down for a 355 kit.
