Fuel pressure test port & the tester connection problem | FerrariChat
Discussion in '360/430' started by 24000rpm, Dec 23, 2018.
  1. 24000rpm
    24000rpm F1 Rookie
    so I bought this fuel pressure gauge with the connector like the pic below
    it screws into the test port on the fuel rail perfectly.
    But there's no pressure when I start the car or put key to "on" position.
    after unscrew the connector, i see no fuel residue or smell around the area.
    Is it possible the connector's nipple is too short to touch the nipple on the test port valve?
    what do you guys use?
    mwstewart likes this.
  2. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    #2 hessank, Dec 24, 2018
    Maybe my old eyes are tired but does yours have a metal pip in center to depress the schrader valve? If the schrader valve is not depressed no fuel will be released, similar to a bicycle tire valve
    Take a look at mine
  3. 24000rpm
    24000rpm F1 Rookie
    mine does have a metal thing to depress the schrader valve.
    Maybe it is way too withdrawn inside so it doesn't touch it?
    Would you tell me what make/model is your gauge?
  4. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Merry Christmas!
    This (no affiliation to Amazon)
    I get very accurate readings.
    For the 360 I've removed all the 'extra stuff' from the pouch as none are needed. The long drain tube makes it easy not to spill fuel in the engine bay after testing.
    I'm 360 Canuck likes this.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    You must be cranking the engine over (trying to start it) or have the engine running in order to have the fuel pumps running to check fuel pressure. If you want to check pressure with the engine off, you have to jump pins 30 and 87 of the fuel pump relay sockets.
  6. USMCS6
    USMCS6 F1 Rookie
    4,078
    Arlington VA and Daytona Fl
    Elliot
    Also you can "unscrew" the center depressor with a pair of needle nose pliers if its not hitting the core. Only go a small amount at a time.
  7. 24000rpm
    24000rpm F1 Rookie
    THAT'S THE TICKET!
    i use a long needle plyer to unscrew the nipple , and voila! it works and i got pressure, but i guess i unscrewed it too much and when I start the car, gas was oozing out of the connection area!
  8. USMCS6
    USMCS6 F1 Rookie
    4,078
    Elliot
    Hopefully you can just replace the core. That is easy. It only takes 1/8th of a turn on the depressor.
  9. 24000rpm
    24000rpm F1 Rookie
    i think it is an adjustment issue, it isn't broken, i just unscrewed it too much
  10. 24000rpm
    24000rpm F1 Rookie
    report: everything good. just mess with the gauge nipple's height by screwing and unscrewing it, u'll be good
    but it raised one more problem
    i always tested the fuel pressure when the car is cold. That is fearing if fuel spills it would catch fire.
    now, after I tested the fuel pressure, there's no way to not to leak any fuel, sometimes a lot.
    Another fact is that you have to start the car to have fuel pressure. Even if for 30 seconds of engine running, the header will be hot enough to be concerned.
    How do you guys avoid that risk? by unscrew the fuel pressure gauge after the car went cold? That's the only way i can think of. Any other ways?
  11. Rifledriver
    36,745
    Good gauges have a way to bleed off the fuel into a container on the side. Thats what the clear hose in the photo is for.
  12. 24000rpm
    24000rpm F1 Rookie
    i see! thank you!
  13. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    898
    S La
    Why are you testing the fuel pressure to begin with? Out of curiosity. Problem with the engine?
  14. 24000rpm
    24000rpm F1 Rookie
    CS cold start misfire.
    check everything you can ever imagine( for 2 years), except:
    1. fuel pressure
    2. wiring integrity
    3. timing
    4. compression/ leakdown
    con
  15. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Look at the 2 pictures I posted above (#2 and #4). There is a release push valve and a lengthy tube to bleed off the fuel to a container away from the engine
