Fuel gauge problem and range
Discussion in '458 Italia/488/F8' started by First, Jan 17, 2011.
  1. First
    First Rookie
    Feb 14, 2010
    33
    Does any 458 owners out there with problems with the digitial fuel gauge? Ever since new, my car has never been on full gas tank. Or so I was told by the fuel gauge by 3 bars. I fill up the car to full and the filler always stop. I tried overfilling it and sure enough gas starts to overflow so I stop. But when I get back on the car, even with the gas tank full, the fuel gauge is only reporting 3 yellow bars from full.
    Now I'm so confused if my gas tank is ever full! But the gas filler refuses to fill anymuch more. I am able to get around 85litres of fuel in. Is it suppose to be more?
    And with average aceleration and enthusiastic drives, I am able to get around 300km/190miles only. Is that normal or way below the actual 458 driving range that some of you are getting a lot more out of it?
    Gosh this is weird.
  2. jim g
    jim g Formula Junior
    Jan 8, 2003
    887
    Waverly, Pa.
    Jim Gress
    My 360 and 430 did the same thing but I haven't noticed it yet on my 458.
  3. Lesia44
    Lesia44 F1 World Champ
    17,675
    I've had that on the 360, but not on the 430.
  4. First
    First Rookie
    Feb 14, 2010
    33
    So no one else with 458 have similar problems? I even tried resetting the ecu by unplugging the car battery. Still the same.
  5. GrahamPM
    GrahamPM Karting
    Jan 24, 2013
    113
    Cheshire
    Resurrecting and old thread here; my recently acquired 458 has this problem - brimming the tank I can not illuminate the last 'bar' on the gauge.
    Is this normally? I'm getting around 200 miles before RED, and circa 70 litres of fuel.
    BTW - using 95RON fuel (usually Shell) any advantage on using Super V-Power 98RON?
    My AMG is quite specific about always using Super only
    Graham
  6. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
    I have exactly the same problem with my 2011 458
    Do you have cure ?
  7. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    That would be a dealer fix I would imagine. This car drinks gas with a passion so I wouldn't feel comfortable having this issue. Let us know how it's resolved. I have not had that issue on my 2014. The guage just moves faster than I expected...lol
  8. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
    I went to my dealer with full tank, he checked the car with the diagnostic tool: fuel level 91%.The dashboard gauge reporting one yellow bar from full, it is normal.
    Maybe level sensor problem inside the tank, but not sure
    For the moment no cure
  9. Zaius
    Zaius Formula Junior
    May 8, 2014
    863
    I can easily do 400+ on a full tank but yes 85liters sounds right.
  10. geochin
    geochin Formula Junior
    Jul 3, 2012
    306
    NJ
    George
    Had the same problem with my 2010 458 and the dealer replaced the sensor and problem solved.
  11. lamarmotte
    lamarmotte Karting
    Feb 5, 2014
    194
    France
    Thank you
  12. alvaro1728
    alvaro1728 Rookie
    Sep 26, 2014
    25
    Which sensor did they replace?
