Fuel Accumulator | FerrariChat
Fuel Accumulator
Discussion in 'Mondial' started by MvT, Oct 6, 2013.
  1. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    #1 MvT, Oct 6, 2013
    Hi guys,
    Yep I have a hot starting problem and it can only be my fuel accumulator at this point having ran all the tests.
    I am looking at a Fuel Accumulator on superformance, but this does not look like the original Bosch one although it they describe it with the original part number 113978. It is not the first time they sent a replacement item. Last time they sent a Fiat sensor instead of the original and tripled the price.
    Did anyone ordered this one by any chance and how does it fit? Or better said.. is it a Bosch or some other brand? It's half the price then a Bosch one that I am looking at.
    Item 5th from down up the page.
    Superformance ferrari dino ferrari v6 ferrari v12 specialists 308 246 206 fiat dino 355 328
    Tijn
  2. Steve Magnusson
    26,512
    I think that that picture is of a later TR accumulator (but maybe they are just using it as a generic accumulator picture).
    Have you eliminated the fuel pump check valve and the seal inside the fuel distributor (that prevents the control pressure, and therefore, the supply pressure from bleeding off after shutoff IIRC)? Usually, if the accumulator is bad, the diaphragm is broken and fuel leaks out the drain fitting -- which is just open to atmosphere on a euro version so is obvious, but on a US version it has a return line to the tank (so if you remove that line, and liquid fuel comes out = bad accumulator).
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #3 MvT, Oct 6, 2013
    that's good info! I was wondering why the drain fitting was closed up! Mine looks like this and... I guess when I take it off it will start leaking since I have the hot starting problem when I bought it. I'll take it off tomorrow and see that it does. I will mind the exhaust manifolds when I do this! :)
    Wondering if this is a good thing to put on the drain fitting when you place a new one? I can imagine you prevent midengine fires doing this.
    I will drop superformance an email on what exactly they are selling.. Many thx Steve!
  4. Steve Magnusson
    26,512
    #4 Steve Magnusson, Oct 6, 2013
    Have to agree with you that that added "plug" is a strong clue that your accumulator does need replacing. No downside to running a line from that drain fitting back into the (upper part) of the fuel tank like on the US version (you want the added line to go into the top of the tank so, if it fails for some reason, fuel won't drain out of the tank via that line) -- but you might need to add a "T" into an existing line as I don't think that there are any unused extra fittings available.
    I believe that your F PN 113978 accumulator is Bosch 0438170004 (the Bosch PN should be stamped into your old accumulator body somewhere to confirm/deny):
  5. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #5 MvT, Oct 7, 2013
    Ok.. it's leaking like crazy when I take off the plug.. I put it back on again until I have a new one. No answer from superformance yet.
  6. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Hi Gents, my unit is open to atmosphere, are you saying that if it fails fuel comes pouring out engine running or not? Cheers, Bell
  7. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Mine already without running the engine, but that is because it was closed up I guess.. I'm a bit scared though if this leaks with a running engine and being so near the exhaust manifold(s).. (I was also missing a nut..)
  8. Bell Bloke
    Dec 6, 2012
    1,839
    So if this rails fuel comes out? Sounds to me that a pipe clear fuel pipe should be returned to the petrol tank, that way if it does fail you can see it. I am quite frankly staggered that this obviously lethal point of failure could be left on any car. Are you guys sure about this? Kind regards, Bell
  9. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #9 MvT, Oct 7, 2013
    I have hope :)
    I followed all the starting problems and I came down on my fuel accumulator or ECU, which I doubt the last is the issue, since the accumulator seems to be failing based on what Steve pointed out.
    http://www.ferrarichat.com/forum/308-328/114514-308-qv-doesnt-start-well-when-warm.html
    I'll let it know when I have placed my new fuel accumulator the coming days and at the same time I'll put on a new check valve on the fuel pump. Till then I just wait for our always friendly smiling postman :)
  10. Steve Magnusson
    26,512
    Absolutely certain -- your hemisphere was slower than the US to mandate safety issues ;)
  11. caterus
    caterus Karting
    Dec 24, 2010
    68
    Oxfordshire, UK
    Tim
    I've been working on the fuel system of my Euro Mondial 3.2 and can confirm that the fuel accumulator has an outlet pipe open to the atmosphere as indicated on the parts diagrams. As Bell says this appears to be a fire hazard if the accumulator fails and fuel is emitted.
    I found that the end junctions of my flexible stainless hoses from the fuel pump to accumulator and accumulator to fuel filter were badly corroded and both hoses needed replacement. The pump to accumulator hose (123022) is still available from ferrari classic parts but I understand the longer accumulator to filter hose (117952) is no longer available and I had to have one specially made up.
  12. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    #12 PV Dirk, Oct 8, 2013
    I'm just pulling this out of the air. I believe the accumulator has a diaphram in it. For proper movement of that diaphram it may need to be open to the atmosphere to allow free movement as designed. If attached to the tank then tank pressure on a hot day may affect drivability, possibly based on accumulator not being able to function as designed. Fuel should never pour out of there unless there is a failure. A failure is unlikely to be catastrophic in nature and if there is a failure one should smell fuel and know to do something with their vehicle. The person who put the hose on there and closed it off is a hack and didn't know what they were doing and should not be working on any car.
    OK, now I need to pull out my injection book and see the inner operation of that piece.
    And remember, there are other things that can leak back there like the fuel lines. The fuel lines are not double wrapped for safety and they will pump fuel all over the engine if there is a failure. There are scarier things back there than the accumulator. I say replace it and forget about it.
  13. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #13 MvT, Oct 8, 2013
    A Ferrari is made to burn.... . . . . .......Tires! :D
    hmmm, but the US versions have a line to the above side of the tank. I need to say that I haven't seen any Mondial fires unlike the Ferrari 458ties. So I guess the chances are minimal when it is out into the open air also keeping in mind that the design is already there on the Mondial 8 if it was too dangerous I assume Ferrari would have changed it for the Euro version as well.
  14. Bell Bloke
    Dec 6, 2012
    1,839
    PV Dirk Quote:
    Mmm I second this, that's just what I was thiking last night.
    I'm gonna vent mine to a safe area of the car but not to the tank.
    I'm currently trying to find an exploded view of one to see how it works
  15. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #15 MvT, Oct 12, 2013
    The only cross section I could find that may be similar is the below. I think the blue arrow is where we have the appendix tube sitting to vent and the diagram #3 could be broken causing it to leak.
    Pitty, Superformance has not answered my email still whether or not the item they are selling was the below item. So I went on and bought one from:
    Drukaccumulator, brandstofdruk 0 438 170 004 van BOSCH - MERCEDES-BENZ, FERRARI
  16. Bell Bloke
    Dec 6, 2012
    1,839
    Ah great, thanks for the diagram, it's just as I thought it would be. So the diaphragm gets a hole in it and you are a dad...I mean you have a fire... ;-)
  17. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Gentlemen, great post. I will change the accumulator in my Mondial 3.2 ASAP. Can't believe it's lasted since August 1988!
    Great info; THANKS!!!
  18. David Lind
    Nov 19, 2008
    2,248
    David Lind
    When I disconnect the lines in and out of my Mondial's accumulator, will high pressure fuel spray out? If so, approx. how much?
    Thanks!
  19. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Not sure.. I can tell you tomorrow or the day after as it looks like GLS is delivering my ordered parts tomorrow. However I expect at least a spoon.. I am also not sure if your tank will leak empty when you remove the line from the fuel pump to your Accumulator (or from your check valve if one is in between.)
    For everyone who has read this post and curious which accumulator Superformance is selling: Got reply from Superformance just before the weekend:
    <Snip>
    Thanks for the enquiry with Superformance
    Yes we do have this part in stock and it does have the same Bosch number on it
    <End Snip>
    Pitty they replied a bit late :(
  20. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Remove your fuel pump fuse, start the engine until it stop by itself and the accumulator should be empty.
  21. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Not much quantity. It is under pressure. IIRC, I put my wrenches in place and then put a rag or paper towel around them and opened it. Good form to always wear safety glasses when working on a car.
    Other suggestion is to make sure all these joints are clean before you open them. Don't need any grit in the system. It may be before the filter but always good precaution, also with replacing the filter, don't need any bits of grit getting directly into the injection machinery.
    And be careful, joints are tight, not overly so but my hand slipped hitting something causing me to leak a bit out of my hand. :D
  22. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,294
    Netherlands
    Steven
    Actually this is a funny but nice discussion. My personal experience with the k- Jetronic ( ovef 30 years)is that hot start issues are rare caused by the fuel accumulator. MvT story seems to confirm: his accumulator is way beyond an initial issue but he only recently had a hot start issue.
    In my experience hot start issues are in most cases caused by leaking injectors. To MtV. Please report back on your results if possible.
  23. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    #23 MvT, Oct 15, 2013
    Just came back from my shed having replaced my fuel accumulator :) Indeed I still have the hot start issue... However, the engine runs much better and is idling waaaaaaaay beyond my dreams now. ... Need to say I actually had the hot start issue from the start when I bought this Mondi, but I didn't work on it yet as I had far more worse issues to fix first.
    I had a look at my injectors recently and replaced 2 of them with new ones as they where just giving me a pee jet... You might be right that these could leak as they are still the first ones that were ever fitted back in '87 from the looks of it. I will replace the rest of the injectors too since they don't cost that much anyway and let you guys know! I would be surpriced if that will not do the trick. I mean how likely is it that it is the ECU? Can you diagnose the ECU btw on this?
    @David: The lines are not under so much pressure. It does leak but as PV Dirk mentioned a towel will do.
    I will follow up on this in 2 or 3 weeks. Need to prepare for my first Ferrari meeting :D
    thx so far guys!
  24. David Lind
    Nov 19, 2008
    2,248
    David Lind
  25. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I came up with an idea to see if an injector is possibly leaking. I guess this is an indication and if you want to know for sure you would need to bring them away to be tested.
    [ame=http://www.youtube.com/watch?v=HHaGGUaWLTo]Injectors leaking test - YouTube[/ame]
    HTH
    Tijn
