Front scrape guards | FerrariChat
Front scrape guards
Discussion in '456/550/575' started by gstudent, Jan 15, 2020.
  1. gstudent
    gstudent Karting
    Sep 12, 2006
    133
    Westlake Village
    Gene
    Who can lead me in the right direction where I can buy the ‘custom fit’ scrape guard for installation under the 575 front spoiler?
    Thanks in advance
  2. tazandjan
    38,083
    Gene- Probably will not do much for you since there is nothing really solid to mount them to. Will actually decrease your ground clearance.
  3. gstudent
    gstudent Karting
    Sep 12, 2006
    133
    Westlake Village
    Gene
    Thinking about it you are right. I believe I have them on my 599 and they help me not get nuts if I scrape but on 575 I may be out of luck.
  4. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    www.cargraphics.com are doing Bilstein coilover lift kits for many different Porsche models. I bet the 456/550/575 Bilstein shocks are the same as are being used on som of the Porsches from the same era. It is worth a try. I will call them and ask. It really would solve the problem.
    gstudent likes this.
  5. tazandjan
    38,083
    Erik- 575s have Sachs shocks, not Bilsteins.
    gstudent and F456M like this.
  6. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    Ok. Thanks for the correction. I actually called and sent email to Cargraphic today. I await their reply. I am going to get a pair of their rear mufflers with a rear mounted vacuum tank and their own bypass system. It can be controlled either by rpm. or throttle position. The original 550 system open up at 4000 rpm. which is way too late.
    pkl03 likes this.
  7. 308 GTB
    308 GTB F1 World Champ
    11,190
    New Jersey
    Barry Wolinsky
    Gene, you need Maranello Skunkworks' Front Lift kit...
  8. tazandjan
    38,083
    Erik- The 550 valves pretty much only opened at WOT, too. The 575M actually starts opening below 3000 rpm at around 65% throttle.
    F456M likes this.
  9. gstudent
    gstudent Karting
    Sep 12, 2006
    133
    Westlake Village
    Gene
    Thanks so much. Can you provide me a web sight for Maranello skunkworks. Can’t seem to find
  10. gstudent
    gstudent Karting
    Sep 12, 2006
    133
    Westlake Village
    Gene
    Can you give me contact info for Maranello Skunkworks?
  11. 308 GTB
    11,190
    New Jersey
    Barry Wolinsky
    PM Cribbj here on FerrariChat.
  12. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    Yes. I see a 458 here quite often and it opens the valves very quickly after he goes over a speed bump at Maybe 2.500 rpm. and 30% throttle. That makes the car more alive and you can have some fun without flooring it... Ferrari probably understood the problem when the 575 were build. Would be fun to be able to start it cold on open flaps too... The 575 is like that?
  13. rokhound
    rokhound Rookie
    Sep 8, 2016
    19
    Sacramento, CA
    Jon Mistchenko
    I have been looking for a solution like this since I damaged the radiator in my 456 when an impact pushed the fiberglass panel upward. This happened at a big compression on a bumpy backroad, so a front lift is not what I'm looking for. Has anybody fabricated a skidplate or something similar for this purpose?
  14. tazandjan
    38,083
    Erik- No, stock the 575M valves are closed at start, unless you fit one of Steve Bisel's kits or one of the other aftermarket kits. Those give you the choice of controlled by ECU or open.
    F456M likes this.
  15. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,665
    Oslo
    Erik
    Maserati Club International made a device for the Biturbos so that it would hit the ground before the oil sump. Plenty of Biturbos ran out of oil as it was normal that after a few years the cooling fins were gradually grinded off by the tarmac... It boltet to the engine mounts If I remember right. Not a bad idea. However, the frame at the front of the Maranellos are not very solid and not made for that purpouse. You just need to find better roads!
  16. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
