Front lens screws | FerrariChat
Front lens screws
Discussion in 'Mondial' started by greatscott73, Apr 17, 2020.
  1. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    Not shown on the drawings at all, local ferrari dealership is your best bet
  3. djs308
    djs308 Formula 3
    1,137
    Long Island, NY
    David S.
    I'm not certain about it, but the long screw looks very similar to the one used for securing the fusebox. If so, check with a company like Ricambi. Table 126, part 14. About 7 bucks. There may be a match elsewhere in the car for the smaller one as well.
  4. ronfrohock
    ronfrohock F1 Rookie
    4,175
    MA
    Ron Frohock
  5. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Geez, where does one go to get screws made? That never occurred to me. Why someone deemed it necessary to turn these things to the point of striping the heads is also beyond me....
  6. FerrariJB
    FerrariJB Karting
    Jun 8, 2019
    69
    Netherlands
    FerrariJB
    make a slot with hacksaw, you can tighten again with a screwdriver. Perhaps a solution for emergency?
  7. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    That is exactly what I was in the process of doing. Thanks to all for the advice.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Using a Phillips screwdriver (or bit) on a Pozidriv screw.
  9. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Yeah, they definitely are Pozidrives. Probably explains how they got mangled by someone with a phillips bit on a power tool.
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    gsfent likes this.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    Fill the head recess with Araldite rapid epoxy , as it starts to harden use a suitable screwdriver end into the epoxy and press in the shape. Once you have it, leave for 24 hours to fully cure. The lens does not need to be overtight so you should get it tight enough. If it does not work you can always scrape it out.
    Other alternative is to get a hex machined onto the head or file it if u r good with a file
    ronfrohock likes this.
  14. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I figure I will contact Red Bay and Eurospares tomorrow and see if they have any laying around. I tried Ferrparts, but no dice there. FYI, if you want to hear someone laugh uncontrollably, call the local dealer and ask them if they have screws for the front of a 33 year old car. I'm not too sure they didn't have to give the guy oxygen before the call was over....
    gsfent likes this.
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    If u really get stuck , send me a drawing and will see if i can knock you a pair up with a flat screw driver slot.
  16. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I appreciate that, but I'm sure I'll get it handled. I cut a slot into the really bad one yesterday and that made it useable until I can find replacements. Thanks again.
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I remember someone saying that the Ferrari dealers sold off their old stuff years ago. However, Algar Ferrari of Philadelphia still has lots to offer, maybe call them?
    Example here is their eBay Store.
    https://www.ebay.com/sch/algarferrari/m.html
  18. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    An easy way is to get the damaged recess filled with solder and then machined flat. Then get a machine shop to mill on a hexagon head,( only a 5 min job with a dividing head ) or you glue a nut to the top and file it on yourself using the nut flat as a guide- it is easy with a good smooth flat file, mind i have many years doing this.
    Looking at the threads, they might not be metric- have you tried running a nut down them as they might be a special unless its the camera angle.
  20. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    I don't have any separately unfortunately. I think someone with a turning lathe will be able to help you
    greatscott73 likes this.
  21. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    I have a lathe but if you look at the thread form i dont think it is metric- that is some special thread as the thread tops are rounded. You would need a sample screw to copy the thread form.
    Do these screw into a nylon bush by any chance ? Or into a Spire Clip.
  22. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    They just thread into the plastic bezel housing. Looks like they were originally self cutting for soft plastic.
  23. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    You see what i mean about the threads, something special and not metric looking at the pics.
    Personally i would machine a hex on the old screw head
  24. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Probably the direction I'm heading, Mike. Thanks for the help
  25. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    Buy a file and do it yourself, easy after the first 40 years practice.
