430 - Front Hood Struts replacement | FerrariChat
430 Front Hood Struts replacement
Discussion in '360/430' started by MKTViper, Dec 14, 2019.
  1. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    The front struts on my F430 work OK, but you can tell they're getting a little weak. I was going to replace them, but can't find the OEM part# for my car, Stabilus 67508100. The replacement is 80136300, but Ricambi only has one.
    Anyone found a suitable alternative?
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I got OEM ones from Eurospares.
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,722
    Just East of Weird
    Bob
    Front Struts...Plural? I’ve only got one on my 08. Interesting.
    Sent from my iPad using Tapatalk Pro
    Manda racing likes this.
  4. KatMan
    KatMan Formula Junior
    498
    Silicon Valley
    Stan K
    My 08 also has only one strut. By coincidence, I just got 80136300 from Ricambi a few days ago. Maybe the early 430 had two struts?
  5. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    Just ordered 2x 6300's from eurospares. Yes, my 06 has two of the previous version. Curious if using 2 of the new version (maybe designed for 1) will be alot more force.
  6. KatMan
    498
    Silicon Valley
    Stan K
    I have a new one and there is a lot more upward force. Two would be overkill.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,916
    Isle of man- uk
    Someone listed these cheaper from the original maker, on here
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    But aren’t there two hinges and mountings for two struts? I don’t think I’d want it to be supported unevenly.
  9. KatMan
    498
    Silicon Valley
    Stan K
    I understand your point, but there is only one on the passenger side.
  10. Bob in Texas
    Apr 23, 2012
    2,722
    Just East of Weird
    Bob
    What Katman said. Only 1 mounting point, passenger side.
  11. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    My 06 has 2 struts, but the older part number. Ordered 2x of the new (more powerful) part numbers from eurospares for $14 a piece.
    Unless it has so much force the hood smacks me in the face everytime I'll keep both attached for balance.
    I'll advise when they come in and get them installed.
  12. Bob in Texas
    Apr 23, 2012
    2,722
    Just East of Weird
    Bob
    Let us know, would ya. I’ve got a replacement but not sure how much pressure I use to remove the socket from the ball. First effort didn’t see it budge.
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I pried the retaining clip with a small screwdriver and it popped off easily. Install the new one by snapping the socket over the ball. The hard part was keeping the hood from falling on me once held up by just one tired strut. Best is to get a buddy to hold it for you.
    As for two struts, I meant one one each side, not two on the passenger side.
  14. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    I'll post a synopsis once they come in and I have them installed.
  15. Bob in Texas
    Apr 23, 2012
    2,722
    Just East of Weird
    Bob
    That would be great. The clips came off easy enough but couldn’t budge the ball out of the socket, both. Guess I’m not pulling hard enough((?)
  16. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    So FINALLY got the struts in the mail from Eurospares. Took about 6 weeks...mistakenly routed through Russia...
    Anyway, installed both of the new ones in about 15min. The front hood easily goes up by itself now once about 1/3 open. I certainly could've gotten by with one old and one new, but installed both the new ones anyway.
    The trick to the clip is to use a tiny flat tip screwdriver and leverage it outwards along the groove. Once the clips have cleared the socket, the strut should pop out with a little force (hold the hood up slightly to take any pressure off). Both the old and new struts use the same pin size.
  17. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,764
    The Low Country
    Dave Steven
    Seeing this was posted in December in Northern VA, let me suggest that struts don't hold up as well during cold weather. Good for you if you are driving your car year round!
  18. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    These are brand new and very strong...not too worried about the cold weather. And yes, as long as the roads are dry and the temps in the 50's, I take her out!
  19. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    I've decided to use only one of the new gas struts for the front lid (part #080136300). Two of the new, much stronger, struts is a bit of overkill. I left the original one on the drivers side and put the new one on the passenger side.
    If anyone's interested in my extra gas strut (the new one), IM me. $30 and I'll ship it to you (CONUS).
  20. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    So, do the newer ones (80136300) fit without mods?
  21. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    Yep. Same pin size. Takes about 5 min to swap out.
    Manda racing and Zed82 like this.
  22. ScottS
    ScottS F1 Rookie
    2,933
    Winter Park
    Scott S
    Old thread but I’ll ask
    Pry the clips off the old and pop the struts out top and bottom with ? Moderate force?
    Do you take the clips out before putting the new ones in or simply pop in and they click? Thanks. The difference between the right amount of force and the wrong can be $$$$$$
    ScottS
  23. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,270
    Bakersfield, Ca
    Mark
    I don’t think I had to remove old clip all the way.
    Same with install I think it just popped on and clicked.
    hardly any force.
    I got my factory strut in a day from Ferrparts.
    I propped up hood with a broom.
  24. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    I would recommend NOT removing the clips, just slide them far enough outward to clear the pin and open up the hole. Use a very thin flat head or metal pick. It's not difficult, but takes a little finesse not to completely pop it off.
    Do this on both sides of the replacement struts first as practice...leaving the clips "outward" so they clear the hole. You can get a better feel for what you're doing without worrying about the hood falling down.
    Once the replacements are "prepped", you can do the same with one of the installed struts. I open both clips before removing it. Once both clips are open I can easily swap out the struts with one hand and hold the hood with the other. Once the new strut is installed, I pop the clips back inward with a flat head screwdriver.
    Hopefully this makes sense... it's really very quick and easy once you understand how to slide the clips to release the
  25. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    The clips are spring loaded, and the finish scratches easily. You won’t care about that on the old tired ones. So don’t move the clips on the new ones. Just pop them in.
