does some one knows the original N for the front and the rear bonnet struts for a testarossa, 1987 if so then would be great to post here. thank you
My notes have: Front = 330 N (but this is for the later, after SN 76001, part, SG437003, and many people, including myself, use something with a little higher force) Rear = 320 N (SG337001 with elec connectors 61498100 and/or SG337002 without elec connectors 61498000) but, if you do a search using those Stabilus Sachs parts numbers and/or the corresponding Ferrari part numbers, you should get many prior threads to confirm/deny .
thank you steve front I will use original but rear I need stronger ones. have a big wing on my competition the stabilo sachs I not like to use anymore. after 2, max 3 years not work right. I remember that once here in the forum I read from those struts with lifetime warranty, but can not find anymore. also not know the manufacturer or a distributor.
