FORMULA 1 AZERBAIJAN GRAND PRIX...2021...RACE...... ▄▀▄▀▄▀ SPOILERS ▀▄▀▄▀▄ | Page 25 | FerrariChat
Discussion in 'F1' started by jgonzalesm6, Jun 6, 2021.
  1. JJ
    JJ F1 World Champ
    Jan 6, 2010
    11,357
    PA
  2. Terra
    Terra F1 Rookie
    3,689
    Wasn’t you who so vehemently claimed that Lewis “forgot” to switch off the brake magic just before the standing restart?
  3. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    20,736
    Corpus Christi, Tx.
    Joe R Gonzales
  4. DF1
    DF1 Two Time F1 World Champ
    Max has to know teams take risk and push the limit with all items for an advantage. Pirelli investigated and provided the results. Not much more to offer but I think there was no major problem or conspiracy that caused this. There are multiple ways to manipulate the tires as noted in the press.
    jgonzalesm6 likes this.
  5. jcurry
    21,545
    In the past
    Jim
    Doesn't Pirelli set the pressure limits, and shouldn't there be no structural failures when running at those limits?:rolleyes:
  6. jgonzalesm6
    20,736
    Corpus Christi, Tx.
    Joe R Gonzales
    Agreed
    Picchu88 and Jakuzzi like this.
  7. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    41,368
    ESP
    Bas
    Lewis said it must've been a case of playing with tyre pressures.
    Guess we finally understand how his tyre blew last year silverstone and was moments away from exploding at Baku as well. Glad that was cleared up!
    Either/or. Never his fault though is it!
  8. Terra
    Terra F1 Rookie
    3,689
  9. Bas
    Mar 24, 2008
    41,368
    ESP
    Bas
  10. Terra
    Terra F1 Rookie
    3,689
    So now you’ve come around to an “either/or” stance instead?
  11. Bas
    Mar 24, 2008
    41,368
    ESP
    Bas
    #612 Bas, Jun 17, 2021
    The point is that he always finds someone/something to blame. It's never him is it?
    I've seen the onboard where he indeed switched it off. Then he holds his wheel very strange into T1, pressing the button. Whichever way you put it, LEWIS made the mistake, no one else.
    Lets look at it again:
    We can't see the screen well at all unfortunately, but I have seen images of the screen that the switch was indeed pressed to normal at the start (no timeline I recall but I'll accept it for what it is). He then holds his wheel quite strange on the start, about 100 or so meters in he moves his hand to the normal position, then he locks up, and as he goes straight he appears to press a button (again?). If he pressed the button after locking up, he simply outbraked himself. The only other time he could've hit the button is before the first 100 meters and holding the wheel rather strange.
    JJ likes this.
