For F355....Leave the stock muffler or get a Capristo Exhaust? | Page 3 | FerrariChat
Discussion in '348/355' started by edmo7, Sep 26, 2004.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,678
    Lake Villa IL
    A few pounds from one component would make little to no difference, but that's not what some of us here are doing.
  2. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Precisely why this thread's scope needs to be broadened since this thread was specific to a single component.
    I am in the process of crafting/starting the new thread - Happy to stand down if anyone else prefers to.
    Cheers :)
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Now I understand garage queens. The owners are minimizing the mas of the vehicle by keeping it stationary. :)
    Shorn355 likes this.
  4. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
  5. ShineKen
    ShineKen F1 World Champ
    19,343
    Southern California
    Nostradamus
    The bracket would give it a few lbs more for a fair comparison. My new revised Larini muffler, with revised brackets along with added inconel insulation weighs roughly 27 lbs.
  6. 308 GTB
    308 GTB F1 World Champ
    11,645
    New Jersey
    Barry Wolinsky
    Right, Scott. But a Challenge car doesn't have the "high pitch Formula 1 sound" many owners are looking for. :)
    Here's how my car sounds like at speed...
    That Lamborghini whatever model it is sound would be preferable to most here.
    Barry
  7. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Hey Barry - First, your car sounds SICK!! Awesome! And looks good too :) Second - Your post personifies my point that kinda got lost - SOUND!! Your car sounds awesome and I assume sounds the way YOU want it to sound - correct? So if there was an exhaust option that weighed 5 pounds less but did not SOUND the way you want it to sound would you sacrifice the sound for the weight? I doubt it but I could be wrong.
    The "high-pitch F1 sound" versus lower-end "throaty" sound is an ongoing discussion and generally speaking from my experience Tubi provides the F1 sound and Capristo provides the throatier sound (at least until the valves open up). I am sure Larini, Fabspeed, Akropovic and others also fall into one of the categories or perhaps a great balance between the two - not sure. My point was to install what YOU think SOUNDS best and is high-quality and fits properly regardless of weight because if weight is the driving factor then there are a LOT of other things on a non-Challenge spec/roadgoing 355 that can be sacrificed. And lastly, although it apparently ruffled a few sensitive feathers I sincerely doing many of the 355 owners (including myself) are good enough - wait scratch that - in-tune and sensitive enough drivers to really feel the difference under normal driving circumstances. It all got lost in the mix so who really cares - I certainly don't :)
    So I will ask you since you graciously posted a great video of you ON A TRACK doing what 120/130 (?) down the front straight at Pocono and obviously are licensed to do that and have the opportunity to push your 355 way past normal limits - can you feel the difference in weight between a 30-lb muffler and a 40-lb muffler?
    Again - Thanks for the post and the great video - Anxious to hear your thoughts. As mentioned and promised I started another thread for the broader spectrum of modifications beyond just exhaust - Take a look and perhaps help kick that one off. I think we have run the water out of the washcloth on this thread :) :)
    Cheers!
  8. 308 GTB
    11,645
    New Jersey
    Barry Wolinsky
    #59 308 GTB, Mar 7, 2022
    Hi Scott,
    Thank-you for your compliments of my car. I've owned it for ten years and I always look forward to my next track event where I can drive it again. It's a safe and predictable car on the track. Ferrari knew what they were doing when they made the F355.
    Those are great questions which I'll answer individually.
    The Challenge silencer is very light. I never weighed it but I can pick it up and carry it around with one hand. It was designed for use on tracks on the Challenge Series circuit that had no sound restrictions...
    The car also came with a Challenge muffler for tracks like Lime Rock Park which did have sound restriction rules...
    That muffler is pretty quiet, perhaps a drop louder than a stock muffler. It's a bit heavier than the Challenge silencer.
    Weight is no longer a factor with these older cars. Newer cars at track events have double or more the horsepower of my F355 Challenge. We all take corners at the same speed and then they disappear in the distance when we exit the turn and get out onto the straight.
    Sound is important to many owners. I've only driven an F355 Berlinetta once for about twenty minutes. It had a stock muffler and it sounded pretty good to me.
    I was accelerating down the Pocono front straight after exiting the road course segment. Going into Turn 1 at the end of the video I was doing ~140. No racing license is necessary for these HPDE events. We're not racing. I was able to get my car up to ~165 at Daytona on the front straight but had to immediately prepare to slow down to enter the infield road course. The F355 is very stable at high speeds. Daytona has very high banking which robs the F355 of speed until the banking levels off a bit when the car can accelerate again. It's all a matter of physics and vectors of force. On the banking, forces directed perpendicular to the track surface rob the forward vector of force provided by the engine. The third vector is that of drag. The Factory used a wind tunnel to test aerodynamics. They designed the F355 very well to the extent that the road-going version does very well on the track...
    I just found the thread you started today. I've subscribed and will follow and post.
    Best,
    Barry
    Shorn355 and ShineKen like this.
  9. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Wow!! I have to say this is one of the most informative and interesting posts I have seen/read on here in a long time- Complete with awesome pics no less! :)
    Thanks so much for taking the time and putting the thought and effort into the post- I'm sure many others on here will be equally appreciative.
    I am definitely envious and may pester you with some additional questions but for now will just let this excellent post close my day :)
    Thanks again!
    :cool:
  10. 308 GTB
    11,645
    New Jersey
    Barry Wolinsky
    Asking questions won't be petering me, Scott. I'm happy to share what I've learned about the F355 over the past ten years.
    Barry
  11. robert biscan
    robert biscan F1 Veteran
    5,079
    Nashville and Palm b
    robert s biscan
    If anyone has a capristo exhaust for sale, I'm looking.
  12. ShineKen
    19,343
    Southern California
    Nostradamus
    15 kg for Kline Inconel exhaust system including headers ?
  13. RJJMiami
    RJJMiami Rookie
    Aug 1, 2019
    1
    Alo Barzakay
    I have a 97 355 GTS. Considering the Capristo. I have read a lot of contradictory info online even from Capristo themselves when talking about sound stage 1, 2 or 3. I'm considering the stage two which as far as I can tell is replacing the muffler. Did you do anything with cats or leave stock. Thanks.
  14. robert biscan
    5,079
    robert s biscan
    I got a tubi on my 355 and love it. Sounds great to me. I do have capristo on 599 and tubi on 512tr. 16M is stock. I have put capristo on my lambo's.
  15. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    Having run both along with the stock exhaust, imo Capristo for sound, Challenge for weight savings. I'm currently running the challenge exhaust but it's rowdy, for sure. It weighs 8lbs iirc, so much lighter than any of the other options - and is light enough that the crossmember to hold it isn't really needed saving maybe another pound for those spring mounts that the other mufflers need. There is a titanium version out there if you want to drop another couple of pounds...
    308 GTB likes this.
  16. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    How does the challenge system sound?
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    Like a race car, full stop. It echos off of trees and walls, cracks and pops on over run. It's wicked. But it's obnoxious and hard to drive quietly, both because you have to baby it to do so and because it makes you want to open it up and hear it wail. I figured what the hell, I'm already driving a yellow Ferrari, so not exactly subtle, might as well lean into it. Luckily I live out in the country.
  18. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Do you have any videos? What’s the pitch like?
  19. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    Here are a couple.
  20. Terrible expert
    Terrible expert Karting
    Sep 10, 2012
    239
    Harrogate, North Yorkshire
    Kev W
  21. ShineKen
    19,343
    Southern California
    Nostradamus
    Sold
