Flat Plane vs. Cross Plane Cranks
Discussion in 'Technical Q&A' started by Fly'n DutchMan, Nov 21, 2005.
  1. Fly'n DutchMan
    Fly'n DutchMan Karting
    Oct 4, 2005
    248
    Agoura Hills CA
    Sander Brouwers
    As you've guys have probably noticed, the F430 literature makes it a point that the F430's engine is a flat plane crank engine with the corresponding firing order.
    Is the F430 the first street Ferrari with a flat-plane crank. Some literature says that is the case, other literature says that all Ferrari's are flat plane crank designs.
    http://www.autozine.org/technical_school/engine/smooth4.htm
  2. Steve Magnusson
    26,539
    #2 Steve Magnusson, Nov 21, 2005
    I believe most (if not all) Ferrari V8 use a flat plane crank (e.g., 308), but all Ferrari engines do not use a flat plane crank (e.g., TR where the crank throws are 120 deg apart).
    The "nice" quality that all 2-bank Ferrari engines share is "alternate-bank-firing" (using a flat crank in a 90 deg V8 block is one way to achieve this, but it doesn't require a flat crank in a 12 cyl).
  3. Fly'n DutchMan
    Oct 4, 2005
    248
    Agoura Hills CA
    Sander Brouwers
    Interesting....
  4. Watry
    Watry Karting
    Aug 8, 2005
    78
    Berkeley, CA
    Andrew Watry
    Yes, as far as I know, all the Ferrari street V8s are flat plane. That's what gives them the four-cylinder sound and shriek, rather than the dual-plane V8 burble that comes from American cars and Alfa Montreals. To me, Ferrari V8s sound most like Cosworth V8, which are also flat plane, or hot four-cylinders (again, Cosworth BDA comes to mind).
    Andrew Watry
