Fitting Carbon Fibre winglets | FerrariChat
Discussion in '458 Italia/488/F8' started by H00dedclaw, Jan 31, 2016.
  1. H00dedclaw
    H00dedclaw Rookie
    Oct 24, 2015
    35
    Hi Chaps I fancy doing the upgrade is it a DIY job or take to dealer, clearly you cant easy reach round to undo the bolts form what i see is it a under tray off job which for me would be dealer, i wondered if it was a panel in the front boot.. cant find anything on the net explaining it
  2. luvair
    luvair Formula 3
    1,584
    When I pursued was told, the front bumper needed to be removed. Not possible to remove from just underneath.
  3. synergy
    synergy Formula Junior
    Aug 5, 2007
    517
    Austin Texas
    Chris
    I just bought a set of these in CF as well and the dealer told me the entire front bumper needs to be removed. Owell....still worth it IMO
  4. Capristo Exhaust
    Dec 20, 2007
    152
    Sundern/Germany
    Yes, can confirm that the front bumper has to be removed to mount the winglets.
    Best
    Ignacio
  5. RC33
    RC33 Formula Junior
    Nov 29, 2005
    836
    Garden City
    RC33
    Can anyone advise how does the front bumper winglets actually benefit?
    Where does the winglets remove/relieve heat from?
  6. H00dedclaw
    H00dedclaw Rookie
    Oct 24, 2015
    35
    Thanks guys wonder what the charge for bumper removal would be !!! Winglets are £600 odd ...winglets unless I'm wrong are down force airflow not cooling ..but I guess the rads benefit as well
  7. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    they are for front end down force.
  8. boeckman2003
    boeckman2003 Karting
    Oct 7, 2015
    212
    Nothing to do with heat transfer, they bend for more down force. There is a 458 Italia book on amazon that goes through all of it. Pretty cool.
  9. rockitman
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    I would estimate 2 hours Ferrari dealer labor to get them installed.
  10. RC33
    RC33 Formula Junior
    Nov 29, 2005
    836
    Garden City
    RC33
    Just found this link ... posted here for easy reading.
    "The Show
    Two flexible winglets. This is what the Ferrari 458 Italia starts with. Placed in the lower front apron, these aero-elastic elements their nature very well. These generate downforce and reduce the drag as speed increases by minimizing the radiator intake surface.
    Nevertheless, when you look at them, you wouldn’t say that you’re dealing with active aerodynamics. This hidden nature of the aforementioned twin elements isn’t random. Ferrari wanted the 458 Italia to rely on discrete aero bits.
    For example, you shouldn’t be fooled by the moderate size of the air intakes placed adjacent to the rear side windows. These feed the V8 using an air ram effect that offers 5 HP at top speed.
    There are vents placed inward of the headlamps that feed the front brakes with cool air and then dispose of it via the outlets that sit on the exterior of the light clusters.
    Lean and look inside the rear wheel arches. Here you’ll find air intakes that not only serve an engine cooling purpose, but also reduce drag by neutralizing the air currents created at the sides of the vehicle. The air they take it is sent out though the grilles on the inner side of the taillights.
    The engine compartment is also cooled by air collected from under the car, as well as through the intakes at the sides of the rear window. As for the aforementioned sections placed inboard of the rear lights, these also hold the radiators for the clutch and gearbox oil.
    At the end of the Ferrari 458 Italia, we find two elements working together. While the rear diffuser is pretty generous in size, the boot only holds a small lip spoiler that generates downforce. Yes you tuners, this means that you’re exaggerating with your huge fixed wings!
    Despite the aforementioned subtle aero work, the Ferrari 458 Italia is more aerodynamic and generates greater downforce compared to the F430. Take it to its top speed and the air will add about a quarter of the car’s own weight."
    FERRARI 458 Italia Review (Page 2)
  11. Jafooli
    Jafooli Rookie
    Jan 7, 2020
    16
    Joe
    If the winglets work by flexible deformation, shouldn't carbon fibre perform differently due to it being a much stuffer material?
  12. Depreciating Asset
    Depreciating Asset Formula Junior
    Sep 1, 2019
    299
    Cary, NC
    Randy
    I did this myself a few months ago. Nothing difficult, just a lot of fasteners to remove. I sorta slid the front cover off and onto a weight bench that was the perfect height. From there I could access the bolts. Also added CF frunk trim while I was at it.
  13. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Nice!
    Can you post photos of the frunk trim?
  14. Depreciating Asset
    Sep 1, 2019
    299
    Cary, NC
    Randy
    fazooley likes this.
  15. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    Very cool, and even cooler you can see it with the hood closed near the wipers!
  16. fazooley
    fazooley Formula Junior
    Apr 15, 2005
    387
    Oh yea. I've been dying to do this. For anyone interested in changing the winglets Dan NormalGuy made a video on this also. This guys videos are priceless for 458 owners
  17. Jafooli
    Jafooli Rookie
    Jan 7, 2020
    16
    Joe
    I'm more interested in how these actually work and if carbon fibre being stiffer effects the performance.
    Are there any videos or animations that explain these?
  18. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    The 458 Challenge car completely removed them, so I wouldn’t be too concerned, though it has other aero enhancements.
  19. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    If you take a moment to articulate your OEM front winglets through their travel manually you will see that the 'flex' takes place where the wing mounts and not in the wing itself. The wing is entirely rigid regardless of the material of construction. As such the whether the wings are the OEM ones or the carbon ones it makes no difference to performance.
  20. fazooley
    Apr 15, 2005
    387
    The CF ones still flex like the original ones, I had the dealer install them last month
  21. VelocityTexas
    VelocityTexas Formula Junior
    318
    North Texas
    Bryan
    Carbon fiber winglets were a factory option so functionality would be the same regardless of material.
