First Tack day in a California T | FerrariChat
Discussion in 'Tracking & Driver Education' started by M go Blue, Apr 13, 2020.
  1. M go Blue
    M go Blue Rookie
    Mar 28, 2020
    6
    Foster City, CA
    eli rapaich
    I just purchased a 2017 California T w/ the handling package and looking to track it soon (Thunderhill), does anyone have suggestions or thoughts on what I can expect with this car? I have tracked numerous cars, but never a Ferrari. I have had the entire car sealed with expel and then ceramic coated as a way to help protect the paint.
    Any experiences or do/don'ts will be appreciated.
  2. fatbillybob
    Aug 10, 2002
    26,354
    socal
    If you are handy go through a typical track tech sheet. If not download a tech sheet from say speed ventures.com and have your mechanic go though the items. I would check lugbolt torque after every session, pay attention to any brake fade and go have fun. If the brake fluid is a year old + I would flush it. Stock brakes do not do well on any car and you 1st see the shortcomings as a long pedal and brake fade as fluid boils. Start with 50%+ life left on pads.
    tomc and Qvb like this.
  3. peppe siciliano
    peppe siciliano Karting
    Dec 6, 2017
    75
    Peppe
    I tracked mine a few times, it's OK but don't expect supercar performance.
    It's to soft and heavy, I had to turn the traction off to get anywhere and turn in a bit early as the front complains when you ask a lot from it.
    Be warned driven hard you will kill the tyres.
    Enjoy
  4. M go Blue
    M go Blue Rookie
    Mar 28, 2020
    6
    Foster City, CA
    eli rapaich
    Thanks for the info, I do not expect it to run like a 488, but rather more like it is designed, a beautiful GT cruiser that will put smiles on your face on the occasional track day. I appreciate the input and will let you know how it turns out, we are heading to Thunderhill on May 25. Should be fun.
  5. DougDish
    DougDish Karting
    190
    Northern NJ
    Doug
    Just one more item of note. Lug bolts to be checked when cool so torquing should be done just prior to going on track when the tire/wheel temps are coolest. Have fun, stay safe.
    Doug
    tomc likes this.
  6. M go Blue
    M go Blue Rookie
    Mar 28, 2020
    6
    Foster City, CA
    eli rapaich
    Thanks, I will post afterward.
