First Ferrari and first post! | Page 2 | FerrariChat
Discussion in '360/430' started by Brandon Marshall, Jun 27, 2020.
  1. tres55
    tres55 F1 Rookie
    3,496
    Canada
    GTE Engineering is the company that rebuilds the F1 systems at a fraction of the cost of new parts.
    Congrats on the car, sorry it started out on the wrong foot. GTE should be able to get it running as good as new with a rebuild worst case...hopefully the issue is minor though.
  2. brookliner7
    brookliner7 Formula Junior
    May 5, 2018
    780
    San Antonio, TX
    Hans
    I agree, the F1 pump running constantly meams the f1 pump relay is fried and melted. It's a very common issue. Needs to be replaced. It's like 50 bucks.
    It's behind the passenger seat.
  3. alex
    alex Formula Junior
    675
    Crystal Lake, Illinois
    Alex
    Congratulations on your purchase and good luck with the issues!
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Make sure to find out the procedure for checking the sump oil level as not like a normal car, hence the overfill and the problems it causes
  5. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    So if it’s the relay, why is there a pressure drop internally?
  6. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
  7. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    Hydraulic circuit pressure is dropping, that is sitting idle in shopping. Should not drop according to them, meanwhile, the pump is running constantly. I hear you on relay, but where is the pressure going?
  8. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    Shop* not shopping
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
    Check bleed screws on actuator and ediff solenoid ..those are very common issues before replacing actuator
    Also the accumulator ..that is cheap
    Sent from my moto g(7) using Tapatalk
    Skidkid likes this.
  10. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
  11. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
  12. brookliner7
    May 5, 2018
    780
    San Antonio, TX
    Hans
    part of the normal operation of the F1 pump is to intermittently cycle.
    I can only assume of if the pressure stayed constant and never dropped during normal operation it would never need to cycle again.
    Common failure points are the relay, which burn out your f1 pump, or a leak, which should easily be seen as a mess.
    Ive heard of people replacing accumulators but havent heard one that actaully failed causing a problem.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
    Based on the above ..the clutch subsystem is The cause .. could be a bad solenoid valve or tob.. the leak down is very high
    I would bet it is a bad clutch solenoid on the power distribution unit near accumulator
  14. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    No PPI done?!
  15. Natkingcolebasket69
    Congrats!!
  16. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
  17. Natkingcolebasket69
    It’s nice the seller offered to pay half or most of the repair. We have seen in the TR forum recently a car sold form a member to another which died on him
    After 50 miles and the previous owner didn’t seem to think it was appropriate to financially help with the repairs! I’m glad it turns out better for u!
  18. J360M
    J360M Karting
    Nov 29, 2018
    76
    What a Beauty!!! It will all be worth it when you get it back to full health.. kudos to previous owner for their commitment. I did something similar when I sold my previous F-car, cost me 3k but it was worth it for a clear conscience..
  19. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    I will present this to the dealership tomorrow. I will be honest, I’ve had a lot of cars but first Ferrari so I don’t know much about them but, what they are telling me just doesn’t make sense. I originally myself though something with clutch, but there again, idk much about them.
  20. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    You are confusing the 360 and the 430. Relays were an issue on early 360s, not much of an issue by late 360 and virtually not at all on the 430.
    OP, congrats on the new car. They are a ton of fun. Flash has done a lot and is probably on the right track. eDiff solenoid is an issue on the 430. Power distribution unit has been known to leak and if the throwout goes it will leak down pretty fast; that can ruin a perfectly good clutch as well.
    flash32 likes this.
  21. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    Does anyone on here know of any good techs in Greensboro NC area? I may get a second opinion. I am just limited in this area.
  22. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    374
    NC
    I don’t think there’s anything wrong other then the F1 pump being stuck on.
    Was the bleed down in 2 minutes with the pump no longer being stuck on constantly? This is a normal time with the clutch being depressed (eg idle in neutral and in that state for under 300 seconds)
    Leakage is a bit high but spec for the clutch selenoid leakage rates is <60cc/min which you’re well within.
  23. Brandon Marshall
    Jun 27, 2020
    31
    Oak Ridge NC
    Brandon Marshall
    bleed down was with pump cycling, they are saying it shouldn’t bleed down at all?
  24. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Oh it does bleed down, it just isn't too fast. They are mistaken about that.
