Finally.. new 1978 308 GTS owner... :-) | Page 2 | FerrariChat
Discussion in '308/328' started by Doogie, Mar 11, 2020.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,521
    Raleigh
    Kevin
    Derek, great reply. Can you elaborate on what one should look for with a borescope? I assume one should do this prior to trying to turn the engine at the crankshaft. Are you looking for signs of rust within the cylinders? If the car was running when parked 30 years ago I would think the engine would turn quite easily at the crankshaft, but perhaps one should not attempt to start it up. What are the "red flags" and if you see them how do to proceed?
    By the way, I agree completely that all fluids, filters, cam belts & tensioners, fuel lines and coolant lines should be replaced straight away! :)
  2. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I would look for signs of corrosion in the bores and squirt a bit of oil in before turning a few times by hand and then the starter with the plugs out to lube the bores while also priming the oil circuit.
  3. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    Thanks Derekw! I have a boroscope, great idea about taking a looksee. My plan would be to squirt a little oil, turn by hand like you said. After TB replacement (Parts on the way from RicambiAmerica), then with the starter. (anyone know where I can get a 308 water pump rebuild kit?). I also want to pull the valve cover gaskets not only to check for lash but also to make sure no valves are sticking down! Hopefully if there are any a little oil and a soft tap with loosen them up. Hoping this is not the case though! After that, flush the fluids, replace the fuel lines. The expansion tank is not completely full, and has some junk in it (rust flakes from above the water line) so I'll pull that straightaway and have it boiled out and redone by a local radiator shop. Might do the radiator too while I'm at it... With the USA Shutting down for a while I might be getting on this sooner than I anticipated! Free B&W for anyone who wants to help! ;)
  4. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,521
    Raleigh
    Kevin
  5. awaitingferrari
    Sep 26, 2015
    2
    Wow! Waiting for updates on this one! I also have something cooking but like Doogie, I wont share it till its done!
    Doogie and miketuason like this.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Can you give us a hint?:)
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Buy a new water pump, they are not expensive.
    Don't try to start it. Turn it over by hand after you squirt in there a bunch of oil.
    I hope you are taking into account how much you will need to revive.
  8. 2Velocebro
    2Velocebro Rookie
    Apr 13, 2018
    42
    San Diego, CA
    Brandon Davis
    Congratulations! That's a beautiful car and still looks new!
    Doogie likes this.
  9. awaitingferrari
    Sep 26, 2015
    2
    Fingers crossed and mum's the word! :) But just to avoid a expectations build up, its relatively modest but it'll hopefully be the start of the realization of a childhood dream (Horsie Ownership)! :)
    In final, price haggling stage ... Will share as soon as clinched!
    miketuason likes this.
  10. lm2504me
    lm2504me Formula 3
    1,086
    Nipomo, CA
    Richard
    New water pumps for 308 are poorly built. Outsourced to India or China??? After receiving and returning several new water pumps.....
    I took the original water pump from my 78 308 and sent it to Brian Crall (Rifledriver) http://www.hillcountryferrari.com/ to rebuild. He did the mods to use the single seal of the later 308 water pumps. Give him a call and he will tell you how long it would take. He is usually busy, but worth the wait.
  11. detroiter
    detroiter Karting
    Apr 30, 2013
    182
    Munich, Bayern
    Carter
    Hey that’s a great car... and identical to mine. Reminds me of the day I picked mine up. Congratulations
    Gesendet von iPhone mit Tapatalk
    Doogie likes this.
  12. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,399
    Toronto / SoCal
    Rob C.
    Congratulations on the 308. I know what it is to long for a 308 since as far back as I can remember and bought mine almost 18 years ago. Still love it and gets me going whenever I see it.
    If you plan on keeping the car and are going to give it a real thorough service take my word on it and pull the motor. I've harped on this in other threads but it is first hand knowledge true. I follow the rule of 3. Three or more things to do in the engine bay and pull the motor. In the long run it is less work, allows for a more complete job, and offers access that is otherwise impossible.
    For a car that has sat since 1990 you will want to do the following:
    - Replace EVERY hose. It is not that expensive and you are really playing with fire (literally) if you do not do this. I repeat EVERY hose.
    - Standard service items: Belts, water pump, tensioner pulleys, valve adjustment, etc.
    - Remove and re-build the carbs. MUCH easier to do with the engine out
    - Replace all fluids and filters
    - Check the radiator for blockages and rot
    - Remove the fuel tanks and have the insides cleaned. Almost certainly you will find varnish in there
    - New tires
    - Check CV joints for tightness
    - Check brakes to make sure the calipers are not sticking
    - Change clutch cable. Sitting as long as it has it may be corroded and can break. Cheap and easy with the motor out
    - Change accelerator cable. Same as clutch cable
    - Check the distributor especially the advance mechanism to make sure it is not seized.
    - Properly inspect down the cylinders before starting. Once the belts are done try a compression and leak down on the engine to see where you are. With the engine out it is a good time to take care of anything.
    With this work done you will have a good safe baseline to start driving. Beyond that things like the suspension, detailing the interior and exterior can be side projects to bring the car fully up to snuff. My list is the bare minimum to bring the car up to safety and exposing you to the minimum of risk for a catastrophic failure.
    Going to a professional to do this work should not be terribly expensive either. Doing a bunch of jobs at once is much cheaper than doing a little at a time with multiple trips to the mechanic. Having done this work recently to my car I can tell you that the parts bill was less than $2K. Spending a chunk now will save you much more later and will also make ownership much more pleasant. Best of luck.
    readplays and hawaiizac like this.
  13. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    I had no choice as my engine was seized and signs in the bore of coolant. If the bores look ok and the motor turns smoothly, I would change the belts and try to get it running to check for other issues (synchros, cooling system, brakes, suspension...) After running a bit check compression and leak down. That can all inform your decision to pull the engine or not (or get rid of the car :)
  14. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    So, the rebuild has started! I have the 30K Major service kit from Ricarmbi America, which has most everythign I need so far. Still need to source a Water Pump rebuld/rebuilder. (The one on the car does not turn easily, but rather in 'spurts'?) Everything else is going great! Have the valve covers removed, TB covers removed, A/C disconnected and out of the way (had no pressure so decided to disconnect and remove,. but will re-install and recharge). Need to order complete Water hose set, fuel hose set, vapor recovery hose set, and fuel pump. Next step is to remove plugs, squirt some oil in the cylinders, then manually turn engine a little bit to see if it's OK. Having a great time wrenching on a Ferrari!
  15. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Replace EVERY fuel hose, as mentioned. EVERY SINGLE ONE. Including the cross over connectors between tanks under the car and filler neck. I used SAE J30R9 fuel injection hose for the small lines to and around the carbs. That stuff is ethanol resistant. I got ethanol resistant hose for the larger pieces from someone in CO, can't remember his F-Car dealerships name.
    The water pumps are real easy to rebuild yourself, if you have basic mech skills, feeler gauges and access to manual hydraulic press, or arbor press. The Ferrari service manual helps as it has the dimensions needed. Bearings and the mech seal are inexpensive,and available from the usual f-car vendors.
    Doug
    readplays and Doogie like this.
  16. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,399
    Toronto / SoCal
    Rob C.
    T308 likes this.
  17. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
  18. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    Agreed. Just discovered access to the lower water pump hose between the engine and the firewall after I removed the A/C Compressor, so that's nice to figure out. Every hose is being repalced, even the vapor return lines.
    I couldn't find 308 pump kits?
  19. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    I think you can get pump rebuild kits from TRutlands and Ferrparts.
    Note to measure your water pump shaft diameter, there are two different 308 pumps, thick shaft and skinny shaft. I can't recall if the bearings and seal are different between the two pumps. The two pumps interchange on the motors.
    Follow the directions in the service manual, don't break a seal like i did once, they are $40.
    Doug
    Doogie likes this.
  20. hawaiizac
    hawaiizac Karting
    Mar 29, 2018
    79
    Hawaii and Las Vegas
    Hawaiizac
    Congratulations! I joined the club in Dec. Welcome! Sweet car! I have an ‘84 QV. Do the work now, it’ll pay off when you’re driving at the speed limit but feel like speed racer...
    Doogie likes this.
  21. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    Thank You! And welcome from me to you! (I guess that sounds weird since you were here first! :)
  22. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
  23. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    And Ricambi America sent the wrong fuel filter? Mine is a cartridge type.. the one they sent in a (HUGE!) inline type...?? Guess I'll call them tomorrow...
  24. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
  25. hawaiizac
    hawaiizac Karting
    Mar 29, 2018
    79
    Hawaiizac
