Fiero NORTHSTAR Project | FerrariChat
Discussion in 'American Muscle' started by DANCER308, Mar 18, 2014.
  1. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    #1 DANCER308, Mar 18, 2014
    Why? Because I could!
    I bought a new Fiero in 1985, drove it for 10 years with no problems. Really enjoyed the car. I decided to buy another one in 2004, a 1988 4 cyl, with the intention of doing a body and engine swap. The body swap was going to be either a Ferrari or Lambo. But, I would leave the Pontiac and Fiero badges on. After the engine swap was done, I noticed that there was a lot of jaw dropping when people saw the Northstar in there. If the car was exotic looking, a large engine would be expected and there would be no big surprise. The body swap was out. I drove this car as a daily driver, a blast to drive to work every day and I figured that no one would pay any attention to a Fiero in the public parking garage.
    Pic 1: Here is what the car looked like when purchased, not bad and drove well.
    Pic 2: Original 4 cyl.
    Pic 3: Interior, during a complete instrumentation swap. Found a wrecked 6 cyl and pulled all of the instruments, power windows, electric door locks, subwoofer, electric rear hatch release and probably other stuff that I can't remember right now. My car was a base model without options.
    More to come.
  2. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #2 DANCER308, Mar 18, 2014
    One of the first modifications made was to the engine cradle. Modified to accept the caddy motor mounts. Next, using the inboard Caddy axle and outboard Fiero axle, one axle was made. There is about 1 in. between the two boots. Caddy wiring harness modified to plug into the Fiero harness. Modified Tach with new capacitor to read 8 cyl. Caddy computer modified to remove all of the Caddy functions that the Fiero does not have. Custom exhaust. Modified shifter for "4" speed auto tranny.
    Pic 1: Engine cradle before
    Pic 2: Engine cradle after
    Pic 3: Donor car, 1996 Cadillac Eldorado
    Pic 4: Modified Tach
  3. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #3 DANCER308, Mar 18, 2014
    The engine cradle, computer, axles and wiring harness were modified by Design 1 Systems in Oklahoma. The only modifications to the car were removing the engine strut bracket that was attached to the wall between the engine bay and trunk, removing the lower half of one of the deck lid hinge supports and removing all of the standoff supports in the engine bay that are not needed.
    Pic 1: Installing the engine. I needed extra hands for this. One person holds up the car and the other pushes the engine under the car. Look at the size of that engine.
    Pic 2: Engine under car. At this point it looked like there was no way. I know that I had measured several times, but...
    Pic 3: It fits with room to spare, well, sort of.
  4. Phil~
    Phil~ F1 Rookie
    3,935
    Potomac, Maryland
    Wow, awesome swap!
  5. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #5 DANCER308, Mar 18, 2014
    Thanks Phil.
    Many of the guys here asked me how fast it was on the drag strip. I told them "I don't know". I have never run a car on a strip. They finally cornered me one day and off we went to the strip. It was an 1/8 mile strip. They had to talk me through the whole routine. Here was the results, I thought it would be a lot faster but they said that was really good for a street car.
    More pics to come.
  6. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    .050 light and 2 sec 60 ft on street tires. I smell "sandbagger!"
  7. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    He told me to stomp it on the last yellow. The tires do not spin, the car just jumps, and what a ride.
  8. spdrcr
    spdrcr Formula Junior
    Aug 2, 2004
    318
    San Jose, CA
    Matt
    I always thought the Fiero V8 was a cool swap. Nice post.
  9. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,309
    Southlake, TX
    Rob Lay
    very very cool, interesting project.
  10. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #10 DANCER308, Mar 18, 2014
  11. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #11 DANCER308, Mar 18, 2014
    Changed the stock wheels. Went with lower profile tires. Looking back, I'm not sure the tires were a good idea. They look great but I feel every pebble in the road. But, since I no longer go to work every day, I guess I can live with them.
    Pic 1: Stock wheels. I polished them to a good shine
    Pic 2: New wheels
  12. Nativetroy
    Nativetroy F1 Veteran
    5,988
    central fl
    Troy
    Cool project. I'm sure it's fun to drive.
  13. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    ok,what did you use for a trans,axles,computers,did you just modify the cradle?
  14. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    I used the tranny from the Caddy. The axles were made from the inboard axle flange from the Caddy and the outboard flange from the Fiero. Used the Caddy computer. Modified cradle, wiring harness, computer, shifter, surge tank, throttle body and plumbing, engine deck lid hinge mount, tachometer, speedometer, throttle cable mount on throttle body, removed engine strut bracket and moved trunk wall to make space for the exhaust system and a few other things.
  15. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    Okay I have to ask, you did not mention any suspension work and over the years I have been involved in many projects like this and usually (without suspension changes) you end up with a faster car that is unbalanced with front end plow when you hit the brakes. I assume there were some weight differences between what was and what is in there now.
  16. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #17 DANCER308, Mar 19, 2014
    When the Northstar went in, it lowered the rear about 1 in. I cut 1 coil off of each spring in the front to level the car. No other suspension work done. The engine actually sits in front of the rear wheels. As far as weight goes, the Northstar does not weigh that much more than the V6 that could have been in these cars. Even though this car was a 4cyl, I believe the same suspension was used for the 4's and 6's. It does plow, and if I had planned on racing this car I would have done the suspension work, but it is a daily driver and show car.
  17. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    I like your Jag (I have a similar one, along with an E-Type)!
    Now can you figure out how to shoehorn the Northstar into a Lotus Esprit???
  18. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    #19 DANCER308, Mar 19, 2014
    Funny you should ask, I almost bought this car. Was making plans to put a V8 in it. Passed on the deal. Ended up with the 308. I'm much happier now. The Jag is a great ride.
  19. Ak Jim
    Ak Jim F1 Veteran
    9,385
    North Pole AK
    Thanks for posting.
  20. rdefabri
    Jun 4, 2008
    33,571
    NJ
    Rich
    That's interesting - I almost purchased an Esprit as well, but ended up with a 308 too!!
    The Esprit I looked at was a turbo, but the 308 fell in my lap so I snagged it...I'm happier as well, I love the 308.
  21. Tenney
    Tenney F1 Rookie
    Feb 21, 2001
    4,254
    Very cool - bet it's a blast!
  22. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    I actually went looking for my 308. It was one of those things back in '79 watching Magnum P. I., thinking one of these days I'm going to get one of those. It took me 32 years, but I finally got it.
  23. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    Thanks and yes, it is!
  24. DoctorV8
    DoctorV8 Formula Junior
    Jun 29, 2004
    472
    Houston, TX
    Sanjay
    You could always do the Mera body kit on a Fiero, and people would think you have 2 308s!
    Very cool car...I love V8 swaps. One of the guys on LS1 tech has put an LS4/6 speed into his Fiero.....very vool.
