Fibreglass Spoiler Repair - Need advice. | FerrariChat
Discussion in 'Technical Q&A' started by Verell, Jun 18, 2006.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Hello,
    I'm repairing my front spoiler after an incident involving the brick steps at the front of the garage.
    It's a deep Euro style spoiler.
    The spoiler flexed & cracked the body filler all across the front of the air dam. I just finished sanding all the old filler off, but discovered that in some cases there are thin light colored lines in the fibreglass that correspond to the cracks in the filler. These aren't full breaks, but my suspicion is that they are thin partial fractures in the resin that are being held together by the glass fibers. There are maybe a dozen or so of these lines in various places & lengths.
    My suspicion is that if I just covered them with flexable filler, that the cracks would reappear the first time some stress was put on the air dam.
    What's the professional way to deal with with a situation like this?
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
  3. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Make sure you use epoxy resin if you end up fixing the spoiler yourself with fiberglass. If you're near a good boatyard, they should be able to do a good job fixing it properly. I do not think that many bodyshops know what they're doing when it comes to fiberglass repair. If you neede more advice, please ask - we do this all the time.
  4. Mark 308 gt4
    Mark 308 gt4 Formula Junior
    Apr 24, 2006
    285
    West London
    Mark Taviner
    Its a shame you are not close by, I would show you how to do it, all GRP work is quite simple but to write it down is very difficult.
    You need to know if its made from polyester or epoxy glass fibre.
    You can not mix the two, its more than likely polyester.
    The thing that people do not like is the dust.
    The cracking is in the gell coat, the only way to stop this is to sand it back untill you are down to the glassfibre, you can then fill with filler. If you don't they will return. You must repair the spoiler first!!!!
    Your best way is to work from the inside out.
    sand the inner spoiler off so you have no shinney surface left, clean off all the dust. You can then position the outside correctly (broken bits, cracks with masking tape on the outside) this will come off after all sets. lay up "inside" with a minium of three sheets of matting at repair area, with a larger sheet covering the whole repair.
    After an hour or so you can remove all tape, start your sanding and repairing of the outside.
    The whole thing will now be strong, but it will not be fully cured for a couple of days.
    See what I mean about putting it into words!!!
    the rest is just shape prep and painting, but thats another story.
    Hope this helps
    Mark...
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Unfortunately, D-348's thread & the FibreGlast article don't go down to the level of detail I need.
    I've repaired fibreglass before, but it was always clear breaks, or crushed areas where you just removed the damaged material, then feathered the edges & built it up again with new fibreglass, so am generally familiar with it.(Should have posted this earlier).
    Here's what Dan Hogan, the owner of Thunder Road in Dunstable,MA told me this AM:
    The white lines are 'stress lines' or 'stress fractures'. If just sanded them down & glassed them over(which is the way I read D-348s post), they'll propagate back up thru the repair. Which is what I suspected.
    Here's the way Dan's shop handles them:
    - Drill a ~1/16" stress relief hole at the end of each stress line. (Std aviation practice for stoppin crack growth)
    - Feather a broad V to the bottom of each line, & then rebuild with fibreglass. If there are a lot of cracks close together in an area, it's best to just grind a shallow cup out & repair the whole area."
    From other research, the V should be at least 1/2" wide for each ~1/16" of depth, and should always be at least 1" wide. If possible, feather a broad V in from both sides for maximum strength.
    Build up starting with glass fabric that extends outside the repair area, Then use smaller pieces to build up until level or slightly above the original surface. Sand/grind to original thickness, spot fill, & refinish.
    Now to locate some Epoxy resin. I've got 3M Fibreglass resin, but am pretty sure it's a polyester resin. There's a large boat mfg & repair company near me. Should be able to get some epoxy resin from them.
    Another question:
    The original spoiler had a layer of woven fibreglass cloth on the back, but most of the layers are just fibreglass mat. Which will give me the stronger repair? I'm thinking of using the cloth with one weave direction aligned with the longer stress lines. That way the fibers in the other direction will be directly across the stress lines.
    Valence,
    would appreciate any other tips you might have.
  6. Valence
    Jan 20, 2004
    883
    Charlottesville, VA
    Use cloth - it's stronger, and chopped strand mat is not really compatible with epoxy resin. The mat is held together by a binder that dissolves in stryene, the solvent in polyester resin. Epoxy doesn't dissolve this. Cloth is free of these binders. I'd go +/- 45 degrees across the crack, but you will likely remove so much thickness sanding the "V" area over the crack to apply the repair cloth that it does not really matter. Try alternating plies - 0/90 and -45/+45, building up thickness with a couple plies of each.
    I think the overall repair strategy you outlined above is fine, but the hole drilling is not needed. Standard aviation practice for stopping crack growth on metal parts is replacing the part. On composite flight surfaces, the entire damaged area is removed, so there's no crack left to drill a hole into. I know what he's thinking of - like drilling a hole at the vertex of an angle cut into sheetmetal to eliminate the hard angle and prevent cracks from beginning, and I've heard of "stopping" a crack by drilling holes in metal parts, but the advisability of this is another topic entirely. Composites are fundamentally different from metals in the way cracks form, grow and stop. Just get rid of the damaged material and build up a fresh repaired area.
    Go for the epoxy from the boat place - any retail boat store should have it too. Epoxy repairs are tougher and stronger than polyester (fiberglass resin) repairs, and the materials are a lot less smelly. Wear gloves and goggles and use a respirator, especially while grinding or sanding.
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The original material is only about 1/8" thick. So I suspect that 3 layers of glass cloth is the most I'll be able to lay on before I'm thicker than the original material.
    Is there a way of packing the glass layers closer together than the following:
    0) brush on an initial thin layer of resin to wet the surface,
    1) lay a layer of glass fabric on it,
    2) brush on another thin layer of resin,
    3) Use the brush to work the resin thru the fabric, until the fabric is saturated (no air bubbles, uniform color).
    4) lay on another layer of fabric...
    5) Go back to 2 until you've built up the desired total thickness.
  8. Valence
    Jan 20, 2004
    883
    Charlottesville, VA
    A "peel ply" on the surface will help - ideally you'd apply some clamping force. We use vacuum bags for this purpose. Clamping a thin board or something that will conform to the shape over the repair will work, too. Put a release layer like peel ply or polyethlene film over the repair first. The backside of the part can be bulked up, too.
    If the part is 1/8" 20year old chopped strand polyester/glass, removing damaged material and replacing it with fresh woven glass/epoxy will probably result in superior strength to the original, even without bulking the backside.
  9. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    If you pour some resin/fiber mix down the recess behind the spoiler from the backside, it greatly increases the strength of the spoiler lip itself. I did this on my last fix, and while it did add some weight, the lower spoiler lip is now very crack resistant.
    Good luck Verell.
    Spang
  10. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Verell,
    Well I guess I'm a bit of a dissenter on this issue. I prefer polyester resin and matt for a repair like this and here's why.
    The original piece was most likely made of polyester resin. I've done repair on my spoiler and it came out perfectly and remains so. I find it easier to use ployester resin and it provides adaquate strength. Epoxy is more expensive but provides some additional strength, but it's real advantage, especially in marine applications, is it's impervious to water when the film thickness is adaquate. These are not essential requirements for your repair. If the piece was in constant contact with water, I might elect to use epoxy.
    The strength of a repair is primarily in the glass fibers as I'm sure you know. The resin merely bonds the the fibers together. Need to increase strenght? Increase the glass to resin content by laying down another layer or two of glass and squeeze out some of the unnecessary resin prior to the cure process. A light wooden strip, separated from the resin with wax paper, and clamped with some C-clamps, vise grips, weight, or whatever, works pretty well. Peel off the wax paper and clean off the residual wax with prep solvent, prior to grinding the repair down to the level of the surrounding material. I use a right angle die grinder with a Roloc disc or an oval carbide burr to remove excess material. Finish off by block sanding, primer surfacer, block sand again, then finish coat.
    A down side of epoxy is that while epoxy can be used over polyester, polyester cannot be used over epoxy.
    How much strength do you need? Under normal circumstances not much for the spoiler. If you hit a curb or speed bump again, neither polyester nor epoxy is going to help much. At best, it'll just fracture in a different area.
    Why use matt? Well, it conforms better to curves and after cure and ageing is less likely to show a weave. I think it also wets out better.
    Standard repair practice is to cup both sides of the damaged area and lay up matt and resin on both sides, with sufficient thickness so the repair can be ground to the level of the surrounding, sound surfaces. It's interesting that over the years I developed this method but later found that Lotus wrote the book on this subject. If you ever get a chance to read one of their Elan shop manuals you'll see all the tricks. On the back side of the repair, you don't have to be quite as careful, but I still like to only lay down only enough resin/glass to do a quality repair.
    If you insist on epoxy, West Systems makes a very good epoxy, the standard in the marine industry. You will also need their pump system to reliably mix the resin and hardener. The mix of epoxy and hardener is more critical than polyester and the cure produces a lot more heat.
    For polyester resin, I like the finishing resin supplied by Jamestown distributors in RI. It's a fairly low viscosity resin that wets out well, yet does not run unduly. Their part number for a quart is FIB-553 and costs about $14/qt. It comes with 12 cc of MEKP, almost twice the hardener you need this time of year. I find about 0.4 cc of hardener produces a reasonable cure rate in my garage. I use a graduated plastic beaker to measure out the resin in small quantities like an ounce or two. I find a 1 cc diabetic syringe ok to to meter out 0.4 cc of hardener per ounce of resin, though the needle is so fine it takes a minute to fill the syringe with the necessary hardener. In CT, I can buy these syringes over the counter at some pharmacies for about $4 for maybe 10. They can be reused, but eventually the graduations get washed off by the hardener. Use more hardener if you want a faster cure or less if you want a longer pot life. Excess hardener promotes a slightly more flexible cured product while less hardener produces a slightly more brittle cured product. Kind of counter intuitive. The way a chemistry professor at UCONN explained it to me is the additinal hardner separates the resin molecules a little more, resulting in the increased flexibility. Anyway I would not try to fine tune it too much. If you find the cure taking a little to longer than your liking, warm the layup with a heat lamp.
    I hope I haven't introduced too much controversy here but I've been working with this stuff on my Lotus and racing sailboat for a lot of years.
    Bill
  11. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I have done a fair amount of fiberglass work and I concur with Bill's methods. I have not used epoxy, but here it works well. Had good luck with polyester resin on boats and my '69 Corvette. The mat would be my choice too. You can weave a layer of cloth between layers of mat, but I have seen adhesion problems and the weave showing through so I avoid it. It is important to squeeze all the excess resin-out. Saran wrap or dry cleaning bag material works good because you can clamp it then peal the Saran wrap off.
    Polyester resin loves heat--it works well with a heat gun or lamp. You can cook it to about 150 deg and it will harden in about 10 minutes. They say that you need this type of heat to fully cure it. Have been told by Corvette folks that if the repair is not exposed to high heat it will likely move. Many polyester resin and primer users let their repairs sit in the hot sun for 90 days or so. Notice how long it takes the resin smell to leave a camper shell cap?
    I would be careful about making the spoiler too strong. On my car there is a crack cause by the spoiler being too stiff and not flexing.
    Good Luck,
    Mark
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Thanks for the help!!!
    CAN I USE POLYESTER BODY FILLER OVER EPOXY?
    I've got a quart of WEST SYSTEMS epoxy being delivered today.
    The remark about not being able to use polyester over epoxy concerns me because body fillers are all polyester based. I've been using SEM Flexable Filler over my fibreglass repairs. It's made for filling plastic bumpers & other fibreglass & plastic body panels. Am I likely to have problems using it over epoxy resin? If so, then will reconsider & just use polyester resin.
    I'm not trying to strengthen the area significantly. Just do a repair that brings it back to the original strength, or at most slightly stronger, while retaining the original flexability. The spoiler is clearly designed to flex slightly, so that relatively gentle encounters don't crack it. I've accidently touched curbs before with no visable effects other than minor paint chipping.
    Luckily, most of the area I'm dealing with is very close to being flat. It's the front of the deep Euro spoiler lip. So I'll try to clamp a long thin 6" wide board with a release material under it on top of the repair.
    I say 'try to clamp' because the lip cross section is basicly a deep V, with a curved back leg. The radius of the back side of the V is about 5"or so. I suspect that there's just enough angle so that my C-clamps will slide off, but it's worth a try.
    Because of the deep V cross-section, the actual back of the lip surface is down in a very narrow, deep area, that has been sprayed with a thin layer of Dinol, or some other kind of tar like substance.
    I haven't been able to figure out how to get a sanding disc deep enough into the groove to clean the area up. So I don't think I'll be able to reinforce the repair's back. Instead, I'll cup the damage pretty deeply & build it back up.
    BTW, to match the original surface texture, the repaired area is going to receive a skim coat of flexable body putty, then be sprayed with light texture rocker schutz(aka chip guard), which will hide any glass mat surface texture that might otherwise appear over time.
    bill308:
    Here's an alternative to your insulan syringe:
    I have a wide selection (0.5cc to 140cc) of oral feeding syringes that I use for mixing my casting material. The 0.5cc & 1cc syringes are calibrated in 'drops' as well as cc, so measuring out precise ratios of resin & hardner is easy. The have a nubby tip with a fairly large opening so they don't have the flow problems that a needle has. Many drugstores will have them, as well as online vetinary supplies, and exotic bird breeders use them. They're less than a $1 in quantities of 5 or so, altho shipping would about double that.
    I was surprised by your 0.4cc hardner/oz polyester resin. That's ~8.8 drops/oz (22drops/cc x 0.4cc). The usual ratio is 14drops/oz at std temps. Somewhere I've got 3M's recommendations for changing the ratio to accommodate temp. changes, but remember their high temp ratio being either 10 or 12 droops/oz, & they were pretty adamant about not going lower.
  13. Valence
    Jan 20, 2004
    883
    Charlottesville, VA
    Verell, I have some clamping tips - call me if you want and I'll explain.
    The reason that epoxy should be used for a repair is that it is a much better adhesive than polyester. The water resistance thing doesn't really factor in here - it's a big plus in the boat world, though. Once polyester resin has cured, as it did over 20 years ago in Verell's case, new polyester will not chemically bond to it. A mechanical bond is the only hope you've got, but polyester shrinks a lot as it cures, so this mechanical bond is significanty compromised as soon as the repair cures. The bond is significantly stressed from the getgo. Even without taking the shrinkage into account, epoxies are in general better adhesves from other chemical standpoints.
    West System is our repair epoxy of choice. They make great products, great REPAIR MANUALS, and have most if not all of the info published online. Polyester body filler sticks as well to a properly prepped epoxy surface as just about any other non-porus surface, but why not experiment with West System's own line of filler additives, which stick a lot better than bondo?
    Typically, epoxy like west system is tougher than polyester, and will "give" more before delaminating. Use of woven cloth with epoxy results in a tough, resiliant, strong repair, that doesn't have to be especially stiff as long as you don't build up too much repair area. Polyester/chopped strand tends to be very stiff, but also brittle, especially at the original part/repair interface.
    I do not think that good repair epoxy was around when '60's corvettes or lotuses were around, so they made do with the best primitive chemical technology that they had. Ignore obsolete repair strategies.
    Do the right thing, use epoxy, prepare the surface properly (you could try solvent wiping and sandblasting the backside if it's hard to sand), and don't mix too much epoxy at once. It's an exothermic chemical reaction, it's hot outside, and the 205 and 206 hardeners are pretty fast as it is. The pumps are great - syringes work well for precise measuring, too.
    If anyone reading this does decide to use polyester resin (it's good for part fabrication), just use the amount of catalyst recommended by the manufacturer. It's a catalyst, not an addition reaction component, and you just need enough to kick off the chemical reaction that has already been iniated at the resin plant. Variations within a small range will increase or decrease the speed of the chemical reaction, but any physical variations in the cured resin are indicative of overly lean or rich catalyst mix, and the lamiinate is probably no good. Too much hardener, for instance, will make the reaction progress too fast, causing excessive heat and microcracking, and a permanently weak part.
    Chris
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Took my spoiler up to the boat builder to get an expert look at it when I picked up my epoxy resin.
    He took one look & asked how long the spoiler had been cracked. I told him since last summer. He said 'thought so'.
    Turns out that the lighter lines are where moisture/ humidity crept along the filler cracks & caused the resin to lighten. So they aren't cracks in the fibreglass substrate after all.
    Will post a picture as soon as I get a chance.
    His bottom line was that it was ready to fill in the low spots & a few voids in the resin & refinish!
    So, a couple of days work should have my car back on the road!!! Now if the weather will just stay cool enough so I can finish this weekend, I'll be driving again!!!
    I want to thank all of you for your advise & suggestions.
  15. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Excellent discussion guys and thanks for the vote of confidence Mark.
    Verell,
    The first pharmacy I tried wouldn't sell me syringes due to store policy, but offered me free oral medication syringes. I asked for ant they actually gave me 10, as I didn't know how they would hold up to the methel ethel ketone peroxide (MEKP) catalyst. When I looked at syringes closely, I could see that I would have trouble withdrawing hardener from the 12 cc bottle, so I went to another pharmacy, which allowed the sale of diabetic syringes without a perscription. The advantage of the needle is that it will reach into the fluid without having to immerse the tip of the body.
    Syringes of all types seem to be readily available on ebay. Of particular interest are catheter tip syringes with an elongated and tapered large bore. I believe one could easily slip a flexible tube onto the end and withdraw resine from a quart or gallon container. They are readilly available in 30-140 cc capacities, so are appropriate for metering small to modest batches of unmixed resin.
    In the past, I always used 15-drops of catalyst per ounce of resin as a starting point for polyester resin. For my latest perchase of resin, the mix ratio was specified in tea spoons per quart, not the usual volume units. The mix ratios at 70 F were:
    slow gel: 20 minutes or more 1 teaspoon/QT which I calculated to be 1:193
    medium gel: 15-20 minutes 2 teaspoons/QT 1:97
    fast gel: 10 minutes 3 teaspoons/QT 1:64
    My Marks Handbook says 1 oz = 6 teaspoons = 29.6 cc's
    1 QT = 946.4 cc's
    So for one once of resin, at a medium gel recipe, I get: 29.6/97=0.305 cc of catalyst.
    I hope I did my math correctly, but the results worked ok.
    The first batch I mixed up was to the medium gel ratio target of 0.30 cc's per oz. I actually metered out 0.32 cc's. The cure was on the slow side for my liking so I upped the next batch to between the medium and fast (0.46 cc's) target. I used 0.40 cc's of catalyst. The residual mixture was just starting to jell in the mixing cup as I finished the last of this small layup, so this was just about right.
    The thing to remember is that a large batch will begin to gell quicker than a small batch, not only in the mixing cup, but also in the layup. Since I was only laying up 2-layers, the repair cure was a little slow, but I speeded it up with a heat lamp. Had I laid up more than 2-layers, then the repair cure would have been faster.
    Bill
  16. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Some of those marks turned out to be shallow cracks after all. When I wiped the surface down with lacquer thinner, I could see the cracks if I got the light just right. Realized that what I needed was the equivalent of a magniflux test to find out which marks were just moisture, & which were true cracks.
    So I took a red paint stick & drew a thin line along any crack that was suspect. After giving the paint a couple of minuites to penetrate, I wiped the surface paint off with a paper towel, then with one dampened with lacquer thinner. Sure enough, this made about 1/3 of the cracks very visible, & the rest were just moisture marks. The cracks appeared to only penetrate the clear top layer of resin & stop as soon as they reached the top layer of fibreglass.
    If I'd had some red lacquer I'd have thinned it out quite a bit so it would have pentrated quicker & deeper, and would be easier to remove. Ink would probably work quite well also.
    I used a dremel sanding drum to sand out the cracks into a semi-cylindrical cross section. Used paint again to verify that as soon as I'd sanded out the light colored mark, I'd gotten all the crack.
    Then used my 'finesse' DA sander's 3" pad to feather the edges of the ground out cracks. It looks like a single layer of fibreglass fabric & resin will be enough to fill in the cracks. I'll cut strips about 1" wider than the area to be filled & sand the excess off after it's cured a couple of days.
    Am kicking myself because I forgot to take pictures of all of this.
    So, thanks again, I can take it from here.
    Bill,
    I've got a 60cc catheter tip syringe that I use for resin as you describe.
    I've been buying resin in pints or quarts so it comes with a tube of MEK hardener. If I'm careful in trimming the end off of the hardner tube, the feeding syringe's nub will fit inside & I can turn the tube upside down & suck material into the syringe. Otherwise I pour some of the catalyst into a 1oz medicine cup & suck it up into the syringe. Then can use the syringe to squirt any excess back into the tube. I loose a drop or 2 this way, but so what.
    Also, a silicone tube fits nicely over the end of the feeding tube syringe for sucking stuff out of containers.
  17. SpannerMan
    SpannerMan Karting
    Nov 7, 2005
    116
    San Diego
    Erik Rathmann
  18. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I wish such an animal was available as a simple bolt-on for the 308 long front spoiler. I have some black HDPE (High Density Polyethylene Plastic) sheet that I've been meaning to make a template for and cut for that same purpose...
  19. Dr Tommy Cosgrove
    36,232
    Birmingham, AL
    Tommy
    My trick was to swap to the US version.
  20. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
  21. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Actually, a skid plate wouldn't have helped this time. It's a long story, but my car got away from me while pushing it up on the boards I use to get the height for my lift arms. It rolled off of the rear boards & launched itself over the stop bumps on the front boards & into the brick steps of my garage.
    The bottom of the spoiler actually cleared the lower step & the front edge of the spoiler came up against the vertical riser for the 2nd step. The front edge of the spoiler only had a couple of chip. However, the impact flexed the spoiler back enough to crack the thick filler on the large flat area above the front edge.
    However, a skid plate is cheap insurance.
    I'll be making one out of the tropical hardwood plywood the racers use. Can't think of it's name, something like Jabra I believe.
    Steven Rochelin had KTR make one out of it for his car's new spoiler, & I was over there & it looked pretty good.
    Probably what I really need is a spoiler made out of the somewhat flexable plastic that most car mfgs use for spoilers & bumper covers these days.
    Or maybe I just shouldn't be pushing my car into the garage at 1:30 AM in after working on another car from 5:00PM until then. Saying I was exhausted & a bit punchy at the time is an understatement.
    However, I'll just work with what I've got for now & apply the skid plate.
