FF with capristo x-pip | FerrariChat
Discussion in 'FF/Lusso' started by jerry430, Jan 21, 2015.
  1. jerry430
    jerry430 Karting
    Apr 13, 2010
    161
    Hi,
    i am wondering if anyone has done the capristo x pipe on their ff with the stock exhaust. thank you
  2. FFMAC
    FFMAC Formula Junior
    Jul 20, 2012
    397
    Mac
    I have the Capristo X-pipe and exhaust. Sounds amazing! Can't comment on what the x-pipe alone with standard exhaust would be like. Probably not much of a difference I'd imagine. It's supposed to produce an F1 type wail at high revs with Capristo's exhaust. :)
  3. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,124
    Toronto
    Joe
    I was looking for this.. looks incredible!
    Ferrari FF
  4. FFMAC
    Jul 20, 2012
    397
    Mac
    Do it! Sounds incredible! I could never go back :D
  5. Vic55
    Vic55 Karting
    Sep 21, 2014
    58
    THE Orange County
    I just had my FF up on the rack--- the location where the x pipe would go already has an efficient H pipe (no resonators). Based on that view and my techs knowledge I dont think the X-pipe alone would do anything (negligible at best) soundwise.
    The best bet is to swap the cans.
  6. ttforcefed
    ttforcefed F1 World Champ
    19,216
    I went novitec exhaust, hi flow cats, x pipe and it literally sounds insane
    switch from sport to comfort and it sound stock
  7. rmitchell248
    rmitchell248 Formula 3
    May 26, 2013
    1,071
    Nürburg
    Robert
    did you do the Novitec ECU Update to make the Manettino work like that?
  8. ttforcefed
    19,216
  9. jerry430
    jerry430 Karting
    Apr 13, 2010
    161
    my local ferrari tech told me the sound will change a lot if i change the x pipe cuz it remove the secondary cat....
  10. ttforcefed
    19,216
    yep it changed it bigtime - for the better in my opinion
  11. mjeagent
    mjeagent Karting
    Aug 17, 2012
    119
    Northern Virginia
    Curious. How much are F dealers charging to do capristo/novitec exhaust work? I've been eyeing this upgrade but not if the dealership is going to bend me over. Don't trust any other local shops to do the work either.
  12. ttforcefed
    19,216
    dealer? ugh that's painful
    why not send the car up here
    Bradan or P1
    lots of people send their cars to them
  13. jerry430
    jerry430 Karting
    Apr 13, 2010
    161
    dealer charge me $800 to install the Ipe exhaust for my f12 so it should be around the same
  14. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    what about just the capristo rear box and no x-pipe, anyone done that?
  15. rmitchell248
    May 26, 2013
    1,071
    Nürburg
    Robert
    Did you tune just the Manettino settings or also the full ECU?
  16. rjn21
    rjn21 Karting
    Dec 3, 2013
    192
    There are no secondary cats in the factory "x pipe". It is just a H pipe (ie 2 plain tubes connected in the middle). For FF, swapping the X H or whatever central pipe will make negligible difference sound and/or power wise. Swapping the cats to 200 cell will make a difference, and swapping the muffler boxes will also help, although with the valves open its nearly (but not quite) straight through anyway. Biggest delta will be from the cats and the muffler cans will add a bit.
  17. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    In your opinion, would there be a big difference if one was to only replace the rear boxes and not change the cats or swap H for and X pipe?
  18. rjn21
    rjn21 Karting
    Dec 3, 2013
    192
    Depending on rear muffler manufacturer, you would certainly get some increase in noise. It would be noticeable. Personally I wouldn't reconnect the valves on the replacement muffler, but I prefer it LOUD all of the time.
    Entirely my subjective opinion, and I have seen no proper comparison tests, any increase in power from a muffler change would be negligible.
    For the x h pipe swap, having done it, I wouldn't bother again. It made no difference as far as I could tell re power or noise. It was a bit lighter and looked prettier (not that you can ever see it again one installed).
    Most increase in noise came from the cats, but they are not a simple install.
  19. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Thanks a lot. I have capristos on my F12 and love them - keep them open all the time. I'm taking delivery of an FF this coming week and can't decide whether or not to put capristos on it as it will be a daily driver, wife and new born (soon) as regular passengers.
  20. ttforcefed
    19,216
    I got the full ECU tune and I specified that I wanted valves always open with manetinno in sport. if you don't specify the valves just open quicker in sport. So my comfort setting is oem and obviously very driveable, u don't even know the car has an exhaust until you heavy throttle it. then in sport the valves are always open.
    https://www.facebook.com/video.php?v=637631473021110&set=vb.217589571691971&type=2&theater
  21. rmitchell248
    May 26, 2013
    1,071
    Nürburg
    Robert
    Thanks for the information. I would certainly want it always open in sport mode. What do you feel about the tune? What have you noticed performance wise?
  22. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    When I installed the Novitec mufflers, I opted to keep the factory software control on the valves. I usually drive the car in Sport over long distances and prefer the valves closed for cruising. However they will open in Sport at about 2500 RPM which translates to about 85MPH in 7th.
  23. ttforcefed
    19,216
    car has a bit more pep. tough to really differentiate between 670 and 700 hp
  24. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    I have sometimes wondered how much difference you can actually perceive in these high hp cars. I know that I could easily tell 55 hp difference out of 620 in my old BMW X5M. The Dinan software that turned up the boost added this much hp, and occasionally the dealer would accidentally uninstall it when I brought it in for service. I would take car out and could tell right away, bring it back, and they would reinstall it. So I imagine 30 hp would be on the edge but perceivable.
  25. rmitchell248
    May 26, 2013
    1,071
    Nürburg
    Robert
    The X5M more than the 55 hp I'm sure you were feeling the 100 + lbs of torque in the midrange. We won't see anything like that in an NA motor.
