FF Transmission appears to be leaking | FerrariChat
Discussion in 'FF/Lusso' started by turbosonoma, Nov 5, 2018.
  1. turbosonoma
    turbosonoma Karting
    Sep 17, 2010
    69
    White rock
    Brad
    Shortly after my last epidose of fixing the leaky lift pump I noticed a sizeable a puddle in the same area of the garage floor, but atleast a different fluid this time! Apparently this is a common issue for a drip to come out of some vent hole on the bottom of the transmission. Does anybody know what the actual fix is short of installing a new transmission? Much like the lift pump im sure it is repaired with a 10 cent seal but im far from a transmission tech....
    Which other vehicles use the same version of getrag transmission?
  2. turbosonoma
    turbosonoma Karting
    Sep 17, 2010
    69
    White rock
    Brad
    I thought these leaks were a known issue, does nobody know anything about these?
  3. otakki
    otakki Formula 3
    1,634
    Is the car throwing any error codes?
  4. turbosonoma
    turbosonoma Karting
    Sep 17, 2010
    69
    White rock
    Brad
    No. It works great. But I guess only until it runs out of fluid completely!
  5. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,329
    The Netherlands
    I wasn't aware of transmission leaks being a known issue. I did a lot of reading around before buying my FF and leaking transmissions didn't come up as a problem.
    On a side note, has your fix for the lift pump worked?
  6. CrazyMD
    CrazyMD Formula Junior
    Mar 10, 2012
    404
    Southern California
    Still hoping you can tell me where you got your lift pump seal from
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,338
    Frederick, Maryland
    Brian Brown
    It is not a common issue for DTC transmissions to leak any oil. If there is any oil leaking then there is a problem with the transmission. There is an internal seal leaking inside the transmission. The weep hole is there to let you know that this seal is leaking, instead of just leaking from gearbox portion into the hydraulic portion without you knowing that there is a leak. Unfortunately Ferrari/Getrag does not sell seals separately, and you have to purchase the entire housing casting/repair kit in order to get the seal. Someone with the proper training and the factory special tools will need to disassemble and replace the leaking housing/seal. Not a repair for the inexperienced.
    Doug., maor1827, ryalex and 5 others like this.
  8. turbosonoma
    turbosonoma Karting
    Sep 17, 2010
    69
    White rock
    Brad
    I got it at a local joint called fluid seal that speacialize in all types of seals. I think they even have an online store, but im sure there is a similar business much closer to you.
  9. Eurofed
    Eurofed Rookie
    Apr 16, 2019
    1
    John Jovaneli
    We have a FF in that is leaking from the weep hole, pretty significantly. We have special tools and the table to remove the engine, but are unsure which seal kit to purchase for the repair. We are on Scuderia parts and see many different levels of overhauling available. Anymore information on this issue would be greatly appreciated Motob!
  10. turbosonoma
    turbosonoma Karting
    Sep 17, 2010
    69
    White rock
    Brad
    I never fixed mine, but really need to, Please keep me posted what you come up with!!
  11. isellair
    isellair Rookie
    Oct 2, 2018
    16
    I am having a similar problem on my 2014 FF. I was told the leak is in the middle gearbox. Ferrari said they had to actually replace the center gearbox. My question is why cant that component be repaired instead of replaced. My car runs and driver well. The only issue is it leaks oil from the weep hole. Any help would be appreciated
    I am having a very similar problem on my 2014 FF. I was told by Ferrari that my leak is coming from the center gearbox from the weep hole. The leak is pretty bad. Ferrari told me the center gearbox needed to be replaced. I would like to know if the internal problem can be repaired instead of replacing the center gearbox. Any help would be greatly appreciated.
  12. LeoBRK
    LeoBRK Formula Junior
    Sep 26, 2010
    454
    NYC
    Leonardo
    center gearbox replaced, is that covered under power warranty?
  13. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    524
    I know of the rear DSG gearbox and The front PTU gearbox, but what is the center gearbox?
  14. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    What are you guys doing about these leaks and what is the cost? Mine just started to leak. Thanks
  15. Bamsefar
    Nov 26, 2012
    524
    No oil leak so I don't understand this at all.
  16. ttforcefed
    ttforcefed F1 World Champ
    19,216
    we need a sticky for DCT and PTU issues
    ryalex, sakyubasu and papou like this.
  17. JohnDxb
    JohnDxb Rookie
    Apr 10, 2019
    8
    Jonathon Lewis
    My 2014 was in for leaking DCT earlier year. Failed seal inside the box.
    Symptoms were a massive leak but no warning lights.
    All fixed under warranty.
    ryalex likes this.
  18. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Centre gearbox? Wutt???
  19. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Get a Lusso:D
  20. otakki
    otakki Formula 3
    1,634
    #20 otakki, Oct 27, 2020
    Incidental finding on my car during this year's annual service after tech removed the rear under-cover. No warning lights. DCT's slow leak causing oil stain on the cover like shown by OP on post 1. Around $4800 at dealer; including gear-box kit used to replace seal and plug leak.
  21. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    I thought the Lusso was the same DCT, no?
  22. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    That's besides the point;)
  23. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    Has anyone found a solution to replace the seal kit rather than the whole center box? The video is from my car.
  24. Nospinzone
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    Wow, that's more than leaking, that's close to flowing!
  25. JohnDxb
    JohnDxb Rookie
    Apr 10, 2019
    8
    Jonathon Lewis
    That’s exactly what happened to my box. Essentially the whole box had to be taken apart. There was a seal that had gone at the end of the box closest to the front of the car.
    sqml123 likes this.
