FF spark plug replacement | FerrariChat
Discussion in 'FF/Lusso' started by Scout123, Mar 6, 2024.
  1. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    551
    For those of you who have replaced your spark plugs on an FF, did you typically just order up the OEM plugs or, are there other plugs out there just as good, but not so pricey?
  2. Endrig
    Endrig Rookie
    Oct 4, 2023
    23
    Wyoming
    Henry Wu
    Let us know how this goes. Plug change on this motor looks to be a major job in terms of labor.
  3. sfcarguy
    sfcarguy Formula Junior
    522
    Earth
    Plugs on a V12 are expensive because of the shear number of them. The FF isn't too bad in terms of access.
    NGK 93340 is the OEM part for Ferrari 254771
    vraa likes this.
  4. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,222
    WA
    Fernando
    You still have to remove the intake plenum. I had our local Indy shop do it. I assume they used the OEM plugs.
  5. sfcarguy
    522
    Earth
    Nope plenum can stay on. Doesn't mean it's not easier with the plenum not in the way but it's not a requirement.
  6. sid12345678910
    sid12345678910 Karting
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    NGK MR8AP8HJS
  7. Scout123
    Nov 1, 2017
    551
    The OEM sparkplug part on Scooteria parts sells for $53. Finding the same plug elsewhere on the Internet between $24 and $28.
  8. Scout123
    Nov 1, 2017
    551
    Scuderia I mean
  9. ttforcefed
    ttforcefed F1 World Champ
    19,217
    Major service and plugs is like $7500 I think right?
  10. Scout123
    Nov 1, 2017
    551
    Not sure what the labor on replacing plugs will be. The plugs you should be able to buy for like $500-$600.
  11. ttforcefed
    19,217
    Plus a break flush
  12. ttforcefed
    19,217
    Oration isnt bullet proof - BRAKE flush
