https://www.eurospares.co.uk/parts/ferrari/ff-usa-/all-pages/ptu-repair-kit-61626 Sent from my iPhone using Tapatalk
How do they rebuild it worldwide? I assume one would still need to have a local indy to disassemble the PTU from the car to send to them, right?
Nobody other than Ferrari has the equipment to calibrate gears and bleed the air out of the PTU after replacement or rebuild. So keep in mind if you ever replace the PTU or rebuild it, you will have to take to Ferrari to bleed air out of the system + calibrate the gears to work in conjunction with main transmission. That can cost alone $1,500 on top of everything you already spent. I’m still working on a solution. Sent from my iPhone using FerrariChat.com mobile app
I don’t see anywhere $8,000 on that kit. That’s not realistic. This “repair kit” has been out for quite a while but nobody have come up with what is causing the PTU to fail nor what is the defective part to replace. The guy at GTE engineering gives prices anywhere from 6k to who knows! How can someone send a PTU to him without an accurate estimate? Worst than that, he does NOT give any warranty. So you will spend that much money and have no warranty it will work? Sounds too tacky, sorry! I’m working to find out what is causing the problem and I’ll report back soon. Sent from my iPhone using FerrariChat.com mobile app
Have admired your diy spirit, especially in spite of being ridiculed as a fear-monger. I'm sure by now those are bygones... This was mentioned briefly a few times above and I wanted to add my experience. I have another account here but I can't remember the password and chrome defaults to this one. Anyway, the speed sensor in my gearbox failed spring of 2018, full cost around ~18k. Out of warranty but no problem I knew it could happen. Fast forward to this February and took car to first indy for annual. The mechanic really admires FFs and wanted to chat about them. I live in a very unfriendly people are too cool to wave black baseball cap and sunglasses region of the us, so this was cool. When I told him my love of the car despite 1) DCT failure and 2)potential of PTU failure , the tech quickly said: "someone's already been in there." The dramatic law and order scene change music was at that moment piped into the room. Second owner car purchased in 2016 from Ferrari dealer. This suggests Ferrari dealer is poor at diagnosing DCT failures , as late as 2018, and was mucking about in the ptu. Or ptu failed with owner #1 at under 5k miles. Or they said they fixed the dct in 2018 but it was actually Ptu. I suppose it's also possible that when the car was consigned they fixed it as a precaution, knowing it was a problem. Chances of that are 0% I would imagine. For those keeping track.
It seems quite unlikely that it failed that early, so far the earliest anyone has reported a failure was gilly6993 at 5000 miles. The average failure is around 17,000 miles. I think your post brings up an interesting point though. There frequently seems to be some confusion between DCT and PTU failures/repairs. I'm wondering if this is causing the PTU issue to be under-reported, or perhaps over reported. There do seem to be a number of DCT fialures, and they don't seem to generate much buzz. That might be because its not an FF/Lusso specific component and therefore is more 'normal'. I've had a couple people on my list of PTU failures only to late take them off when it turned out it was a DCT failure. Speaking of which, here is an update. I did add CLG although after re-reading his post I'm wondering if that was actually the DCT. I didn't add yours though as its not clear if that was actually a failure. Image Unavailable, Please Login Redline is average failure, gray bar is standard deviation.
The average failure mileage is right on the money for my * DCT* failure, almost to the number. There was buzz about the DCT failures, which was why I took in it stride, and it was my understanding that these speed sensor failures weren't exclusive to the FF (or even Ferraris if I remember right ? Not sure). I mentioned the confusion of what has failed and what was actually fixed because it was mentioned above, to do with a swedish (was it?) translation of the word gearbox and to which it referred and suggestion of suspicious fluid replacement. Part of the question would be who is confused ...and is any information being withheld etc. And I don't mean that dramatically. As I said it could be something as simple as not being well trained and looking all over to diagnose an issue. When my DCT failed it took a long time for them to tell me what was up. Which may explain Indy reporting the dealer had at some point been in the PTU.
Sorry: my number was high. I added two rear tires also thats how I got to 18. (USD). Here's the body so you people can get a second hand arousal Since it’s a bit difficult to get each other on the phone I’ll do my best to describe through an email what’s going on with the car. After looking into it, it was discovered that you have a faulty “speed sensor” The speed sensor is a individual part that is located inside the transmission/gearbox. I regret to inform you but this part requires the entire transmission/gearbox to be removed and dissected in about 30 different pieces. Luckily that part is sold separately and is available through Ferrari North America in New Jersey. Here is the break down. · DCT Speed sensor $1858.10 · DCT fluid $ 460.00 · Gear box fluid $ 245.20 · Cooler O-rings $ 44.50 · Sealant/liquid gasket $ 122.80 · Coolant/ Antifreeze $ 40.00 X2 + $ 80.00 · Labor charges for disassemble and re-install $ 11.100.00 Total cost of $ 13,911 + tax
Also for public record. Never launched my car in five years ownership; as a rule have a kind of virginity complex with cars (compensation for the souls with whom I share my bed). So gentle use won't save you. And car is a 2012. And yes I do still love it enough to take it from me would require prying from my dead lifeless fingers. The worst part of ownership nowadays is being forever raced by Teslas. Gets old. In a big way these I.C. performance cars are obsolete when Newport Coast third wives blast past with their status anxiety. Time will help: the more antique it gets the less of that there will be. . Can just enjoy it
Your experience is recorded repeatedtly in Rainman style with a few exceptions in previous 13 pages. All due respect but jeez.
here is what wld make this thread more productive - if you have had a PTU actually go and need replacement: post the miles, parts changed, and price paid.
Read above. I have a second handle kenwidmerpool but I get it. Gatekeeping makes people happy etc. The enthusiasm of the gatekeeping though. Your comments over these 14 pages have been super helpful. I'll walk myself out and forget the password to this handle also. Other interests blah. I'm surprised i was so unhelpful but I really thought ttforce kept repeating his great luck for 14 pages to the point that an objective reader would likely wonder if it's a troll.
Maybe kenneth and why I can't login. Ha. I'm no power user of this forum. But the seniority rubbish is nonsense. I want to talk about this thread and the relationship between PTU and DST failures. And I don't think that was inappropriate. Some of us raised with tech and working on tech throttle our forum use. Because it can be negative. The seniority card silences. You were well represented in this thread. Let it go.
Now that would be terrific! The 'Rainman style' comment was 100% unnecessary. Now, you let it go and get back on topic!
