Hi, Does anyone know how to have valves always open on the FF ? Can we unplug vacuum line ? Is it easy to access ? Thanks a lot
nope it is quite hard. I begged service 3 times to do the job. They told they removed quite alot of rear bumper assembly to get to valves. I assume removing bumper might be easier than removing inner wheel arch protection thing.
I'm leaning heavily in this direction. I'll contact dealer this week for more info and total cost for install. Then Ill see if I can't post some pics and before/after video. BTW, to me the exhaust sounds perfect when on the throttle, I'm just trying to turn the volume up a bit at startup and slow rolling idle.
Put on lift, loosen rear undertray section (no need to remove completely), put hand up into exhaust muffler section pull off the blue vacum line. Takes at most 10 minutes inc getting the car on and off the ramp.
