Ferrari V8 engine dimensions/specs | FerrariChat
Discussion in 'Technical Q&A' started by The Dark Side of Will, Jan 13, 2017.
  1. The Dark Side of Will
    May 24, 2012
    18
    NoVA
    William Lucke
    I'm having a hard time finding actual numbers.
    What is the block deck height?
    I've found rod length is 137mm.
    Does anyone have big end width and pin diameter handy?
  2. GordonC
    GordonC F1 Rookie
    4,153
    Calgary, AB, Canada
    Gordon
    There's been more than a few Ferrari V8 engines over the past 40+ years.
    For which one specifically are you looking for information?
  3. The Dark Side of Will
    May 24, 2012
    18
    NoVA
    William Lucke
    Sorry... stuck in my own little world. Dino family V8's, specifically the 3.6
    And of course I can't go back and edit my original post at this point. Lame.
  4. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,624
    Manning, SC
    Robert G. Zambelli
    3.6?
    As far as I know, there were 2.0 and 3.0 engines in the early Ferrari/Dino cars.
    I believe the 3.0 Quatrovalvole became the 328 (3.2 liters)
  5. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,243
    Worcester, England
    Phill J
    Despite what wiki might say, the V8 engines are not really known as being "Dino" engines in the Ferrari community - The "Dino" engines are seen as being the V6 engines because that is what Alfredino Ferrari actually worked on.
    The V8's shared design characteristics with the V6 engines (and the V8 engined 308 GT4 model was originally badged as a "Dino" before later being badged "Ferrari"), but the V8's have always been seen as being a Ferrari engine - Not a "Dino" engine.
  6. The Dark Side of Will
    May 24, 2012
    18
    NoVA
    William Lucke
    Calling them Ferrari V8's above didn't have the desired result.
    It's also easier than typing "the 2.0/2.8/2.9/3.0/3.0/3.2/3.4/3.5/3.6 family"
  7. tazandjan
    39,019
    Using Wikipedia as a source on Ferraris will lead you to all kinds of misconceptions.
    How about something simple, like does anyone have dimensions on the 360 engine?
    The 360 WSM probably has most of what you need.
  8. The Dark Side of Will
    May 24, 2012
    18
    NoVA
    William Lucke
    Is that available or download?
  9. tazandjan
    39,019
    William- Affirmative, and if you cannot find it, I can send you a DVD.
  10. boxerman
    boxerman F1 World Champ
    19,526
    FL
    Sean
    Is not the 308Gt4-360 essentialy derivations of the same motor.
    Out of curiosity what does a 360 motor weigh compared to a LS7 and what were the dimensional differences.
  11. tazandjan
    39,019
    Sean- There are similar design features, but comparing a 5 valve per cylinder engine with a two valve is stretching it a bit. The early V8s actually have some commonality with the Daytona engine, except for a few obvious differences. All are cast aluminum engines with wet liners and DOHC heads that follow a similar design philosophy along the lines of the Jano engines.
  12. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I've shipped both recently and I believe the 360 engine is 406# vs. about 460# for the LS7. I don't have the exact deminsions but I know the 360 engine is very tall compared to the LSx engines. The runners on the 360 Intake are tall.
  13. Rifledriver
    36,760
    There are deck height and connecting rod dimension differences along the way too. Just the numbers he was looking for. Making such vague information requests hardly makes answering a question easy, something that is incumbent on the seeker of information.
  14. The Dark Side of Will
    May 24, 2012
    18
    NoVA
    William Lucke
    I did find the manual available for download, and while it does have dimensions for the conrods, it does not list the block deck. I was told elsewhere the 3.0 & 3.2 block deck is 204.2mm. If the 360 had the same deck height, 39.5mm crank throw and 137mm rods, then it would have to have a 27.7mm piston compression height, which is *VERY* short. Since 360 pistons are also significantly dished, I suspect the 3.6 has a bit more deck height than the 3.0/3.2.
    Interesting how difficult some pretty basic numbers are to find.
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,066
    Dumpster Fire #31
    SMG
    360 piston: (gudgeon) wrist pin center to crown deck is 27mm.
