Ferrari oil filter wrench? | FerrariChat
Discussion in 'Technical Q&A' started by randomlambo, Dec 30, 2013.
  1. randomlambo
    randomlambo Formula Junior
    Feb 3, 2013
    379
    RI & MA border
    DT
    What is the size of the 348/355/360/430 oil filter (Purflux LS925) -- and are there any wrench alternatives to the Hill Engineering $100 one?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    You missed the sale...
  3. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    I found the one from Ultimate Garage for $32 made by Facom which would be an alternative.
    Is the USAG D156 discontinued?
  4. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
  5. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    Fantastic Joe, I knew the Brit eBay would come to the rescue as they have their head on straight regarding parts costs over there :)
  6. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  7. Joegnsx
    Dec 1, 2012
    958
    Joe Gliksman
    Pretty sure that tool on Amazon is not the same, although it may fit. From what I've read, the tool is also for installing the new filter with some significant torque. The one I have is made for the Purflux filter which of course has a unique design (the notches for the filter anyway).
  8. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    It works perfectly on the 360 purflux. Sure it's not a day-in-day-out workshop tool but for an occasional DIYer it is fine although only a 3/8" drive. No problem with torqueing up.
    I'm only trying to give the OP options.........
  9. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Agreed, that Laser tool works perfectly well and the torque required is quite low. It would probably last a professional a life-time never~mind the DIY'r.
  10. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    I'm sure any 86mm wrench with 18 notches would work great. Would have bought the Laser one except that I ended up getting the UK eBay one last night...thanks everybody.
  11. Tom y92
    Tom y92 Rookie
    Sep 24, 2013
    41
    New port richey fla
    Tom y
    Try using a strap wrench.They work great.
    SupercarGTM and lm2504me like this.
  12. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Will not work on the 360 and 430. You need to buy that filter tool, period. Money well spent, trust me. Buy the $32 one and be done. It costs half as much as an oil filter. Give up Starbucks for a week and you are there.
  13. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,522
    Jeff
    #13 348Jeff, Dec 31, 2013
  14. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    For those stateside, check Pep Boys and Autozone as well. They have a host of steel oil filter wrenches available in different sizes, all for 3/8" drive and around $10.
    I don't remember off-hand if the Pep Boys near me had an 86mm /18 flute when I was looking a month or so ago for another car I own. But, they had the size I needed that day.
  15. Joegnsx
    Dec 1, 2012
    958
    Joe Gliksman
    I tried all the auto stores around Central FL and never found the right wrench....that would have been great! I must agree with Yelcab, the job really does require it--none of the many wrenches I have for other cars worked very well.
  16. tazandjan
    39,007
    Make sure you use a torque wrench when installing the new filter, now that you have a filter socket that will work. 25 Nm/18.4 lb-ft.
  17. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    803
    Orchard Park NY
    Bruce Roche
    For a 575 I got mine from Ricambi. It will stay with the car if there is a next owner for the car. GTS Bruce
  18. GTO Joe
    GTO Joe Formula Junior
    997
    Charlotte, NC
    Joseph Troutwine
    Interesting, these are available on US Amazon for a little over $7 but the shipping is almost $10 more. Best to try and find one local if possible. Used on certain VWs as well so should be around. I have one of the Facom units and they are very good but a lot more expensive.
  19. clex2
    clex2 Karting
    Aug 30, 2009
    103
    #19 clex2, May 20, 2017
  20. gvanrenterghem
    gvanrenterghem Karting
    Jul 12, 2023
    67
    FYI, bought the Beta Tools 1493pF 86mm and it is a piece of junk with the filter not fitting comfortably in it meaning you need to force the filter in and then it is extremely difficult to get the tool off the filter => Garbage.
    I have used Facom tools forever, always satisfied with them so will buy a Facom d.156 and see if that does better.
  21. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Qavion likes this.
  22. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Hill Engineering makes an excellent tool...
    f355spider likes this.
  23. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    LOL....here is one review which affirms what I stated here:
    Qavion likes this.
  24. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
