Ferrari Mondial VIN | FerrariChat
Ferrari Mondial VIN
Discussion in 'Mondial' started by soucorp, Jan 31, 2012.
  1. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #1 soucorp, Jan 31, 2012
    This is the best VIN explanation that I have found so far that I wanted to share:
    1st digit = country of origin
    The first digit identifies the vehicle's country of origin. Italy's letter is "Z," therefore, all Ferrari VINs will begin with the letter "Z".
    Z = Italy
    2nd + 3rd digit = marque / manufacturer
    The second and third digits identify the marque and manufacturer. To date, Ferrari SpA has been assigned and used only two codes
    DF = the Dino
    FF = the Ferrari marques manufactured by Ferrari SpA.
    The Dino marque has not been produced since 1980, therefore "FF" will appear in the second and third place digits of all Ferrari VINs, unless you are looking at a Dino.
    4th digit = Engine
    With only 26 letters available, it was necessary to recycle some of the letters. Always consider the entire 17 digit VIN to determine the type of engine, especially the sixth and seventh digits
    A = 308 2-valve injected (U.S.A.model)
    B = 308 2-valve carb wet sump (Euro.model)
    C = 308 2-valve carb dry sump (Euro.model) + 328 European
    D = 512 Boxer carbureted
    E = 400 V-12 fuel injected
    F = 308 Australia + 348 U.S.A. / Japan
    G = 308 2-valve carbureted USA/Japan + F40 European
    H = 308 2-valve injected European
    J = 512 Boxer injected
    K = 208 Turbocharged European + 348 European
    L = 308 4-valve European + 512 TR European
    M = 308 4-valve U.S.A. 1993 + F40 U.S.A.
    P = F355 + 288 GTO
    R = 348 U.S.A.
    S = Testarossa U.S.A./Japan + 456
    T = Testarossa European
    U = 308 4-valve U.S.A. ( 1984-1985 )
    V = 512M
    W = 328 European
    X = 328 U.S.A. / Japan
    Y = 412 V-12
    Z = 550 Maranello
    5th digit = Safety system
    A front 3-point inertia belts
    B front 3-point inertia belts; rear 3-point non-inertia belts
    C front 3-point inertia belts; rear 2-point inertia belts
    D front 3-point inertia belts; rear 3-point inertia belts
    G passive restraint system
    P front 3-point inertia belts and air bags; rear inertia belts
    M passive restraint system
    N automatic passive restraint system
    R front 3-point inertia belts and air bags
    6th + 7th digits = vehicle model / body type
    01 308 GT4 (ZDF) & 308 GTBi (ZFF)
    02 308 GTBi
    03 308 GTB
    04 308 GTS
    05 512 BB
    06 400i automatic
    07 400i 5-speed
    08 Mondial
    09 512BBi
    10 208 Turbo (B)
    11 208 Turbo (S)
    12 308 GTB Quattrovalvole
    13 308 GTS Quattrovalvole
    14 Mondial Quattrovalvole Coupe
    15 Mondial Quattrovalvole Cabriolet
    16 288GTO
    17 Testarossa
    19 328 GTB
    20 328 GTS
    21 3.2 Mondial Coupe
    24 412 automatic
    25 412 5-speed
    26 3.2 Mondial Cabriolet
    27 GTB Turbo
    32 Mondial T Coupe
    33 Mondial T Cabriolet
    34 F40
    35 348 B
    36 348 S
    40 F512M
    41 F355 Berlinetta
    42 F355GTS
    43 348 Spider
    44 456 GT
    48 F355 Spider
    49 550 Maranello
    50 456 GTA, 456 M GTA
    51 360 Modena
    52 550 Barchetta Pininfarina
    53 360 Modena Spider
    54 612 Scaglietti
    55 575 M
    56 Enzo
    57 Challenge Stradale
    58 F430
    59 F430 Spider
    60 599 GTB Fiorano
    61 Superamerica
    62 FXX
    63 F430 Challenge
    64 430 Scuderia
    65 California
    66 Scuderia Spider 16M
    67 458 Italia (but these two digits are now the 4th and 5th digits!!)
    68*
    69
    70 599 GTO
    8th digit = market
    A USA (left-hand drive)
    B Europe (left-hand drive)
    C UK (right-hand drive)
    D Australia (right-hand drive)
    J other left-hand drive
    S other left-hand drive
    T Middle East (left-hand drive)
    9th digit = check digit (used by law enforcement agencies)
    The ninth digit is a check digit used by law enforcement agencies to ensure that the VIN is valid. By using a very complicated formula involving the entire VIN, a law enforcement officer can determine if the VIN is correct for the vehicle being checked. Occasionally a letter, rather than a number, will appear in this space, but it will usually be a number between 1 and 9. In some cases, this number will be a zero on vehicles that were built for markets outside of the United States.
    10th digit = Is used to designate the year model for vehicles produced for the U.S. market.
    A = 1980
    B = 1981
    C = 1982
    D = 1983
    E = 1984
    F = 1985
    G = 1986
    H = 1987
    I = NOT USED
    J = 1988
    K = 1989
    L = 1990
    M = 1991
    N = 1992
    O = NOT USED
    P = 1993
    Q = NOT USED
    R = 1994
    S = 1995
    T = 1996
    11th digit = assembly plant
    The eleventh digit is used to designate the company's plant location where the vehicle was produced. This digit should always be zero, since all Ferraris are produced in Maranello, Italy.
    0 = Maranello, Italy
    12th --> 17th digit = production number
    The twelfth through seventeenth digits are production numbers in sequential order. This number should allow you to determine when the vehicle was produced in the production run.
    When purchasing a used, Ferrari one should carefully compare the VIN against the different vehicle components.
    If the VIN indicates that the vehicle should have a fuel injected 4-valve motor, while in fact it has a carbureted 2-valve motor, you can safely assume that the motor has been changed out in this vehicle. This would adversely affect the overall value of the vehicle and your future investment.
    It is very important that the VIN is correctly shown on all documents, (registration title, insurance papers, etc.) concerning your vehicle.
    The data on this page was obtained in part from the 59th annual edition of the National Automobile Theft Bureau handbook for Law Enforcement and an article which appeared in the Ferrari Market Letter.
  2. Marcel Massini
    Honorary
    Mar 2, 2005
    22,915
    Here's a little more about the 6th and 7th digit:
    51 360 Modena
    54 612 Scaglietti
    55 575 M
    56 Enzo
    58 F430
    59 F430 Spider
    60 599 GTB Fiorano
    61 Superamerica
    62 FXX
    63 F430 Challenge
    64 430 Scuderia
    65 California
    68
    69
    70 599 GTO
    Marcel Massini
  3. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
  4. ukshooter
    ukshooter Rookie
    Jul 5, 2011
    47
    Crowthorne, UK
    Ian Morgan
    Perfect, just been checking mine and it all makes sense.
    ZFFLC15C000057599
    UK Right hand drive QV Cabriolet with the 308 Engine with 3 point seat belts in the front and 2 point ones in the rear
  5. TheMac
    TheMac Formula Junior
    Sep 5, 2009
    452
    Alberta
    Jon Mac
    Great write up! Cool bit of info to know now!
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #6 Wade, Jan 31, 2012
    Every time I see a list like this it I'm always intrigued. Everything I've read and heard in the past stated that the cars for the Saudi Arabian market used the same specifications (safety, emissions, etc) as the U.S. cars. However, the 4th digit, W, signifies 328 European.
    Hmm... does anyone remember the HP difference between the Euro and US cars? Or are they the same?
  7. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #7 soucorp, Jan 31, 2012
    Wade, I believe U.S. models lose ~ 5HP from the European model without cat.
    Example:
    1987 FERRARI MONDIAL 3.2 cat. Europe
    Specs of FERRARI MONDIAL 3.2 cat., manufactured or sold in 1987, version for Europe with 2-door coupe body type, RWD (rear-wheel drive) and manual 5-speed gearbox. Basic specs and characteristics: petrol (gasoline) engine of 3185 cm3 / 195.1 cui displacement with advertised power 187.5 kW / 251 hp / 255 PS ( DIN ) / 7000 and 289 Nm / 213 lb-ft / 5500 of torque.
    1987 FERRARI MONDIAL 3.2 North America U.S.
    Data for FERRARI MONDIAL 3.2, model year 1987, version for North America U.S. with 2-door coupe body type, RWD (rear-wheel drive) and manual 5-speed gearbox. Basic specs and characteristics: petrol (gasoline) engine of 3185 cm3 / 195.1 cui displacement with advertised power 194 kW / 260 hp / 264 PS ( SAE net ) / 7000 and 289 Nm / 213 lb-ft / 5500 of torque.
    1987 FERRARI MONDIAL 3.2 Europe
    Specs of FERRARI MONDIAL 3.2, manufactured or sold in 1987, version for Europe with 2-door coupe body type, RWD (rear-wheel drive) and manual 5-speed gearbox. Basic specs and characteristics: petrol (gasoline) engine of 3185 cm3 / 195.1 cui displacement with advertised power 198.6 kW / 266 hp / 270 PS ( DIN ) / 7000 and 304 Nm / 224 lb-ft / 5500 of torque.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Thanks Mike... then it's probably a toss up since S.A. cars have Euro spec engines along with one Cat.
  9. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    Wonder if your car is US spec or Euro ?
    check out the 8th digit in your VIN# = market
  10. peterdavid911
    peterdavid911 Formula 3
    Apr 9, 2012
    1,339
    London, UK
    Peter
    From what I have read in many articles including the original Ferrari sales catalogues is that the US spec 3.2 is 260 bhp and the UK spec is 270 bhp. Not sure if the Saudi Arabian spec is one or the other. Does it mention it in the handbook?
  11. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    That is correct Peter. The emissions equipment/cat converter on the US cars loses 10hp and gives my 3.2 car 260hp.
  12. peterdavid911
    Apr 9, 2012
    1,339
    London, UK
    Peter
    See you on the drag strip Mike:)
  13. BlackMondial32
    BlackMondial32 Karting
    Aug 27, 2007
    244
    i suspect, and i read that the Cams are differents
    euro cams are different from us cams
  14. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Didn't see this before. Yes, mine is "T" (see post #6).
  15. floridadoorman
    floridadoorman Formula Junior
    Jan 14, 2014
    392
    Florida
    Alex
    would anyone know what "K" would represent as the 5th digit....
    on a 1991 mondial t conv, US version?????
    Alex
  16. bbekker
    bbekker Karting
    Jan 16, 2010
    64
    Mexico
    Bas
    This site has a lot of details on VINs: Red Headed - VIN Decoder
    According to that site K = Passive restraint system on Mondial t Cabriolet, US version, >1990
  17. SonomaRik
    SonomaRik F1 Veteran
    6,882
    Sonoma, CA
    Why then "N automatic passive restraint system"
  18. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #18 soucorp, Aug 26, 2014
    the automatic refers to the running mice belts like on the 92 T where as the earlier T did not have those systems.
  19. floridadoorman
    Jan 14, 2014
    392
    Florida
    Alex
    thank you for the clarification! Cheers, Alex.
  20. Dazza72AUS
    Dazza72AUS Rookie
    Oct 16, 2020
    1
    Darren Warner
    Hi guys can anyone decode my vin and also tell me is my car Australian delivered and was also wondering what the trim color is called?
    The VIN is ZFFXE21D000085295. Thanks in advance
  21. Steve Magnusson
    25,121
    #21 Steve Magnusson, Oct 16, 2020
    Just use the decoder listed in post #1 yourself (the "D" in the eighth digit of your VIN indicates it is an Australian market RHD car).
    This website has a more complete Ferrari VIN decoder:
    http://www.red-headed.com/vin.html
    (For example, it explains the "E" you have in the fifth digit, and better clarifies the "X" you have in the fourth digit.)
  22. Mick5961
    Mick5961 Rookie
    May 21, 2019
    27
    Yip, "D" is for Australian delivered & from the VIN yours is a coupe - there were no cabs delivered in Oz until the T
    There should be a trim sticker on your brake booster in the front compartment - mine, an 86 cab ("C" UK) has a "crema" sticker on it.
    Cheers
    Mick ;)
  23. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    153
    EU
    J.Schulz
    Gentlemen, small confusion here:
    I haven a 1992 delivered US T cab and the VIN reads ZFFRK33A8N0xxxxxxx
    Whilst all other letters and numbers match above listings, the K would suggest that I have no mice, but I do.....
