Ferrari flat 12 engine stand | FerrariChat
Discussion in 'Boxers/TR/M' started by uzz32soarer, Apr 15, 2012.
  1. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
    #1 uzz32soarer, Apr 15, 2012
  2. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    The next step is to remove the engine from the sub frame. There appears to be a limited amount of ways to do this and I would appreciate it if any of you guys have pictures in your files of the various ways that people have lifted these engines, so I can get some idea of where to attach lifting harness to the engine.
    Once I have it hanging on a hook, the next thing I really need to do is turn it upside down so that I can get to these really nasty and rusty exhaust manifold bolts and this will also make it really simple to remove the gearbox.
    Normally you would use a commercially available simple rotating engine stand for this, but unfortunately, this isn't your run of the mill V8 which can be affixed to an engine stand using the bellhousing bolts of the gearbox like a chev or ford.
    I'm wondering if I pull the clutch cover off, if the bolts around the end of the block that hold the clutch on would be strong enough to hold the weight of the engine cantilevered on a 'normal' engine stand?
    Has anybody ever seen an engine stand for a flat 12 that allowed it to be rotated for assembly?
    Pictures ....................anyone???
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,244
    Mel
    #3 Melvok, Apr 15, 2012
    First ... take all extra's off ... I mean arches, wheels, springs, clutch .....
    Upside down the engine ... better not ... Never seen F garages do that; must be a good reason why not ...
    Unscrew the gearbox (gb) and then .... look very carefully inside the gb.
    Be very carefull if the gb is off ----> don't ruin the oil pipes from the engine while the sump part is not there to protect them ...
    Make a stand ... (picture).
    Are you familiar with shimming the diff ? My gb builder takes (approx.) 40 hrs to do so .............
    Good Luck ... I'll be watching this thread ... :)
  4. TRTOM
    TRTOM Rookie
    Dec 2, 2012
    21
    Chesterfield, MO
    Tom
    I am getting ready to drop my engine to do the same repair. Can you send me the plans for the engine cradle you made? Also, how hard was the differential set up? I have done it on Chevy's before but never a TR and the Chevy was hard enough. Any insight would be appreciated.
  5. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    The stand fabrication is captured in this thread:
    http://www.ferrarichat.com/forum/showthread.php?t=359951
    I'm also going to fabricate a stand based on this design for my next engine service. As for the differential, I have been watching as well and have the same level of experience as you. Put a 4:10 in my 12-bolt '69 Z-28 this past summer and was pretty straightforward, though I ended up taking it to a differential shop when I thought I was done to get a professional opinion--they made a minor shim change and all was well. This looks similar...but different. Read the WSM closely and make sure you are ready. OEM side cover shim procurement has been an issue for some, others have had them manufactured. I hope to not have to change my crown and pinon so eliminating the pinon setup will save some heartache. Search all the gearbox threads so you know what you are getting into. I plan to (like the Z) do the work myself but if I can't get the pattern perfect have a F-shop finish the installation.
  6. Melvok
    Jul 25, 2008
    14,244
    Mel
    Indeed better to do so Tim: if things go wrong with these F gb parts, it will cost you a fortune to repair that .... apart from time ...
    Good luck all ! Please keep us informed with text an lots of pics ... ;)
  7. ago car nut
    ago car nut F1 Veteran
    5,463
    Madison Ohio
    David A.
    If you don't disturb the pinion gear, is it not just a shim job for backlash and preload? Would this not disturbing the pinion gear not change the contact pattern?
    Ago
  8. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Waiting for a response, I hope you are correct, it's what I had assumed.
  9. TRTOM
    TRTOM Rookie
    Dec 2, 2012
    21
    Chesterfield, MO
    Tom
    Thanks for the link Tim! I rebuilt the rear end on my dad's 79 Vette a few years back. It was a pain in the rear to get the pinion and ring gear lined up just perfect, but luckily no whines and working perfect for the past 20 years, but still concerned about the amount of work involved with the Ferrari. I will def read a lot before I start.
  10. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    It is a shim job but a very comprehensive one. That said, do the reading, take your time and have plenty of the correct shims available and it can certainly be done at home. Both Mike and I have done our own and we are car guys but not mechanics by trade.
