Ferrari F8 Tributo | Page 220 | FerrariChat
Ferrari F8 Tributo
Discussion in '458 Italia/488/F8' started by Ferrari 308 GTB, Feb 28, 2019.
  1. MANDALAY
    MANDALAY F1 World Champ
    Owner Rossa Subscribed Silver Subscribed
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    Follow engine temp that's why I suggest auto until they are up. Up and down start and stop you are loading the engine. So the piston rings seat into the honing of the cylinder wall.
    In the picture you can see the cross hatching. This is caused from the honing operation and helps the rings "seat" during the break in process. When the term "seat" is used, it means the ring is worn down slightly, allowing it to mate to the cylinder wall, and form a seal which holds compression in the cylinder/combustion chamber, as well as keeping oil out.
    It is claimed that Ferrari beds the seat as they do go for a test drive but at the same time on the manual they ask you to follow a break in procedure.
    IMO do it. And don't mother it.
  2. mdrums
    mdrums Formula 3
    2,234
    Tampa FL
    You win for the Pista wheels...so much better than the stock f8 wheels.
    Tech Nerd, Dicecal and GT2goneF like this.
  3. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    That, I understand... It was the logic behind up and down and stop and go, that I was referring to... But it wouldn't be any different than routine driving.. In my opinion. With that said. I will follow instructions. It will be hard to not floor it. I mean, being honest here... Who has received their car and not pushed it a bit as soon as they got it? I doubt that there has been a single soul that has followed those instructions to the dot.
  4. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,247
    Bakersfield, Ca
    Mark
  5. Condor Man
    Condor Man F1 Rookie
    4,857
    Los Angeles
    Awesome car... now you just need some Stripes!
    May the Horse be with you
    Dicecal likes this.
  6. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #5481 Shadowfax, Sep 27, 2020
    The liners are usually electrosil or nikasil coated so you wont see the cross hatch. Visually the liners have a smooth dusky matt finish and the surface is extremely wear resistant. The rings see extremely minimal bed in wear and remain that way over the life of the engine due to the coating/plating on the liners. The coating is @ 20 to 30 microns and even after some many hundreds of thousands of kms is still there in the same way as it was new. The rings at that stage can show a deeper wear land but even they can still have plenty to go. Its mainly parts like valve guides, seats, and certain markings on the big ends, mains, and thrusts that can evidence degrees of wear and usage behaviour over the long haul. Turbo seals and bearings etc, and certian levels of carbon build up in manifolds and ports which can also tell a story on the use.
    These days the engines are virtually idiot proof. Itd be more likely to see a problem develop in a clutch pack or a turbo in the early stages where the engine hasnt been respected than say a bearing or ring/liner related problem.
    MANDALAY and GT2goneF like this.
  7. MANDALAY
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    Never knew the cylinders were coated . Im going to look up that out of interest. I know the pistons are like the engines ive built but they aren't made by Ferrari . Mahle makes them. They even made mine as they have excellent reputation.
    jlharlan likes this.
  8. MANDALAY
    May 23, 2013
    11,098
    AUSTRALIA
    ANGELO
    What I read up was that even after the coating is applied the cylinder
    At this time the cylinder has been coated
    to an undersize of the piston and will require a
    specialized honing process to size the bore to
    the correct tolerances.
    ELECTROSIL
    Cylinder Coating Stages
    Top:
    Typical Damaged/worn
    cylinder
    Centre:
    Cylinder coating removed and
    precision honed ready for coating
    application.
    Bottom:
    Electrosil coating applied and
    diamond honed to finish bore size.
    Electrosil
    Coating Close
    Up!!
  9. Napoli
    Napoli Formula Junior
    Nov 18, 2017
    958
    NOYB, Ray!
    Pronounced "George."
    Jo Sta7 likes this.
  10. F2003-GA
    F2003-GA F1 World Champ
    13,090
    Sunbelt
    Bro
  11. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    783
    Pete
  12. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
  13. Lesia44
    Lesia44 F1 World Champ
    17,336
  14. F2003-GA
    13,090
    Sunbelt
    Bro
    Nice but not my car just a pic I found on Instagram
  15. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    It belongs to somebody in Southern California. Pictures had been already posted.
    F2003-GA likes this.
  16. wthensler
    wthensler F1 Rookie
    3,153
    Gator Country, FL
    William
    Dicecal likes this.
  17. Dicecal
    Dicecal Formula 3
    1,804
    Phoenix, AZ
    Rob
    Thanks, I ended up doing a pretty traditional build of Rosso Corsa and Cuoio. Crappy cell phone pics, but you get the idea..
  18. Snaponjackson
    Snaponjackson Formula Junior
    469
    INDIANAPOLIS INDIANA USA
    Chris Jackson
    Congrats on your new F8!
    Just wanted to say hello to a fellow Hoosier and Purdue fan. (Both of my sons are Purdue grads) I am here in Indy
    and have also dealt with the guys at Lake Forrest. Great people. Hope to see you on the road. CHRIS
    Sent from my SM-G986U using FerrariChat.com mobile app
    Spider68 and Brent Gust like this.
  19. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Corsaspider likes this.
  20. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    Fantastic interior colon combination. Mr. Atelier from Az
    Ash Patel and Dicecal like this.
  21. Dicecal
    Dicecal Formula 3
    1,804
    Phoenix, AZ
    Rob
    Thanks, my salesman would not agree with you since he tried to steer me away from the carpets and belts... but thats what I prefer....
  22. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    I see colors on your bridge but it doesn't look like the tricolore buttons.. Am I rgiht?
  23. GT2goneF
    GT2goneF F1 Rookie
    May 28, 2020
    2,861
    Southern California
    I love the seatbelt color contrast. The floor mats are an acquired taste.. However, I don't dislike them... I really love the tricolore along the name
