Hello everyone Most probably this F355 issue has already been discussed so I could use some help. I have a front hub flange plate (the outer part) that’s distorted and needs replacing and a rear wheel bearing that needs replacing. Ferrari sells the whole unit at a ridiculous price. So my questions are? 1. Is there a way to separate the outer flange plate from the hub? 2. If yes what’s the process to undo and redo? 3. If yes where can I find the parts separately? 4. Is that part a cross reference part with other cars? I really need your help here. Thank you!! Georgios
I had the exact same questions a few years back, ended up coughing up 800 for the Ferrari rear bearing. I wrote about it in this post: https://www.ferrarichat.com/forum/posts/140562662/ Am very interested if anybody has come up with an alternative in the meantime.
