Ferrari F1 2020 ( 671) | Page 6 | FerrariChat
Discussion in 'F1' started by 444sp, Dec 7, 2019.
  1. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,132
    PR, TX, GV
    Jaime
    I concur with you.
  2. Thomas S.
    Thomas S. Karting
    Sep 11, 2017
    212
    Thomas
    Maybe stupid question: Is there a rule that only one driver at the same time is allowed go test? Or why don't they both test in parallel?
  3. fer312t
    fer312t Formula Junior
    Nov 16, 2010
    805
    You can only have one car at the test per day (for cost control reasons). You'll often see test days split between the two drivers though, one running the morning session and the other afternoon.
  4. DF1
    DF1 Three Time F1 World Champ
    and all teams are doing this potentially it’s testing
    Jakuzzi likes this.
  5. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,307
    Very nice analysis from Peter Windsor.
  6. Challenge64
    Challenge64 F1 Veteran
    6,364
    Ron
    freshmeat, senyah, stavura and 4 others like this.
  7. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,476
    KL, Malaysia
    MC Cool Breeze
    no missin winniw
  8. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    24,261
    Corpus Christi, Tx.
    Joe R Gonzales
    Soooo, after Barcelona testing...............it looks to be a long season
    Ferrari had to retool the engine
    The FIA has sent a six-line email with explosive content. It says that after the investigation of the 2019 Ferrari engine, an agreement was reached with Scuderia, but it was agreed not to disclose. What is behind it?
    The bomb hit ten minutes before the end of the test drives in Barcelona. The FIA press release was only six lines long. Apparently it said nothing and yet everything. Between the lines. Here is the exact wording:
    “The FIA announces that after a thorough technical review, it has completed its analysis of the operation of the Ferrari drive unit and has reached an agreement with the team. The parties have agreed not to disclose details of this agreement. "
    “The FIA and Ferrari have also agreed on a number of technical obligations that will improve the monitoring of all drive units in Formula 1. Ferrari has also agreed to support the FIA in its regulatory duties and research into sustainable fuels to reduce CO2 emissions. ”
    The time of publication shortly before the test drives closed said a lot. He was deliberately chosen so late. This ensured that the parties and third parties concerned could no longer be interviewed in the paddock. The Formula 1 community will not meet in Melbourne for two weeks at the other end of the world. If any. Until then, the Corona virus will make the headlines and the matter between FIA and Ferrari will take a back seat.
    The real story would probably not be a glory sheet for Formula 1. Therefore we will never know their details. So why did the FIA comment on the case again? Probably under pressure from the competition. Mercedes and Red Bull knew that the world association Ferrari had the engine on its line. You could no longer sweep that under the carpet.
    Litigation would be too risky
    You can interpret a lot in the first sentence of the statement. To put it politely, the FIA inspectors have clearly found irregularities in the operation of the 2019 Ferrari engine. Sharper tongues would speak of fraud.
    It is another matter whether the FIA is able to prove this in detail in a legally reliable manner. Ferrari would certainly have appealed against a drastic punishment. A legal dispute would definitely have washed a lot of dirty laundry and might not have brought the desired result.
    So it was easier to reach an agreement by hand, which could be as follows: You went too far with the engine. From now on, this will no longer be tolerated. You also pay a penalty for it. Of course not directly, because that would have been too obvious. Ferrari is funding the FIA's research into CO2-neutral fuels. This can quickly add up to a double-digit million sum.
    Ferrari has been officially suspected of tricking the engine since the USA GP. The FIA sent out several technical directives in quick succession to prevent what Ferrari's competitors accused it of doing. Inject more fuel than allowed by manipulating the measurement signal for flow rate measurement. New regulations for oil consumption. Tighter checks on the elasticity of the gasoline lines. Introduction of a second sensor to which the teams have no access.
    When Charles Leclerc's Ferrari suddenly had a discrepancy between the petrol specified in the data sheet and the fuel in the tank at the season finale in Abu Dhabi before the start of the race, the measure was obviously full.
    New engine with less power
    Rumor has it that the FIA inspectors then confiscated an entire Ferrari engine to test everything over the winter. And it should have been discovered how Ferrari has increased the performance of the engine in certain phases. Apparently using methods that are not quite in line with the rules.
    The FIA was thus under pressure. She could no longer keep the case silent. She apparently did not want to step him out in detail in public because that would probably have done more harm to the sport than it would have benefited. The suspicions were apparently so serious that Ferrari had to agree to the sanctions. Of course, they are much too mild for the opponents.
    But Ferrari may pay the colliery on the racetrack this year. A completely new engine had to be built in Maranello over the winter. Even the turbocharger and the energy recovery system were affected. According to measurements, this new engine has significantly less power than the old one and is one of the reasons for the disappointing top speed on the straights.
    Ferrari bases the PS diet on the concern for reliability. One could react with the second specification at the earliest. It usually comes after the seventh race. Since the World Cup for the Italians can be long lost.
    https://translate.google.com/translate?hl=en&sl=de&u=https://www.auto-motor-und-sport.de/formel-1/fia-mitteilung-ferrari-motor/&prev=search
    william likes this.
  9. william
    william Two Time F1 World Champ
    27,621
    Interesting reading. I could hardly believe my eyes.
    We were told for years that Mercedes were the only ones to cheat.
  10. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,710
    Everyone in F1 cheats, at least those who want to win.
    You just have to be able to explain your interpretation of the rules so that whatever you did seems to comply with the regulations.
  11. DF1
    Explains why Binotto feels they are behind even Red Bull.......wow!! So more than just fuel flow..........it appears. The intrigue of our new season is here LOL :)
  12. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,341
    Texas/Colorado
    George Pepper
    Mercedes are the only ones who are allowed to cheat. For everyone else, cheating is forbidden. :)
    fil, Bas, classic308 and 2 others like this.
  13. root
    root Formula Junior
    487
    Bay Area, Ca
    #141 root, Feb 28, 2020
    Mercedes F1 the last few years have been like Ferrari used to be when il Commendatore was in charge of SF. They know the rules and how to exploit them to their advantage, they're competent, well managed, smart, driven, and laser focused on winning. Can't say the same about SF the last few seasons or the coming one. It's gonna be a long painful season unfortunately.
  14. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,424
    Tampa FL
    Damn disappointing! Geesh!
  15. Dilusha
    Dilusha Formula Junior
    Dec 10, 2016
    769
    That article was brought to you by Mercedes. :p
    ingegnere likes this.
  16. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,270
    Le caylar (France)
    mathieu Jeantet
    Don't be disappointed,
    Leclerc's race simulation yesterday was very good
    Very comparable to Hamilton's one last week before they hit troubles with their engine.
    Binotto is playing game and last year lessons were painful it seems !
    mdrums, G. Pepper, 375+ and 1 other person like this.
  17. Dilusha
    Dec 10, 2016
    769
    Yeah, just relax. I think everyone's scared of what FIA's settlement might have done to SF1000. I personally don't think it did anything to the new car. And don't read german magazines. :p
    ingegnere and mdrums like this.
  18. DF1
    Oh yes lol. So called “ settlement “ fun is just beginning lol. And we worry about Coronavirus :).
    https://www.bbc.com/sport/formula1/51688538.
    Formula 1: Ferrari engine investigation sparks 'anger' from rivals
  19. Kiwi Nick
    Kiwi Nick Formula 3
    Jun 13, 2014
    1,325
    Durango, CO
    Jeff
    "According to measurements, this new engine has significantly less power than the old one and is one of the reasons for the disappointing top speed on the straights."
    But the two cars that were fastest on top speed (the straights) were powered by...Ferrari. Were Ferrari and Alfa using last year's engine? Or, is the guy who wrote this article just wrong?
    stavura, Igor Ound and ingegnere like this.
  20. ingegnere
    ingegnere F1 Veteran
    5,566
    Montreal
  21. ingegnere
    5,566
    Montreal
    We’ll see at the first race what the SF1000’s relative competitiveness will be but this whole narrative of cheating reminds me of the fuss made by the British contingent in 1994 against Ferrari’s use of supposed trick fuel. I remember talking with the Tyrrell guys before the Canadian GP that year, they were convinced Ferrari would pay a big performance penalty with new fuel rules being implemented.
    Not long after the new rule was introduced, Ferrari locked out the front row and won at the power critical German GP at Hockenheimring.
    Ironically it was the Brit/German duo of Brabham-BMW that were the first to introduce rule-skirting fuels (with help from German chemicals company BASF) at the end of the 1983 season to s the the still-considered-tainted WDC for Piquet. But here again for the English-speaking press it was a triumph of ingenuity and technology and not at all cheating.
    stavura, jpalmito and Igor Ound like this.
  22. DF1
    lacking downforce and less drag
