Ferrari F1 2020 ( 671) | Page 5 | FerrariChat
Discussion in 'F1' started by 444sp, Dec 7, 2019.
  1. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    Can only hope they’ll pull up a “Mercedes” this year and come to the last day of testing with a completely different and much faster car. Would explain the early reveal.
    375+ likes this.
  2. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,360
    Le caylar (France)
    mathieu Jeantet
    Bar front and rear wing I'm fairly certain this is the car we will see in Melbourne
    classic308 likes this.
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
    Looks more like its suitable for slicing salami, perhaps thats where they have gone wrong in the past!
    It doesnt bode well when they have to slam on the brakes and do a u turn in the design concept from last year, successful cars are built on evolution.
    Of course they had to work on all areas, we knew that Mr Binotto!
    Tony
  4. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,500
    Looks like last year's car but slimmer and with more stuff attached. Also the suspensions are conservative compared to what everybody else is doing.
    Yet, I've read that engine and gearbox are brand new and that the final aero only will arrive for the last test, so we'll see.
    And I like the numbers.
    375+ likes this.
  5. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,360
    Le caylar (France)
    mathieu Jeantet
    S3 in Barcelona will be an interesting metric for the new car
  6. Borrow’d Mine
    Borrow’d Mine Formula Junior
    832
    Florida
    Would love to see Ricardo in red
    DF1 likes this.
  7. TheMayor
    TheMayor Nine Time F1 World Champ
    98,792
    Vegas baby
    Jakuzzi, Igor Ound and DF1 like this.
  8. TheMayor
    98,792
    Vegas baby
    Albert-LP, Kiwi Nick and DF1 like this.
  9. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,614
    Australia
    Mark R
    They probably realised if they have Mission Winnow on the official team wear there are about 5 countries they can't sell them in.
    This way without the Mission Winnow logo they can sell 2020 stock at every racetrack and country around the world.
    More sales equals more money for them.
    G. Pepper likes this.
  10. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,257
    let’s just hope it’s a nod to the winning past!!!
  11. TheMayor
    98,792
    Vegas baby
    Well, the 80's weren't exactly Ferrari's F1 golden years...
  12. freshmeat
    Aug 30, 2011
    7,257
    bracing for the pain already buddy lol
    Jakuzzi likes this.
  13. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,360
    Le caylar (France)
    mathieu Jeantet
    Indeed 1982 was a tragic one ..
  14. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    20,850
    Corpus Christi, Tx.
    Joe R Gonzales
    Ten key design points on the new Ferrari SF1000
    By: Giorgio Piola
    Co-author: Matthew Somerfield
    Feb 13, 2020, 11:21 AM
    Using the Ferrari SF90 that raced last year as a yardstick with Giorgio Piola’s latest sketches of the SF1000 overlaid, let’s dive in and unlock the differences between these two machines...
    1. The nose utilises a similar cape solution to the design introduced by Ferrari in Singapore last season, with changes made to the nose tip shape in order to optimise its performance.
    2. The turning vanes have been brought forward and are more complex than last year, with seven elements now hung beneath the nose and chassis.
    3. The wheels have been redesigned with their partner O.Z. and feature longer spokes due to the central hub being reduced in diameter. This will allow more air to be passed through the brake duct assembly and out through the wheel face, a technique preferred by others last season given the prohibition of the blown axle solution.
    4. The bargeboards have been carefully redesigned to maximise flow to the sidepods and their inlets behind, with the forwardmost section divided into three and made even taller than last year. Meanwhile, a twin boomerang solution has been deployed with a slimmer one mounted at the front end of the assembly and a larger one at the rear.
    5. The innovative sidepod solution introduced in 2017, that placed the upper side impact spar at a lower and more forward locale has been retained but improved upon. It has clearly taken inspiration from Red Bull in this regard, with two winged sections above and ahead of the main cooling inlet allowing it to be much smaller, whilst also serving their own aerodynamic purposes. These changes have also led to a more aerodynamically beneficial wing mirror design, with both stalks serving as flow conditioning devices as well as supports for the actual mirror.
    6. The airbox retains its narrow trapezoidal shape, a feature that’s enabled the designers to install ‘horns’ either side, serving as flow conditioners that should improve flow to the rear wing. This is not a new solution, just one that has been reinterpreted for the prevailing regulations, with McLaren using a similar design back in 2005, something that other teams duly copied thereafter.
    7. The engine cover is dramatically slimmer and carries a much lower line thanks to work done by the powertrain department to repackage the power unit and ancillaries. This extends to the sidepods too, where we can see just how much tighter the packaging is when compared with its predecessor.
    8. An all-new gearbox, which has the same volume but is much narrower, permits much narrower bodywork at the rear of the car, improving flow into the coke bottle region.
    9. The T-wing is not dramatically new when compared with their opposition but does feature some novelties compared with last year's car. The double swan-neck rear wing supports have also been retained, as has the single element wastegate pipework, although work done at the tail end of last season could see them switch to a double wastegate arrangement at a later date.
    10. The endplate of the rear wing has been optimised for 2020, with care taken over the number and design of the strakes placed on the wider section of the wing. As usual, we’d expect to see a number of rear wing configurations throughout the season in order to cater for the demands of the specific circuit that they’ll be visiting.
    https://www.motorsport.com/f1/news/ferrari-sf1000-key-design-points/4684309/#gal-4684309-0-ferrari-sf90-front-nose-under
  15. jgonzalesm6
    20,850
    Corpus Christi, Tx.
    Joe R Gonzales
    Ferrari not changing front wing concept but will have "quite a lot" more downforce
    Ferrari's decision to focus on reducing drag rather than increasing downforce with their 2019 car was a costly one as they lost more time in the corners than they made up on the straights.
    The front wing concept Ferrari had for the SF90 in 2019 was still bolted on at Tuesday's presentation of the SF1000, and Binotto explained this wasn't just for show.
    “We will not change our concept, it will remain like that, even on whatever we may test later on," the Italian was quoted by Motorsport.com.
    "I think this is the right concept for us. I think we improved a lot the downforce, not only through the wing but if you look at the car itself, turning vanes especially.
    "It's quite a lot of high complexity, I would say. The entire car, the slimmer car, makes as well the back of the car and the diffuser work better. So, finally I think the overall [downforce] has certainly increased.”
    Increasing downforce typically goes hand-in-hand with increased drag and therefore reduced top speed and Binotto knows this, although he does think his crew have found the right balance between low-drag and high downforce as he underlines they'll have a much stickier car in the corners now.
    “Where is the right balance? I think it's difficult to know, difficult to know what the others are doing as well. But certainly we increased by quite a lot our downforce.
    “As I said, I think the starting point of this car has been the one of last year, so we have not changed our concept. So let's say that the wheelbase and rake [are] pretty much similar.”
    https://www.gpblog.com/en/news/54673/binotto-on-car.html
    stavura, Igor Ound and greg328 like this.
  16. TheMayor
    98,792
    Vegas baby
  17. crinoid
    crinoid F1 Veteran
    9,485
    LaCrinoid
  18. Igor Ound
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    DeSoto and TheMayor like this.
  19. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    The Complexity of that design is amazing.
  20. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    Why? Ferrari won the F1 title in 1982 (Ferrari 126C2, V6TT 1.5 liters) and 1983 (Ferrari 126C3, V6TT 1.5 liters).
    1982 was a tragic year, but a winning year as well: Ferrari dominated the 1982 Championship.
    ciao
    ingegnere likes this.
  21. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,360
    Le caylar (France)
    mathieu Jeantet
    Agree
    Sadly apart the tragic Villeneuve death , Pironi absolutely deserved the WDC this year.
  22. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,073
    PR, TX, GV
    Jaime
    Qualy?? Wait for the checkered flag.
    Remember that MB/LH44 have been known to sandbag even during qualification, just to run away with the race... :(
    V12addict likes this.
  23. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,269
    Which is a perfectly legal tactic.
    william and Jakuzzi like this.
  24. Mitch Alsup
    Nov 4, 2003
    9,269
    In other words, they learned almost nothing from last year's embarrassment.
