Ferrari Diagnostic Tool for $775 (Launch X431 V Pro) | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by nessus-gte, May 2, 2018.
  1. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I probably wasn't clear with my answer...… The Xdiag connects to my CS TCU which uses CFC231 hardware using the 430 gearbox menu. I understand but only off here, not from direct experience, that if you use the 360 menu you get a choice of CFC201 Early of late model on the menu and I'm not sure anyone has managed to connect via those.
    If it connects it cannot enter decimals in the PIS and new clutch position parameter only whole numbers.
    Brake bleed it does indeed but I do mine with a power bleeder.
  2. duskybird
    duskybird F1 World Champ
    12,528
    29 Electoral Votes
    Bill B.
    Got it, thanks.
  3. tazandjan
    39,007
    If you can only set PIS at 4.0 or 5.0, not too useful.
    mike01606 likes this.
  4. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    The positive is it will read and graph a load of data so when I took my gearbox out and changed the release bearing I had a baseline and could also bleed the clutch. I did a job that wasn’t previously possible. Hopefully they will fix the truncation issue in later releases and when they do it will be pretty perfect. If they don’t it’s a fairly minor inconvenience.
  5. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    Yes, it is a minor inconvenience but it'll have a big impact on the clutch wear and the inability to put the gear into reverse.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Can't recall now but I thought there was a way to set using other parameters on that tool .. I think mwsteward might know ?
    Sent from my Moto G (4) using Tapatalk
  7. skar89
    skar89 Rookie
    Feb 27, 2012
    13
    Spain
    I have Easydiag2 with x431pro software and a 360 spider.
    No access to TCU with any of the three options CF201v1, CF201v2, CF231.
    No ABS function.
    Only ECU, electric roof and airbag can clear dtcs.
    WIth Autel 908 i can access to ABS too with bleeding and other functions but not to gearbox, like X431. Seems that in 430 there are more functions but havent tried yet.
  8. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,430
    On the Limit
    Dino
    #58 Ingenere, Jul 11, 2018
    I have this unit and can do PIS and brake bleed on my CS. It also bleeds the clutch, self learns, engages gears, aligns, etc. I set the PIS at 5 and it read out at 4.86, which is pretty much perfect.
    I just replaced the clutch and I have been having a challenge resetting the wear index with this tool. Has anyone figured out the process?
  9. Nick
    Nick Formula Junior
    Sponsor Professional Ferrari Technician
    Oct 31, 2003
    506
    Nick Scianna
    The launch and Autel are hacked old versions of Leonardo and the data is not accurate. I have been told this by many workshops who have been able to evaluate these cheap chinese tools tool next to a Leonardo or a SD3 / DEIS tool. Plus there is no support as they do not know the strategy/ theory of the cars. Below is a video showing a paragraph from our tool in a actual Autel tool. This is located under Key programming in the 458 section. These guys are nothing but a bunch of hackers.
    f355spider, taz355 and Dave rocks like this.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    Like all things in life
    You get what you pay for.
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,826
    The Cold North
    Tom
    Very true. These hacked machines a good for quick service work. Bit when it comes down to the real nitty gritty..they are completely unreliable.
  12. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    #62 gobble, Oct 24, 2018
    I bought a HK delivered version of this tool last week and played with it a bit the last few days. So far I've successfully reset service lights in both a Porsche and Mercedes. The Porsche light had been on for 5 years, I had thought it was dealer reset only. I have an offer out in the 458 forum to ship it to someone if they want to test for the 458 service light reset.
    I can put people in touch with the seller if they're interested. Mine came unlocked for all makes of cars and the price was reasonable.
  13. duskybird
    12,528
    29 Electoral Votes
    Bill B.
    Is it update-able? I got one from someone here on F-Chat and after 1 year it won't update so it doesn't work.
  14. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    #64 gobble, Oct 24, 2018
    Here's my understanding of all this, and I just traded messages on Skype with the guy I bought mine from.
    Someone else on the forum bought one a year or so ago and I wanted the same thing. I was told the tool had been updated though to a version 3 which is what I bought. My dongle is green and the buying/software download process was different.
    The guy I bought mine from just told me he can update your old one if he has your dongle's serial number plus the username and password you were given. If you want to talk with him I can give you his Skype name.
    I paid for mine on Friday and it arrived by DHL from HK on Monday. So far the service and communication has been great.
  15. duskybird
    12,528
    29 Electoral Votes
    Bill B.
    I'd love to try it but if it doesn't work on a 360 I don't have much use for it.
    MarioVU1 likes this.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    If you have a yellow dongle it may be worth sometime .. they are not making them any more
    Don't think it is garbage .. it can be worth hundreds of the right serial number
    Sent from my moto g(7) using Tapatalk
  17. windsock
    windsock Formula 3
    1,129
    What are you trying to fix by getting to the actuator bleed screws. While that was a common problem on 360, maserati's and early 430 I have not seen loose screws since before 2008 models.
  18. Yellowgallardo1
    Yellowgallardo1 Karting
    Sep 19, 2018
    143
    marcus
    Anyone have one they may want to part with? or rent out that may work ok a 458
  19. Marie348
    Marie348 Rookie
    14
    Torrez
    I can test and make a video for sure ! but the cost of update is more expansive than saling my actual launch and buy a new one with 2 years update no ?
  20. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    Not only that but I don't have enough memory left to download anymore updates.
  21. duskybird
    12,528
    29 Electoral Votes
    Bill B.
    I had the same issue. Move it to an SD card and only download what you need. I limit mine to jus what I need and if the need ever arises I'll download what I don't have.
  22. AutoNation
    AutoNation Rookie
    3
    Tom
    one of the best diag tools ever !!!
    only 330usd with 1 year updates.
  23. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Why does it say "BANNED" next to your name and Silver Subscribed notation at the top of the post?
  24. jeffdavison
    2,544
    Suwanee Georgia
    Jeffrey Davison
    anyone used a TEXA?
  25. PaulK
    PaulK F1 Rookie
    4,768
    Michigan
    Paul
    Looks interesting. But at over 6k I'd rather buy a proven tool like a Leonardo.
