458 - Ferrari 458 spider rear window - wind deflector - not going all the way up - help. | FerrariChat
458 Ferrari 458 spider rear window - wind deflector - not going all the way up - help.
Discussion in '458 Italia/488/F8' started by sharon amos, Feb 5, 2019.
  1. sharon amos
    sharon amos Karting
    Dec 24, 2017
    118
    Houston Texas
    sharon amos
    Guys
    This is one annoying feature, Ferrari made a great rear glass that goes all the up and down with the top is closed but when you open the top and want to block the air from the back, the rear window only goes up 2 inches????
    That is one annoying thing, why would they limit it from going all the way up and acting as a real wind deflector ?
    And the worst part is that because it’s considered to be a built in wind deflector, no one sells a wind deflector for this car.
    Anyone has a solution, maybe another product and or maybe a bypass to the window so we can close it all the way up even with the top down ?
  2. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    It is designed to do this. As the rear window gets higher, the turbulence in the cabin becomes greater hence why it goes to a predetermined position resulting in the lowest turbulence in the cabin. Honestly, I haven't found it to be a hindrance at all.
    TheBigEasy and bball16 like this.
  3. sharon amos
    sharon amos Karting
    Dec 24, 2017
    118
    Houston Texas
    sharon amos
    I think that if you raise the side windows and the window in the back would go higher than you would have no wind at all. Just like any other convertible.
    It sounds weird that only at 2 inches height the wind will not enter from the back vs a full height.
  4. 707
    707 Karting
    May 29, 2014
    175
    Alex
    Think about the wind resistance on the glass if it was fully up at 200 MPH. Also never had a problem. Maybe the convertible life isn’t for you
  5. tekaefixe
    tekaefixe Formula 3
    May 10, 2012
    1,201
    CH
    Paulo
    Never had a problem. I think the problem is you.
    SD455TA likes this.
  6. 338Lapua
    Sep 5, 2015
    829
    Michigan
    Tony
    Come on guys, the question was valid especially if you look at the 430 Spider and the very large wind deflector it has. But, it is a much different body design than the 458....
  7. sharon amos
    sharon amos Karting
    Dec 24, 2017
    118
    Houston Texas
    sharon amos
    I’ve had several Ferrari’s, r8, 911, corvette c6, c7and SL63 all convertibles and all had a proper wind deflector that was doing a better job at high speeds.
    I love the 458, it’s my best car ever but I’m positive that the glass deflector is not 100% - they could have done a better job and or choice.
    I also watch couple Of review videos that pointed the same issue.
    Nonetheless love my 458....
  8. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,296
    California
    Ethan Hunt
    Not to drudge up an old thread but I had the same question! But also suspected that it was by design
