Ferrari 400i exhaust header removal | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by christc, Nov 27, 2016.
  1. christc
    christc Formula Junior
    Mar 3, 2013
    444
    Germany
    #1 christc, Nov 27, 2016
    Dear All,
    what is the exact procedure for removal of the exhaust headers on a fuel injected 400i?
    I would like to have the headers ceramic coated and need to remove them therefor.
    Do I need to remove the complete injection system on each side of the engine or is there enough space if I just remove the air filter box but leave the rest in?
    I would be very greatfull if someone could offer advice on the different steps for the removal. Thanks a lot.
    Christopher
  2. jacques
    jacques Formula Junior
    May 23, 2006
    876
    Los Angeles/Florida
    No, you do not need t remove the injection system be cause you are going to remove the exhaust manifold from beneath the car. Remove the exhaust pipes bolts at the collector, and tie the pipes up in situ. then you can start to remove and loosen the header bolts. Just loosen them until you have them all loose on each given section(3 per side). These are heavy pieces, and you don't want the falling and breaking your nose and teeth. Straight forward. really,. Just remember to install the in reverse order. Also a little WD40 wouldn't hurt as you do not want to snap one of the bolts off. New gaskets wouldn't hurt at this time. I hope that this is of some use to someone. Thank you. Jq.
  3. christc
    Mar 3, 2013
    444
    Germany
    Hello Jacques,
    thanks for the fast reply. I guess rhe heat shield stays in that way. I will face it within the next weeks and for sure will use some WD40 upfront.
    Christopher
  4. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,683
    Seattle, WA
    Brian White
    The heat shields can come off without removing the injection systems. They are bolted to the headers themselves.
  5. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Definitely new gaskets and nuts. The nuts aren't in tight. I coated my headers a few years ago.
  6. christc
    Mar 3, 2013
    444
    Germany
    Done it today. Really was easy as you said with air filter boxes removed I could
    get at some bolts from above, some from below. Thanks a lot for your recommendations!
    Christopher
  7. Schumi
    Schumi Formula Junior
    Jun 5, 2002
    829
    Missouri
    Daren
    What color coating would appear "correct" for our cars? Who is the best to do this work?
  8. christc
    Mar 3, 2013
    444
    Germany
    I am thinking of having it plasma ceramic coated in black. Adresses I do only have in Germany. Sorry.
    Christopher
  9. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,146
    Canada
    Newman
    Mine on my 400i are a metallic white and original just like a set of 365 boxer headers I have kicking around in my basement. I think black is incorrect.
  10. jacques
    May 23, 2006
    876
    Los Angeles/Florida
    Who sells the best quality header gasket? Also, what size are the header nuts and bolts, and what is the size of the bolt that fastens the the heat shield to the headers. Thank you all very much. Jq.
  11. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    #11 GT Jones, Dec 6, 2016
    I found when re-assembling mine that there were flat copper gaskets and 'puffy' copper gaskets that look to have better sealing. Awitalian.com had them in stock. Check dimensions when you remove them
    400 engines use these
    exhaust gasket 147630 (4)
    exhaust gasket 147631 (4)
    Not sure about the bolts & nuts. I did apply a high-temp heat shield to the inside of the heat shields and combined with the ceramic coat headers it has noticeably reduced interior footwell temps.
  12. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    540
    London
    Anthony Bentley
  13. Anthony bentley
    May 20, 2006
    540
    London
    Anthony Bentley
    Do I even need to remove the air boxes to get the headers off?
  14. christc
    Mar 3, 2013
    444
    Germany
    Only the lower part housing the filter.
  15. Anthony bentley
    May 20, 2006
    540
    London
    Anthony Bentley
    With out looking yet, does it come out of the bottom or top?
  16. christc
    Mar 3, 2013
    444
    Germany
    Top, but it is a quiet tight fit
  17. Anthony bentley
    May 20, 2006
    540
    London
    Anthony Bentley
    How tight do you go with the new nuts?
