Ferrari 365 GT 2+2 / 330 AC Refrigerant Volume | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Peter Lipman, Apr 30, 2021.
  1. Peter Lipman
    Peter Lipman Rookie
    Nov 24, 2020
    21
    Peter Lipman
    I am interested in finding out the refrigerant volume for a 365 GT 2+2. The AC system is the same as in the 330's. any info about the compressor oil would also be appreciated.
  2. 330gt
    330gt Formula 3
    Nov 12, 2004
    1,982
    Seattle, WA
    Kerry Chesbro
    The 330 GT A/C manual specifies 1 kg (2.2 lbs.) of freon.
    1) YORK COMPRESSOR
    a) Before mounting the compressor on the motor and base, support it on two pieces of wood, one on each side, with the shaft of facing down, since no weight must ever be on the shaft. Leave it for 30 minutes in that position. This is necessary so that the oil can lubricate the packing of the shaft before the operation of the compressor.
    b) The compressor comes from the manufacturer properly lubricated and with the exact oil amount needed.
    Do not add any other type of oil, it will contaminate the system completely and will invalidate the guarantee on the compressor.
    USE SUNISO GRADE 43004 OIL EXCLUSIVELY.
    c) It is best to check the level of the oil in the compressor before assembly. On a level support, remove one of the two side plugs, insert a metal dip stick and measure the amount.
    The level in a new compressor must be 35 mm. (1 1/32”).
    The level after operation must be between 22 and 29 mm. (7/8” and 1 9/64”).
    enio45 likes this.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Measure the Superheat value across the evaporator and fill until the Subcooling across the condensor matches it.
    A $60 harbor freight manifold and a temperature probe are sufficient to perform this.
    If you don't like to deal with the science, gauges and stuff then use the "beer can fill" method.
    Place your hand on the big hose at the compressor and start filling until that hose is as cold as you like to drink your beer
    (DISCLAIMER: This technique will not work in the UK or where Lucas home refrigerators are sold)
    turbo-joe likes this.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,913
    romano schwabel
    lucas - lord of darkness or the inventor of the short circuit and the darkness :)
    synchro likes this.
