Ferrari 360 Spider - Convertible top stuck open. | FerrariChat
Discussion in '360/430' started by keon2k, Aug 29, 2017.
  1. keon2k
    keon2k Rookie
    Aug 5, 2013
    11
    I have a 360 Spider.
    Convertible top is stuck fully open. I can hear the engine run, but the top is stuck.
    I need to close the roof before it start to rain.
    Any suggestions on what the problem might be? Possible to get the top up manually?
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    Have you tried to turn off the engine, remove the key, turn on, start engine and try again?
  3. keon2k
    keon2k Rookie
    Aug 5, 2013
    11
    Yes, I have tried that. Also tried a new battery in the car for more power. The old one was bad.
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    Can you hear the pump operate when you hold the switch?
  5. keon2k
    keon2k Rookie
    Aug 5, 2013
    11
    Yes. But nothing happens. Its like something is stuck. Any linkage or something.
  6. Jonkheer
    Jonkheer Formula 3
    Aug 29, 2010
    2,250
    The Netherlands
    Christiaan
    Is there enough fluid in the reservoir?
  7. blackbolt22
    blackbolt22 F1 Veteran
    5,792
    Boca Raton, FL
    Mr. Anderson
    Broken cable?
  8. houtie123
    houtie123 Formula Junior
    Dec 9, 2007
    547
    Cape Town, RSA
    Andrew
    Happened to me a couple of months back. Turned out the hydraulic hoses connecting to one of the Rams has failed. It's all one integrated piece - with labour was a $2000 fix. Hope you're in a different place. Do you get a whirring noise when pressing the button? If not it's likely hose failure
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    A video would be good so I can judge the sound.
  10. mello
    mello F1 Veteran
    5,434
    CA Bay Area
    Steve
    Try using the manual tool in the toolkit to close it for now. At least the interior won't get rained on.
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    Good suggestion.
  12. daveyator
    daveyator Formula Junior
    Jun 10, 2014
    292
    Yucaipa, CA
    Dave B
    Oh s*@t. We have that??
  13. Dewinator
    Dewinator F1 Veteran
    7,331
    WA
    I saw the instructions when I was reading through the manual... there are like 50 steps.
    robertjskelton likes this.
  14. keon2k
    keon2k Rookie
    Aug 5, 2013
    11
    Thanks for all suggestions. I will take a look tomorrow. I will also make a video and check all suggestions! :)
    Where do I put the tool to take on the top manually?
  15. keon2k
    keon2k Rookie
    Aug 5, 2013
    11
    Thanks steve_fr !
    If I decide to use manually / emergency method. Will the top work? Or does it have to stay closed all the time?
  16. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    If the manual is followed and all of the switches are tripped, then it will operate normally.
  17. hessank
    hessank Formula 3
    1,867
    Canada, Florida
    Fred
    I wish there was like a socket and you could crank it open manually and later on crank it closed and just totally bypass the electrics/limit switches interfaces. Instead, the manual steps are rigourous
  18. JerseyBland
    JerseyBland Karting
    Apr 29, 2018
    99
    Chandler AZ
    Scott B
