Ferrari 360 BMC F1 Replacement Air Filter- any thoughts? | FerrariChat
Discussion in '360/430' started by GordonF355, Dec 1, 2015.
  1. GordonF355
    GordonF355 Formula 3
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    Has anyone installed these air filters? Does it improve sound / performance or is it just marketing hype? I have a 2000 Eur0 360 with racing exhaust.
    Thanks!
  2. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,430
    On the Limit
    Dino
    I have them and it does improve sound and breathing, which helps performance.
  3. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    More expensive version of K&N
  4. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    ^^Yep K&N is the same but way cheaper.
  5. ph12
    ph12 Karting
    Jun 28, 2015
    178
    Los Angeles
    after reading around posts on the forum most people think paper filter is fine. There is no documented case that replacing the filter alone on a ferrari will have any significant power gain.
  6. f355spider
    f355spider F1 World Champ
    18,027
    +1. I used to use them in all my cars and motorcycle...a bit more intake noise, but little performance increase. Used on everything, including a carb 308 GTS, and later 328GTS. Never bothered on the 355 or 430 Scud...they have all been dispelled as doing very little.
  7. GordonF355
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    ok thanks for all of your opinions! I emailed my mechanic and he pretty much said the same thing that it will not matter much at all!
  8. tazandjan
    39,007
    The other train thought on the K&N and BMC filter is it is not a great idea to have oil in front of your MAF sensors.
  9. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    All models after F430 have BMC as OEM. (from my F-tech) Just installed K&N. Didn't seem oily at all. First clean and re-oil is in 50,000 miles. So I will let someone else worry about over oiling them!
  10. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    First Ive heard that BMC type filters are in new f-cars. Anyone confirm?
    Don't re-oil, you are asking for trouble. I've been watching the various forums (mostly p-cars) for 25 yrs and the only time people have reported problems is after re-oliing.
    If you are planning to use 'em, just buy new.
  11. 1mean3
    1mean3 Formula Junior
    426
    +1 I agree with that!
  12. kelley
    kelley Rookie
    Apr 16, 2009
    15
    Bmc is constructed far better than the K&N I have had two frames fall apart on the K&Ns
  13. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    I thought bmc also had more filter layers? I can't remember.
  14. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    #14 Michael B, Dec 3, 2015
    Is that so... Well add these BMC filters to that mix. Yeah, by the way.. That is debris in that MAF screen. Went right past this filter.
  15. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    573
    california
    Jack
    you would pay 250.00 for some air filters????????
  16. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
  17. GordonF355
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
  18. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    #18 captglen, Dec 4, 2015
    It passes much more air thru the engine.
    I can't really say it makes a difference in the sound
    Its constructed with all top quality materials.
    The company that makes filters for Formula 1 and NASCAR, Porsche Cup to name a few makes these for us under contract
    We will have more Ferrari models available soon
    You will not find a better filter and its rechargeable, Mfg says 10,000
    I would every 5000, so probably every 1-2 years
    Let us know if you have any questions
    Glenn
