Ferrari 308 master cylinder - Booster whistle noise | FerrariChat
Discussion in '308/328' started by reuven, Jun 15, 2019.
  1. reuven
    reuven Karting
    Apr 22, 2007
    120
    Israel
  2. Martin308GTB
    Martin308GTB F1 Rookie
    4,224
    Black Forest Germany
    Martin N.
    Hello reuven,
    is the whistle noise always present or only if you apply the brakes?
    Independend from the noise. It looks, as if your master cylinder is leaking a bit.
    BTW. are YOU the owner of the GTB in that great, famous Youtube-video from Israel :)
    Best from Germany
    Martin
  3. Dr Tommy Cosgrove
    35,342
    Birmingham, AL
    Tommy
    Just had this EXACT problem with my 99 Jeep Cherokee. Sounded like a hairdryer blowing until I pressed the pedal
  4. reuven
    reuven Karting
    Apr 22, 2007
    120
    Israel
    Hello Martin,
    The whistle is permanent, when applying the brake pedal it is getting stronger.
    If you refer to this video: it is my 308 GTB :)
    Thanks,
    Reuven
    Milkshaker0007 likes this.
  5. Martin308GTB
    4,224
    Martin N.
    Hello Reuven,
    that's the video. I cannot repeat it too often; just great.
    As for your problem. I haven't dealt with my brake servo enough to make any statements. But it sounds as if it needs a rebuild. My question above was, because my car also has a slight hiss just in the moment, when I apply the brakes. It remains silent with the pedal permanently applied and without. It didn't get worse over 20 years so I left it like it is.
    As for a rebuild, there are 'rebuild kits' available. Whatever these are. On pics on dealer websites I just see two rubbers for a three digit $-price, while the front seal is something around $5.00.
    I think dismantling this thing is a challenge and though I meanwhile perfom bigger jobs on my cars I don't know whether I would dare to touch that thing and better would search for a specialist.
    But perhaps you are more courageous :)
    And here's an older thread addressing similar problems:
    https://www.ferrarichat.com/forum/threads/308-brake-booster.316391/
    Best from Germany
    Martin
  6. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    230
    Rockwall
    Dave Hoffer
    IMO the big rubber diagram inside has a hole in it. Most of the time the hole is from the master cylinder leaking brake fluild on it. A easy fix if you can find the rubber diagram. A little tricky getting it apart. If its like most cars it twist apart with lots of force. Fixed many of them on older cars years ago. The supply of rubber diagrams has gone a way since new cars don't have this problem.
  7. offtheworkigo
    Feb 23, 2016
    230
    Rockwall
    Dave Hoffer
    Check out youtube on rebuilding a power booster.
  8. Martin308GTB
    4,224
    Martin N.
    #8 Martin308GTB, Jun 16, 2019
    Opening the housing looks like a major PITA :)
    Reuven,
    If you are looking for a specialist and don't mind shippig it abroad to the birthplace, here's a very reputable shop with reasonable costs:
    https://www.casafreno.com/
    Best from Germany
    Martin
  9. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    I had my booster rebuilt a couple years ago here in the US. It cost less than $200 USD and took about 1 or 2 weeks. I think they said they replace multiple (maybe 12 seals? and a diaphragm) during the rebuild. They also stated that a lot of boosters fail after about 20 years due to deteriorating seals and ageing rubber parts.
    I posted a thread on this site if you need more info. Don't chance it, send it off for a rebuild.
    Good luck
    PS. Also a good time to check the check valve near the intake manifold, they often stick open.
    waymar likes this.
