Ferrari 126C2 1:8 | Page 2 | FerrariChat
Ferrari 126C2 1:8
Discussion in 'Collectables, Literature, & Models' started by Peperbus, Jan 24, 2009.
  1. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    I admire the work you are doing but I think I'd be much more inclined to drive to Manzoni's house and shake the parts out of him! Good luck in completing the parts to this awesome model.
  2. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    The Netherlands (071
    Ton
    Thanks guys :)
    @Latsyrc
    "Taking a break from the 250?"
    No not really.....but this car is crawling in my mind to often lately so I thought ...let´s start with the difficult things :) The 250 stays on the work bench
    @the_stig
    "I'd be much more inclined to drive to Manzoni's house and shake the parts out of him!"
    It passed my mind occasionally :) ...but it is useless ...if there is nothing you can get nothing :(
  3. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    In the last couple of weeks I made a nice progress on reproducing the missing parts of the gearbox. It is not finished yet but there is enough to show :D
    On this picture all the reproduced parts are shown. The part in the middle is the "collar" between engine and gearbox housing. It is made out of plastic for the right measures but will be reproduced in brass because of the weight on both sides. The blue square show the parts from the kit which are the reference for reproducing the missing parts
    A dryfit is shown from the reproduced parts and the picture in the left corner shows the original without missing parts :evil:
    regards
    Ton
  4. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    Looking great, Ton. Glad you are able to build the parts and keep progress going on the 250! :D
  5. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Ermmm....well I dreamed about it :)
  6. Paulo Ferrari
    Paulo Ferrari Formula Junior
    Mar 5, 2007
    395
    Portugal - Porto
    Good looking !!!! Congratulations. You should think in start to build and sale all the parts of the car ...
    Good luck, we are waiting for the DAY !!!!
    Hugs
  7. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Some progress again :D Last time I stopped at the point were I had to make the brass connection point between the engine and gear housing. I used a plastic mould which I showed earlier to fabricate the brass connection.
    At the left you see the plastic mould and the big picture shows the brass connection. The next picture shows the ready connection were I used copper plating to close the voids.
    And here the gearbox housing is ready: plastic, white metal and copper/brass are painted and dry brushed to get all over metallic look.
    On the next pictures you see the supports assembled for the complete suspension/wheel setting. I received a spare part of the suspension from another owner of the Promocom 126C2 so I only have to reproduce its counterpart.
    This is my goal for the next update and probably I will make the wing strut too!
    Ton
  8. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    Excellent work, Ton! Thanks for the updates, it's too bad more people aren't following this and commenting. :)
  9. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Thanks Travis ......maybe there is more interest on the moment a car is evolving ;) Collectors like shiny cars that you can put in a showcase ...not all kind of parts :)
    Ton
  10. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    There are very few people here capable of this sort of work so I think it is of limited interest for the rest. They may not understand what goes into this at all. I've been around models 30+ years and I'm in awe of someone being able to reproduce these missing parts.
  11. JOEV
    JOEV F1 Rookie
    2,827
    Ontario, Canada
    Joe
    Agreed - "awe" is the right word. Incredible craftsmen with the hands of surgeons. Truly boggles the mind.
  12. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Thanks guys!
  13. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
  14. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Another update: a few parts less are missing now :D This update concerns two vital parts: the wing strut (orange) and a part of the suspension (blue). The wing strut is completely missing and I have the other suspension part as an example.
    After a failure in brass and aluminium sheet I decided to use plastic. The aluminium wing is so light that the structure has almost nothing to support. Here the inner parts are shown
    Here the strut is almost finished
    And here it is ready and assembled to the gearbox. The photo etch part is the mount for the wing.
    The next part is the suspension part which gave me a considerable headache. As you can see nothing is straight but all these angles need to be united in one piece.
    How do you get these parts together? On the next picture you see the different stages. I took the original (upper part) and I replaced the virtual lines on the previous picture by brass tubing and soldered them together. This gave me a template ( middle part) with the right angles to make a base frame for this part (lowest part)
    Because of its stiffness I used plastic to cover the base frame instead of brass
    And here it is finished
    Another two parts are from the list and rest is work for the lathe. I will finish the aft part as far as I can get and than back to the TR 250
    :mrgreen: Ton
  15. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    Thanks for the update, Ton. Looks like a handful, but glad you are able to have the resources for it! :)
  16. 360C
    360C F1 World Champ
    Great work indeed. I bought one of these models that was "factory built" by the manufacturer. The wing support arrived broken in half and I was looking at the prospect of remanufacturing it myself. Fortunately I was able to fix the break which was luckily hidden by the mounting plate for the wing. Remanufacturing one part is bad enough, having to do multiple complex parts is quite a feat!
  17. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    Thanks guys! 360C, nice to meet another "victim" of Promocom. I assume you did not get a response either when you asked for a new part :) I am glad you were able to fix the part because it is a wonderful model of an icon of a car.
    Ton
  18. 360C
    360C F1 World Champ
    No luck. It's a great model; but the build quality on this one could be better unfortunately. I could have done better if I bought the kit; but the reality is I wouldn't have found the time to build it.
  19. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    I have heard it before ...more than once. To much ambition !
    Ton
  20. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    I must say that is one awesome model and other than not being able to afford one when would I get around to building it as I still have a Tamiya 1:12 Renault RE20 Turbo new in the box that I baught in '85 LOL!!
    tex
  21. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    You treated the kit as a good bottle of wine :) I bought and built it around that period too and it is a real delight! And this promocom kit is the most awesome kit I have ever seen and built ...unfortunately its creator and manufacturer is the opposite.
  22. MovieCarMania
    MovieCarMania Karting
    May 3, 2009
    50
    Woodstock, MD
    Rodney
    Wow! Beautiful model. $4595 yikes, I'll just put that away towards my future Ferrari. Thanks for all the updates.
  23. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    LOL ....that is the best investment :)
  24. texasmr2
    22,232
    Houston
    Gregg
    Thanks Ton. I joined a model building site last year and asked alot of questions because when I begin building it I want it to look like some of the F1 cars on that site, they look like they are about to startup and drive away. I learned that I will need quite abit of goodies to make it look as real as possible.
    I would like to start on it later in the year after I graduate the police academy and get a job to pay for all those goodies. Great thread everyone and I hope I did not rob too much from the origin topic.
    tex
  25. Peperbus
    Peperbus Karting
    Jul 8, 2008
    207
    Ton
    For a good model you don´t need a lot of goodies: basic instruments (knive glue and a spray can) do wonders :)
    Ton
