Fast Idle Issue | FerrariChat
Fast Idle Issue
Discussion in '308/328' started by Lawrence Coppari, Aug 5, 2013.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    An interesting new problem has developed in my 1987 328GTS. For the past several weeks(after warmup) the idle speed will suddenly jump to about 1400 rpms and remain there until I shut the engine off. When I restart it, the idle speed goes back to the 900 +_ which is the normal speed. After about another very few miles the idle jumps back to 1400 and remains there until I shut it off again. The idle adjustment screw can be screwed all the way in but has no effect on the idle speed when fast idle is happening. However, if I back it out, the idle speed increases. The sequence of fast idle, restarting, normal idle, then fast idle again is repeatable.
    This morning while driving I was slowly accelerating and the engine suddenly completely died for a split second. Then it came back on and car ran normally again. I immediately checked the idle speed by depressing the clutch and it was in the 900 range as it should be. But it soon returned to the 1400 range about 1/2 mile later. Upon getting home I shut it off and restarted it. Idle went to 900 but after a short time it jumped back to 1400.
    Seems to me in view of the fact it is so sudden, I have an electrical issue. Anyone have suggestions where I should begin my search.
    I have a master on/off switch on the ground side of the battery that is over 10 years old. The fast idle problem began before the sudden loss of power incidents which have now happened twice.
    To date I have cleaned the plug in connection on the warm up regulator. That had no effect.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Did you check the Ferrari automatic cruise control/fast idle device...the carpet? ;)
  3. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Yes, that was the first thing I did - obvious things first. Throttle is closing against its stop.
  4. Steve Magnusson
    26,504
    Easiest first thing to try IMO is: when the fast warm idle occurs, pinch/block the air line that passes thru the AAV (simulating a properly closed, warm AAV) -- if the idle drops back = bad AAV; if no effect = look elsewhere.
  5. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    I suspected that too so I pinched the line (which is original and quite hard) with a pair of rounded edge hose crimping locking pliers. I failed to mention this in my original posting. It had no effect but I'm not sure I'm pinching it hard enough. I'll remove it and plug it with a cork or something to ensure no air is passing through it.
  6. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    385
    Herts, UK
    Richard
    That happened to my euro spec 328.
    Turned out to be the throttle sensor micro switch had come out of adjustment and wasn't sensing the closed throttle position.
    You can adjust this quite easily.
  7. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    OK, I'll loosen the locking screws and rotate it once it begins to idle too fast. I'll get on it tomorrow. Thanks for suggestion. Thanks everyone who has made a suggestion to date.
  8. spirot
    spirot F1 World Champ
    Dec 12, 2005
    14,941
    Atlanta
    Tom Spiro
    higher idle to me seems to point to by pass air flow - so either an air leak or AAV not working - or thermotime switch on AAV.
    Cant really think of electrical issue that would cause high idle... low yes, but not high
    If the idle adjustment screw is not working - you have an air leak somewhere -
    my 308 QV had a bad o ring in the idle mix screw that was alowing bypass air in....
  9. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I would put my money on bad contact on the AAV connector.
  10. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Here is what I've checked this morning. I cleaned the following connectors: warm up regulator, frequency valve, fuel distributor, throttle body switch. I have not gotten to the one on the AAV. However, I removed the inlet air hose that goes from the fuel distributor (uncontrolled air source) to the AAV and plugged it. I also plugged the nipple on the fuel distributor where it attaches - engine won't run without it plugged. Problem still existed. Engine started right up, ran for a minute or so at 900 rpm then suddenly jumped to 1500 rpm. The AAV rarely shut off the air flow because when I stuck my finger in it with the engine running I felt the vacuum coming and going. However, it had no effect on the high idle speed. This convinces me the AAV is not the issue because I competely stopped its air entry with no effect on idle speed.
    The next thing I'll do is pull off the air line that goes from the idle adjustment bolt to the tee that is also fed by the AAV and plug it and see what happens. I squeezed the line with a hose friendly pair of vice grips but I cannot be sure I totally stopped the air. Removing it and plugging it will convince me.
    I'll report findings once I get this done.
  11. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    The idle adjustment flange/metering screw was removed. The exit holes at the fuel distributor elbow section for both metered and unmetered air were plugged. The line to the AAV was plugged and the idle adjustment bolt/flange was left loose. Engine was started and ran at 900 rpms. The idle adjustment screw would change the rpm (mostly only to increase rpms) but even with my finger over the flanged end where the air enters, the engine still ran about 900 rpms. After a few seconds the idle suddenly (and I mean suddenly just as before) jumped to around 2000 rpms. Completely plugging the idle screw hole at the flange had no effect.
    The only line not checked is the one downstream of the tee and upstream of the aluminum pipe at the intake plenum.
  12. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    If you have eliminated all air leak possibilities then another cause of fluctuating idle is mixture being incorrect, ie too rich will cause slow idle, which could have been compensated-for by (mis)adjusting the throttle stop screw or the idle screw.
    An intermittent heater in the WUR would cause mixture fluctuation. You could easily test for this by unplugging the connector to it, which would introduce the same fault (if there is one) permanently rather than being intermittent, ie is the idle constant when this is unplugged.
    Also is the metering plate always returning to rest position when pressed down? If its binding this would cause slow idle which would speed up when it does return to its rest.
  13. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    A sudden jump sounds like something sticky.
    air sensor plate?
    distributor piston?
    AAV?
    Throttle/cable?
    Try the same experiment without touching anything (no throttle, no idle adj...no anything).
    Re-do with connectors off the WUR and AAV; these have natural travels due to temperature. The natural variations will be different w/o electronic input.
    Shouldn't be affected by TPS at such a low engine speed, and TPS shouldn't flip during warm up. All throttle air should be idle/AAV.
    If you touch it, it will change.
    Tell us what happens.
  14. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,332
    maurice T
    I've had a similar problem for a while and after doing some reading,I checked my Vacuum limiting valve.I removed it and tested it with a vac pump.It tested ok.
    I tested the hoses and they were all ok as well.
    What I did notice was that two of the hose clamps were loose and the hose ends where they connected to the various nipples were worn.I cut off the ends and changed the clamps.
    I haven't had a chance to test if that has solved the problem but will do this weekend.I will post back with the results?
  15. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    #15 Lawrence Coppari, Aug 7, 2013
    TPS makes a click when throttle returns to idle. The click changes the resistance on the pins so TPS is working when it goes to idle.
  16. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    #16 Lawrence Coppari, Aug 7, 2013
    At the risk of sounding silly here, I do not see any electrical connection on the AAV. There is what looks to be a heat sensor that screws into the reservoir. Could it be that the AAV relies on heat conduction rather than electrical heating? Pictures posted.
  17. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Metering plate is not sticking. It moves up and down when engine if off and has been sitting for quite some time. If I push it down a little when engine is idling properly, engine wants to stall. It appears to be in same place at high idle.
    Are you saying some AAV's do not have electrical connections?
  18. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The connector is on the end of the long piece which sticks out. Its off the edge of the picture.
  19. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    I'll check for it when the thing cools down. I cleaned the contacts at the temperature sensor in the second picture above. After doing that I started it up for the first time today. The first start cold idle was higher than before - about 1500 rpms - like it used to be quite a few months ago. (Prior to cleaning the prongs and slip over wire parts the idle would be only about 1100 when cold.) After a minute or so the idle fell off to 900 -1000 rpms as it should. I let it sit there idling until the electric fans came on. The idle never suddenly jumped to the 1400 range as before. It behaved. Then I drove the car for about 10 miles with the problem not returning. Perhaps it was a bad connection at that brass plug or an intermittant connection that confused other things. My plug is a switch that is closed when the water temperature is cold and opens when hot. It seems to me, however, that once the switch opens, it shouldn't matter if the connection is good or not. So I wonder if the problem has been fixed.
    I think there is a vacuum leak or the AAV is not fully closing because I cannot get the idle below 1000 rpms when the engine is fully warm by turning the brass plug on the intake elbow. When it cools I'll unbolt the reservoir and remove the AAV and find the electrical connection that I cannot seem to find now. Hopefully the AAV internals can be cleaned as has been suggested in posts I found on a search on FChat.
    Another test I think I'll do is open the idle air line right at the top of the right side of the intake plenum and plug the rubber elbow and the entrance to the plenum that the elbow slips over. That takes the AAV, and crankcase ventilation system out of the picture. That along with pinching off two small vacuum lines and brake system vacuum line should prohibit the engine from idling if there are no leaks.
  20. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    +1
    AAV uses both inputs from the temperature sensors (coolant and oil) as well...all controlled in the ECU.
  21. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The AAV and WUR voltages are fed from the same feed as the fuel pump so current is applied all the time the engine is running. They are not controlled in any way.
  22. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Reservoir cooled down and I removed the AAV. As you said it has electrical connections. When I removed it from a tepid reservoir, the opening looked like 1/3 moon. I attached it to a car battery and after a couple of minutes it fully closed. It's in the freezer at the moment to see how far it opens.
  23. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Is the throttle butterfly limit screw maybe adjusted too open? If so, the proper idle adjustment screw would have no effect.
  24. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Well I'm back to square one. I went for a ride this morning and everything was fine. After reading your post I checked the screw on the throttle and it is closing all the way. I can back off the screw to where there is space between it and the throttle linkage. That had no effect on idle speed of 1000.
    After doing this I let it keep idling. Suddenly it jumped back to 1400 rpms. I shut it off and restarted but the idle went back to 1400. I think this thing is possessed. Perhaps I need an exorcist.
  25. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    You are correct. I was erroneously thinking about the air injection system (p.72 in the Owner's Manual).
