False reading - California Fuel Range indicator | FerrariChat
Discussion in 'Technical Q&A' started by sherrillt, Feb 3, 2024.
  1. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    My California (2010) fuel range indicator on the display is giving a false reading. It consistently shows 682mi range regardless of fuel level.
    Any diagnostic procedures, speculations, or sensor that is likely faulty?
  2. Niklasbraun
    Niklasbraun Karting
    Nov 30, 2023
    54
    Nuremberg
    Niklas Braun
    First thing, I'd check the fuel level sensor; it could be misbehaving and giving a constant value. Consider running a diagnostic scan to check for any error codes. Also, just give the wiring hooked up to the sensor a once-over to see if anything stands out.
  3. Qavion
    Qavion F1 World Champ
    13,806
    Ian Riddell
    The California seems to have a Trip A and B range selection
    Are you sure you haven't selected the wrong trip?
