Fabspeed O2 Spacers | FerrariChat
Fabspeed O2 Spacers
Discussion in 'Ad Archives' started by cm2, Jun 5, 2016.
  1. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    #1 cm2, Jun 5, 2016
  2. CM20
    CM20 Rookie
    Dec 30, 2016
    3
    Orlando, FL
    Cecil
    I know this post is from Sep. 2017, but thought I'd see if you still have these for sale?
  3. Smyrna355Spider
    Smyrna355Spider F1 Rookie
    Feb 9, 2008
    3,747
    In my Garage
    Scott
  4. CM20
    CM20 Rookie
    Dec 30, 2016
    3
    Orlando, FL
    Cecil
    Thanks for the help, much appreciated. My car is a 2000 360 with Kinetix high flow cats and Tubi exhaust. Do you know if I need spacers with or without mini cats? 90 degrees? Or straight?
  5. Smyrna355Spider
    Feb 9, 2008
    3,747
    In my Garage
    Scott
    The 90 bend simply helps to reduce the amount of exhaust tested. I have used the 90 without any mini cats, nor the spacer and I never had a cel thrown in my 355. I had high flow cats as well. I can't say I am positive but I truly believe you will be fine with the simple 90. The kit I posted has the spacer included so you can always add it later if you do get a cel.
