F50 dashboard covering material | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Red Sled, Apr 25, 2017.
  1. Red Sled
    Red Sled Formula Junior
    Does anyone know what the grey dashboard covering is made from, and whether it can be sourced? The factory has none. I have seen a few which are close in appearance but not identical to the original. Thanks
  2. joe sackey
    Sponsor
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Ask Henk HVL Class Leather® - Home he's a whizz at sourcing materials, he sourced the velour dashboard material for one of our 288 GTOs and it was a good match.
  3. Rifledriver
    36,760
    Henk would be my first choice but you might get in touch with Re Originals too.
  4. Red Sled
    Joe, Brian - thank you both for the leads. Much appreciated. My dash covering becomes a slightly loose fit when cold but is taut as it should be when warm. Not sure whether it a common issue or whether age/sun related.
    Thanks again for your help.
  5. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Orourke trimmers seem to be the go to guys in the UK for such things as well, especially with the family links to Mototechnique.
  6. joe sackey
    Sponsor
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Common issue with F50s as the material Ferrari SpA stretches over the years.
    I would not replace the material if it is unblemished and retains good color, I would simply have an experienced upholsterer adjust it so the fitment is more taut.
    This way its both perfect & original!
  7. Rifledriver
    36,760
    I agree even if not 100%. In the end originality will be more important on a car of that stature.
  8. Red Sled
    Good advice as always gents - thank you both. The material looks fine other than the stretching. So, I will have a go at getting it adjusted first. The material seems to stretch when cold. I was worried that adjusting it to be taut when cold would then put too much stress when it is hot.
    Thanks again gents.
  9. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    This is common. Virtually every F50 experiences this. I wouldn't worry about it.
