F430 Window felt trim/seal issue (Easy Fix) | FerrariChat
Discussion in '360/430' started by _JERRY_, Nov 26, 2018.
  1. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    #1 _JERRY_, Nov 26, 2018
    For those who have encountered a similar issue, with the felt trim at the windows wearing out due to the glass window sliding onto it, over time.
    What i did was to get A4 sized felt pieces from most Arts n Craft stores which come with an adhesive built-in on one side. The result is quite satisfactory, albeit not perfect.
    Below are images to show the before and after.
    (Before):
    Just cut the A4 strip as per desired.
    (After): with and without lighting.
    Where i'm from, the 2 sides have to be bought together for a whopping $1,700.
    Hope the $10 solution suffices. This makes much more sense to me , considering even if you replace them with a new set, eventually they will be worn out again.
    Cheers!
    f355spider likes this.
  2. Chux360
    Chux360 Rookie
    Aug 14, 2017
    5
    Golden, Colorado USA
    Jerry, nice hat, strategically placed.
    Sent from Chux iPhone
    _JERRY_ likes this.
  3. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Quite satisfactory. Thanks for sharing.
    Sent from my Galaxy
  4. brookliner7
    brookliner7 Formula Junior
    883
    San Antonio, TX
    Hans
    Nice work!
    I always worry about about my windows shifting over time so I cringe when people slam my doors!
  5. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    :p
  6. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    One thing i forgot to add. Because the position of the felt actually serves some functionality, you want to get a felt piece thats as thin as possible. ( Thick enough to cover the wear and eye-sore, but thin enough so that it does not obstruct the window movement too much , thereby straining the window mechanism.)
    brookliner7 likes this.
  7. shifter
    shifter Formula Junior
    625
    Danville, Ca
    Joe
    Nice trick.
    Oh how I hate that felt. Not only that it doesn’t wear gracefully, but felt crumbs everywhere as it ages drives my OCD off the charts.
    _JERRY_ likes this.
  8. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Totally understand that "OCD". :p
  9. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    <UPDATE>
    Gotta make sure the felt goes all the way to the top. I added a strip at the top to prevent water getting in during heavy rain. Also, if any gap between the window and the base trim is not filled, the overall noise insulation is affected as well. I went thru bad weather, and got a couple of rain droplets resting on the interior glass. After the additional strip was added, i used a garden hose, to spray water at the window trim for a good 2 mins, no more water leakage into the cabin-side.
  10. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    621
    Any reason why this would not work on the spider as well where there is felt on just one side of the window?
  11. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    Pretty sure it shouldnt be an issue. You would want the piece of felt from the art store to be as thin as possible though, its the same reason as the hardtop, when you have your roof on. That being said, the felt and the double-sided tape quality, will probably be different between what i used and what you're gonna use.
  12. Mel Spillman
    Mel Spillman Formula Junior
    736
    Sugar Land, Tx
    Great Idea! Thanks for your post.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,788
    Looks good. The required felt (1-2mm thick, max) is actually available in tape form, which should speed the job.
  14. Mel Spillman
    736
    Sugar Land, Tx
    Where did you get that windshield banner with the prancing horse. Very nice!
  15. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
  16. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    I didn’t sand mine. Direct apply over. The original felt is really thin to begin with, and once it wears out it’s even thinner. Imo sanding might leave u with more of a mess and create a larger than ideal area for u to cover with the new pseudo felt.
