F430 Steering Wheel Crease | FerrariChat
Discussion in '360/430' started by Carrera997, Jul 9, 2023.
  1. Carrera997
    Carrera997 Rookie
    24
    Austin, Texas
    Hi guys,
    Looking at an F430 that seems to have a crease on the steering wheel. With a quick google search, I couldn’t see anything on it. Has anyone else experience that? Or what is it?
    Any help is appreciated. Looking forward to stepping into Ferrari from Porsche!
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    That crease is in the airbag. It’s probably the seam where the two halves split apart when the airbag deploys.
    Carrera997 likes this.
  3. Mario Andretti
    Mario Andretti Formula 3
    1,739
    Boston
    That is also a custom wheel, I wonder if they caused the crease when they tried to wiggle the airbag off the wheel; pulled too hard on one side or the other causing the 2 halves to move a bit.
    Actually, I don't wonder. I am confident is what happened. I have not seen a crease in any F430 I saw before with stock steering wheels.
    RobinMasters likes this.
  4. Carrera997
    Carrera997 Rookie
    24
    Austin, Texas
    Anything I should be concerned about? Or just cosmetic? I saw a few things about airbag recalls with Takata going out of business.
    I figured it was stock since sticker has “upper carbon fiber driving zone” and seems maxed out with carbon on the sticker. But I may be wrong.
  5. GogglesPisano
    GogglesPisano F1 Rookie
    2,934
    East Bay, California
    Joe
    It either happened during the wheel swap or someone mashed the center in thinking it's where the horn was. Should only be cosmetic but a little heat or steam may help relax it back. Small chance the break point was compromised so it will always be like this. Safety speaking, that doesn't affect deployment.
  6. LHBMC
    LHBMC Karting
    Nov 16, 2011
    62
    Hello,
    I disagree, this is not a custom wheel.
    My F430 has the factory carbon fiber driver's zone package and my wheel is identical to the one being discussed here.
    I am 100% positive that it is original and has never been replaced.
    It also has the crease mentioned here but I never even noticed it until I took the attached picture a few minutes ago.
    Regards,
    Les
  7. Mario Andretti
    1,739
    Boston
    That looks identical to the MAcarbon wheel, I still don't believe it. I also have that option, and it's only related to the areas around vents and stereo being CF.
    EDIT: The thickness of the top area looks very un-natural for a factory wheel, they would never design that. I think Exoticcargear have the most natural looking CF wheels, with thickness following the OEM design.
  8. Mario Andretti
    1,739
    Boston
    that being said, I would not hesitate to buy that car if that's the only issue! :)
  9. LHBMC
    LHBMC Karting
    Nov 16, 2011
    62
    Hello,
    Once again I respectfully disagree.
    I too have carbon fiber around the vents and stereo.
    But I also have the steering wheel carbon fiber as we have discussed and the instrument cluster and paddle shifters are also factory carbon fiber.
    Again, I am 100% positive that all these items were factory installed and have never been changed.
    Perhaps there were two options available, what is on your car and what is on mine.
    Regards,
    Les
  10. RobinMasters
    RobinMasters Karting
    Dec 31, 2022
    53
    Bill Bodner
  11. Mario Andretti
    1,739
    Boston
    .... that seals the deal. No F430 outside Scuderia came with carbon fiber paddles to my knowledge, hence your car is not original, hence the Steering wheel is not original, and who knows what else on your car.
  12. Mario Andretti
    1,739
    Boston
    ... just kidding. Enjoy it , who gives a f**k if those are oem or not, great cars to have!
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    The carbon wheel with red 12 o'clock stripe was part of the MY2008 (at least in England) optional full carbon driving zone pack. The 'full' pack comprised of steering wheel, vents/hvac/radio, and paddles.
    SpecJunkie likes this.
  14. SpecJunkie
    SpecJunkie Karting
    Dec 8, 2020
    72
    London
    Since there's a bit of a debate going on, I'll add my 2c here — those are genuine Ferrari F430 carbon steerings wheels.
    They formed part of the "Upper Carbon Driver Zone" (option code CIDZ) which also included carbon shift paddles and carbon instrument cluster inlay. There was also a much rarer "Lower Carbon Driver Zone" (CILZ) which consisted of a complete carbon fibre centre console structure (similar-ish to the Scuderia's). These extended carbon-fibre options were available under the "Carrozzeria Scaglietti" personalisation programme.
    @Mario Andretti what you're thinking of is the more common carbon fibre dashboard and centre console inserts which fall under the TRIM option code, seperately. Initial buyers had the choice of either silver aluminium or carbon fibre for these touch surface pieces. Understandably, most F430 buyers around the world opted for the carbon fibre look, since the painted silver trim can look a little "Fischer-Price", but I digress.
    OP, in regards to the crease itself: it is the airbag tear seam and a cosmetic issue only. Judging by your username; you may already know that Porsche 997 gen steering wheels suffer badly from this too; particularly the round airbag of the 3 spoke sports wheel, where they crease down the middle and around the crest. Again, a cosmetic issue only.
    Tbf I've never seen one go that bad, but I suppose it could be a batch issue with the leather. Perhaps climate has an impact here, I don't know. But if it bothers you that much, you could always replace the airbag unit entirely for one in better condition. That said, I certainly wouldn't turn down a car because of it! The carbon driver zone is a rare option and looks very cool.
    AandSC and mwstewart like this.
  15. CoreyNJ
    CoreyNJ Formula 3
    2,358
    New Jersey Shore
    It seems to be more pronounced in the picture from the OP than my 2009 which I know does have the factory carbon wheel with stripe and carbon paddles. I also never noticed there is a line where the airbag changes angles, it's very subtle but seems to no be so subtle on the OPs picture. My guess is the leather shrank on that airbag and made it very obvious.
    Here is a pic of my OEM wheel before I put my CF cup holder in, so this is all factory carbon and as per my window sticker, I have both "Carbon Fibre for Driving Zone" and "Carbon Fibre for Lower Cabin Zone"
  16. SpecJunkie
    SpecJunkie Karting
    Dec 8, 2020
    72
    London
    Good shot. You can see the centre console is entirely CF as opposed to just the top inlay. Also forgot to mention you get carbon inner door mouldings and door entry strips as part of the Carbon Lower Cabin Zone package. Lovely interior that CoreyNJ! Extended carbon works so well with Nero leather. Compliments, rather than clashes imo.
  17. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    379
    NC
    I think what is included in the package must have changed over the years. My 05 has the “CARBON FIBER FOR DRIVING ZONE CIDZ” and that’s just the vent/radio surround - no wheel, cluster or paddles. I also don’t see “TRIM” on the 2006 options sheet either.
    Perhaps they split the option out into two separate options in later years.
  18. CoreyNJ
    CoreyNJ Formula 3
    2,358
    New Jersey Shore
    Did they offer “Carbon Fibre for the lower cabin zone” in the 2005/2006? Maybe that is what came with the steering wheel center console top and the door threshold pieces.
  19. tstuli
    Jun 12, 2018
    379
    NC
    yes. At least it’s on my 2006 options order sheet but I don’t know what pieces it may have included.
  20. Mario Andretti
    1,739
    Boston
    My spec sheet says (it's a 2005) "Carbon fiber for driving zone" , they might have changed it later years ? or added the "lower" option. I always thought the cars I see with CF wheels have them done aftermarket...
  21. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    They did change the pack over the years. The wheel and console for example came later on.
  22. CoreyNJ
    CoreyNJ Formula 3
    2,358
    New Jersey Shore
    Thanks, here is another older money shot. I really love the OEM carbon door sills. I really need to take new interior pics, these are like 3 years+ old now....
    Mario Andretti likes this.
  23. SpecJunkie
    SpecJunkie Karting
    Dec 8, 2020
    72
    London
    The options list I have is for the UK from March 2006 onwards. It’s not uncommon for Ferrari to revise their packages over the years, so I agree it could just be a change like that. AFAIK, the carbon sills, steering wheel etc were not available in 2005.
    Sorry for the confusion, just to clarify here; you wont see "TRIM" as an option code anywhere or listed on your US spec stickers. It’s an internal code on Ferrari's Modis system.
    A bit like “INST” is the internal code for which color Rev counter the initial buyer chose (Rosso, Giallo, Bianco). As an example; a European VIN 2007 blue F430 with tan leather would show on Modis like this:
    • Exterior: Blu NART
    • Interior: Cuoio (4609)
    • Carpets: Nuovo Cuoio
    • CALY: Yellow brake callipers
    • CCMD: Carbon-ceramic brake discs
    • CDCH: 6-disc CD changer
    • EXT1: Fire extinguisher
    • INST: Giallo rev counter
    • LOGO: Scuderia Ferrari shields
    • RUF1: Leather headliner
    • SHF2: Leather rear shelf / door mould
    • TRIM: Carbon-fibre dashboard inserts
  24. CoreyNJ
    CoreyNJ Formula 3
    2,358
    New Jersey Shore
    OK, back to the OP question.
    Here are close ups I took yesterday, ignore the dust I haven't driven the car or taken it out of the garage in over a week while I was on a short vacation. While in some light you can see the transition line in the air bag, you can't see it most of the time and it's barely perceivable when you run your hand over it other than the change in angle of the airbag shape. I hope that makes sense how I'm describing it.
